[SOLVED] KB3000850 fails, SFC/DISM RH work, 80073712
Remove Update Manually
1. Right-click on the Start
wusa /uninstall /KB:2955164
3. Let me know if it says it was successful or if there are any errors.
Windows Update Standalone Installer
Installer encountered an error: 0x80073712
The component store has been corrupted.
I appreciate your continued assistance.
FWIW,
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>wusa /uninstall /KB:2955164
C:\Windows\system32>sfc/scannow
Verification 99% complete.
C:\Windows\system32>dism /online /cleanup-image /restorehealth
Version: 6.3.9600.17031
Image Version: 6.3.9600.17031
The restore operation completed successfully. The component store corruption was
 repaired.
Yes the update is listed.
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17842_none_90da81a4dac50d54\utc.app.json
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17842_none_90da81a4dac50d54\telemetry.ASM-WindowsDefault.json
Alright, let's go for Process Monitor.
Capture Process Monitor Trace
1. Download and run Process Monitor.
Leave this running while you perform the next steps.
2. Attempt to install KB3000850.
3. Stop Process Monitor as soon as the install fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
The PML will (hopefully) contain the events we are looking for, and the CBS.log will help to narrow down the time when the event we are looking for happened.
Not doing Win10 on this machine. I have completed the logging, not having luck uploading the file. It is 300+. I am trying to re-compress as 7z and will let you know when it is up. I appreciate the patience.
OK, I think I've found the problem.
The appid value was missing from HKLM\COMPONENTS\CanonicalData\Deployments\microsoft-w..anguagepack_31bf3856ad364e35_6.3.9600.16384_0c962c81b7da62a8
View attachment SFCFix.zip
Excellent! Thanks for sticking with it until we found a solution :thumbsup2:
You certainly can, donations are always welcome.
I'll mark the thread as solved. If you encounter any problems, please post back and I'll continue to assist you.
