[SOLVED] KB4530734 Fails With Error Code 80073701
FRST Registry Search
6. Copy and paste KB4516065 into the Search box and click the Search Registry button.
  • Thanks
Reactions: 108
Here is a proper EXPORTED copy of the CBS folder:
CBS FOLDER
I noticed your post, above, after posting this. To avoid confusion, plase analyze this CBS folder and advise afterwards. Thanks.
Step#1 - FRST Fix
6. Reboot and retry updates.
  • Thanks
Reactions: 108
Thanks. I am attaching the log as opposed to pasting it's contents, as it's about 2mb in size.
6. Copy and paste KB4519976 into the Search box and click the Search Registry button.
  • Thanks
Reactions: 108
Step#1 - FRST Fix
  • Thanks
Reactions: 108
Thank you! Windows update now works.
The problem with the fixes was, I was in an endless loop. When I would restart the computer, I would always allow Windows Update to install it's pending update, which would basically undo the fix... and also fail. Then, the OS would restart in the same state it was in before.
So I had to kill the OS with the restart button, bypassing the pending windows update. Once I did that, the fixes you created went to work at startup. The computer restarted 2 times to finalize the fix and all seems to be working properly now.
Thanks again, and happy new year!
