KB4486563 will not install
SFCFix version 3.0.1.0 by niemiro.
Start time: 2019-03-05 07:49:43.021
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_ac40e7999efefd6d86f0be35993dae75_31bf3856ad364e35_none_1f94bc7e046b9a6a.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_ac40e7999efefd6d86f0be35993dae75_31bf3856ad364e35_none_1f94bc7e046b9a6a\11.2.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_ac40e7999efefd6d86f0be35993dae75_31bf3856ad364e35_none_1f94bc7e046b9a6a\11.2.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_ac40e7999efefd6d86f0be35993dae75_31bf3856ad364e35_none_1f94bc7e046b9a6a.
SFCFix version 3.0.1.0 by niemiro has completed.
Finish time: 2019-03-05 08:01:51.135
Script hash: UpbGCN6dl8+ifWEYeF2g3AEE6a808WN0uVJbNbjNH10=
Afraid not. Thinking will clone this image and make this problem go away, thank you for help and endeavour anway.
