hurricane28
It does not matter how power hungry the CPU is, when the computer is shut down, the CPU should be drawing nothing. Even in standby, the CPU is doing nothing.Regarding the high wattage being used when shut down, i don't know if it makes any difference but i am on an very very power hungry AMD system
This is happening now? Or did you already get this replacement and have the same problem?I called Cooler Master and they said it must be the PSU so i decided to do an RMA service from them.
While Memtest is not conclusive, you did get no errors. Did you try running with 1/2 your RAM at a time?i RMA my ram and go from there..
If this were years ago, I would also suggest you inspect your motherboard for leaky or bulging electrolytic capacitors. Most motherboards now use solid caps. But you still might inspect your board to make sure all look good.
Ah of course, thnx for pointing that out.
Yes this is happening now, i called them and they said that it must be the PSU since there is no other hardware issue in my system and i know this because i ran every stability/stress test program i know without any problem for extended period of time.
I can assure you there is nothing wrong with the ram, i tested the ram with memtest the first day i got my ram and let it run over night and it was stable as a rock and no errors to be found. if there was anything wrong with the ram memtest would find it. To be sure i also did run the Windows memory tool and yet again no errors. The only thing i can think of is the CPU and the PSU but since i stressed the CPU to its limits without breaking a sweat for an extended period of time, i am almost sure it the PSU because i had this same exact error before and it was solved by a new PSU. The only question is why is this the second PSU that went wrong on me. I asked Cooler Master it they would be so kind to test the PSU since they have an proper PSU tester in their lab, to give me some advice or maybe can determain what the cause is.
I checked the board and i couldn't see any leaking/bulging capacitors but i will inspect the board again just to be sure.
I don't know why the system is still drawing 65 watts when idling, the whole system is not shut down but only a part is still running like the Motherboard is still running, the Corsair h100i GTX, my 3 harddrives, all of my fans and my fan controller, so i guess that is enough to pull 65 watts for some reason, i don't know.
