The previous fix didn't work.
Rightclick the file SFCFix.zip on your desktop and click Extract all.
Do not change anything and allow the extraction to the default location.
This will create a folder called SFCFix on your desktop.
- Download the Farbar Recovery Scan Tool and save it to your Desktop:
64-bit: Downloading Farbar Recovery Scan Tool - Download the attachment fixlist.txt and save it to your desktop.
- Right-click on FRST64.exe and select "Run as administrator".
- Press the Fix button.
- The tool will now process fixlist.txt.
- If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
- When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
- Post the logfile Fixlog.txt as attachment in your next reply.
