major problems!
C:\Windows\system32>chkdsk /f
Cannot lock current drive.
what should i do?
Select "Y"; Re-start the system.
That is a typical message from chkdsk -- the HDD must be "unmounted" during the test.
Happy Holidays!
jcgriff2
what do u do?
Let's go about it the graphical way.
  1. Click the Start button :startorb: then click Computer.
  2. Right click on the C: Drive, under the Hard Disk Drives category, and click on Properties
  3. Click the Tools tab
  4. Under Error Checking, click the Check Now button
  5. Click Continue on the UAC prompt that appears
  6. A small dialogue box will appear. Check the Automatically fix file system errors box, and leave the other unchecked
  7. Press Start
  8. Another message will appear stating "Windows can't check the disk while it's in use". Click Schedule Disk Check
  9. Reboot the computer
  10. Download ListChkdskResult.exe (by SleepyDude) from the link below:
    https://dl.dropboxusercontent.com/u/12354842/My Tools/ListChkdskResult.exe
  11. Double click on it to run it. It will take a few seconds to scan, then it will open a Notepad window with the log. Copy and paste the contents of this into your next post please!
------< Log generate on 01/01/2014 13:13:40 >------
Category: 0
Computer Name: laurag-PC
Event Code: 1001
Record Number: 2104
Time Written: 01-01-2014 @ 13:10:47
Event Type: Information
User:
Message:
Checking file system on C:
Volume label is Vista.
112512 file records processed.
675 large file records processed.
0 bad file records processed.
0 EA records processed.
60 reparse records processed.
Unable to locate the file name attribute of index entry dialer.exe
of index $I30 with parent 0x246b in file 0xc436.
Deleting index entry dialer.exe in index $I30 of file 9323.
Unable to locate the file name attribute of index entry perfctr.h
of index $I30 with parent 0x246b in file 0xb8c8.
Deleting index entry perfctr.h in index $I30 of file 9323.
Unable to locate the file name attribute of index entry tapi.dll
of index $I30 with parent 0x246b in file 0x45b5.
Deleting index entry tapi.dll in index $I30 of file 9323.
Unable to locate the file name attribute of index entry tapilua.dll
of index $I30 with parent 0x246b in file 0x45b8.
Deleting index entry tapilua.dll in index $I30 of file 9323.
Unable to locate the file name attribute of index entry tapiperf.dll
of index $I30 with parent 0x246b in file 0x45ba.
Deleting index entry tapiperf.dll in index $I30 of file 9323.
Unable to locate the file name attribute of index entry tapiperf.ini
of index $I30 with parent 0x246b in file 0xb8c9.
Deleting index entry tapiperf.ini in index $I30 of file 9323.
Unable to locate the file name attribute of index entry tapiui.dll
of index $I30 with parent 0x246b in file 0x45bd.
Deleting index entry tapiui.dll in index $I30 of file 9323.
Unable to locate the file name attribute of index entry telephon.cpl
of index $I30 with parent 0x246b in file 0x45d8.
Deleting index entry telephon.cpl in index $I30 of file 9323.
142616 index entries processed.
CHKDSK is recovering lost files.
Recovering orphaned file tapi.dll (17845) into directory file 9323.
Recovering orphaned file tapilua.dll (17848) into directory file 9323.
Recovering orphaned file tapiperf.dll (17850) into directory file 9323.
Recovering orphaned file tapiui.dll (17853) into directory file 9323.
Recovering orphaned file telephon.cpl (17880) into directory file 9323.
Recovering orphaned file perfctr.h (47304) into directory file 9323.
Recovering orphaned file tapiperf.ini (47305) into directory file 9323.
8 unindexed files processed.
Recovering orphaned file dialer.exe (50230) into directory file 9323.
112512 security descriptors processed.
Cleaning up 818 unused index entries from index $SII of file 0x9.
Cleaning up 818 unused index entries from index $SDH of file 0x9.
Cleaning up 818 unused security descriptors.
15053 data files processed.
33737632 USN bytes processed.
77823999 KB total disk space.
35056332 KB in 87288 files.
52508 KB in 15054 indexes.
0 KB in bad sectors.
216075 KB in use by the system.
42499084 KB available on disk.
19455999 total allocation units on disk.
10624771 allocation units available on disk.
Internal Info:
80 b7 01 00 d2 8f 01 00 58 b8 02 00 00 00 00 00 ........X.......
53 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 S...<...........
42 00 00 00 5f 84 18 77 d8 81 17 00 d8 79 17 00 B..._..w.....y..
I have requested some more assistance from an expert on chkdsk. In the mean time, I would like to run another test for the HDD. You will need a blank CD or DVD to do this. Hard Drive (HDD) Diagnostics - Sysnative Forums. I would like you to run the SHORT test and the LONG test please and let me know the results.
Stephen
i have copyed the sea tolls like asked and it does not work it is not readin the file on the disc
