Start::
CreateRestorePoint:
CloseProcesses:
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
MSCONFIG\Services: AdobeFlashPlayerUpdateSvc => 3
MSCONFIG\Services: SupportAssistAgent => 2
HKU\S-1-5-21-3830305220-1279632340-1782550212-1001\...\StartupApproved\Run: => "CCleaner Smart Cleaning"
FirewallRules: [TCP Query User{107623D2-075A-4FA4-B6ED-EA246BC65311}C:\users\vandana\appdata\roaming\utorrent\utorrent.exe] => (Allow) C:\users\vandana\appdata\roaming\utorrent\utorrent.exe => No File
FirewallRules: [UDP Query User{09D1DE1C-49A9-4C47-9265-55F849A1BC50}C:\users\vandana\appdata\roaming\utorrent\utorrent.exe] => (Allow) C:\users\vandana\appdata\roaming\utorrent\utorrent.exe => No File
FirewallRules: [TCP Query User{0AEDB9CE-E8EA-462F-9B33-0B7B9D1434B3}C:\users\vandana\appdata\roaming\utorrent\utorrent.exe] => (Block) C:\users\vandana\appdata\roaming\utorrent\utorrent.exe => No File
FF Extension: (Flash Player 2021) - C:\Users\vandana\AppData\Roaming\Mozilla\Firefox\Profiles\sx553c94.default-release\Extensions\{6cc0a66e-ae3d-4cd8-9a03-5cd93b392903}.xpi [2021-10-03]
FF Extension: (Flash Player ) - C:\Users\vandana\AppData\Roaming\Mozilla\Firefox\Profiles\sx553c94.default-release\Extensions\{87e997f4-ae0e-42e6-a780-ff73977188c5}.xpi [2021-05-30]
R2 LTService; C:\Windows\LocalT.exe [7526072 2021-12-13] (HONGKONG LINGYUN NETWORK MDT INFOTECH LIMITED -> )
S2 Dell Customer Connect; "C:\Program Files (x86)\Dell Customer Connect\DCCService.exe" [X]
S2 DellDigitalDelivery; "C:\Program Files (x86)\Dell Digital Delivery\DeliveryService.exe" [X]
S3 tesrsdt; C:\Windows\system32\drivers\tesrsdt.sys [802920 2020-06-24] (Tencent Technology(Shenzhen) Company Limited -> TENCENT)
S3 UniSafe; C:\Windows\system32\drivers\UniSafe.sys [572632 2021-03-28] (Tencent Technology(Shenzhen) Company Limited -> TENCENT)
2021-12-17 11:43 - 2021-12-13 16:01 - 007526072 _____ C:\Windows\LocalT.exe
2021-12-17 11:40 - 2021-12-20 22:27 - 000000000 ____D C:\Program Files (x86)\PowerControl
2021-12-17 11:40 - 2021-12-17 11:40 - 000003548 _____ C:\Windows\system32\Tasks\PowerControl HR
2021-12-17 11:40 - 2021-12-17 11:40 - 000003292 _____ C:\Windows\system32\Tasks\PowerControl LG
2021-12-17 11:08 - 2021-12-17 11:09 - 022464840 _____ C:\Users\vandana\Downloads\cool-android-assistant.exe
2021-12-17 08:15 - 2021-12-17 08:15 - 000000000 ____D C:\ProgramData\WsAppHelper
2021-12-16 13:51 - 2021-12-16 13:51 - 000980720 _____ C:\Users\vandana\Downloads\drfone_setup_full4008.exe
2021-12-15 22:14 - 2021-12-15 22:15 - 007790371 _____ C:\Users\vandana\Downloads\Bifrost_Android.apk
2021-12-15 22:10 - 2021-12-15 22:10 - 000000000 ____D C:\Users\vandana\Downloads\Bifrost_Windows
2021-12-15 22:02 - 2021-12-15 22:07 - 055228905 _____ C:\Users\vandana\Downloads\Bifrost_Windows.zip
2021-12-14 20:23 - 2021-12-14 20:23 - 000726552 _____ (Spotify Ltd) C:\Users\vandana\Downloads\SpotifySetup.exe
2021-12-07 13:29 - 2021-12-07 13:30 - 036492512 _____ (Piriform Software Ltd) C:\Users\vandana\Downloads\ccsetup587.exe
2021-12-23 00:39 - 2015-05-10 08:46 - 000000000 ____D C:\Users\vandana\AppData\Roaming\uTorrent
2021-12-17 13:49 - 2021-08-09 22:24 - 000000000 ____D C:\Users\vandana\AppData\LocalLow\uTorrent
2021-12-17 12:36 - 2019-05-27 13:24 - 000000000 ____D C:\Users\vandana\AppData\Local\BitTorrentHelper
2021-12-07 18:51 - 2018-07-02 20:05 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tencent Software
2021-12-07 11:43 - 2021-05-30 22:55 - 000000000 ____D C:\Users\vandana\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WonderFox Soft
EmptyTemp:
End::
1. Attaching logs.
- The fixlog.txt
- What programs did you uninstall and if the process ran fine
- Fresh FRST logs, Addition and FRST
- Feedback: How is the computer running now? Any remaining question/issue/concern?
Start::
CloseProcesses:
CMD: DISM /Online /Cleanup-Image /RestoreHealth
CMD: SFC /scannow
EmptyTemp:
End::
I was ok at first, but some options are shown as the file location instead of the name of the option.1. Preinstalled software
Although I don't recommend this, and I would go to uninstall everything
Alright, I'll do that laterPlease, if you want to restore these programs, do not do that now. Wait for the cleaning procedure to complete first.
Ah, I'll definitely give the alternative(s) a try. Ok, I won't be installing anything now.2. Microsoft Office
In case you just want an Office Suite, no matter it is Microsoft's, you can try some free alternatives:
I tried the first two above, and I like them very much. You can open Microsoft Office documents with them and Microsoft Office can open files created with them.
It's your decision. However, do not install anything yet.
A total of 4 or 5 documents were encrypted, out of which only one is important (meaning it has some personal information). The file is not needed for use anymore.3. Encrypted files
I asked you and I think you didn't reply about this. Are your documents encrypted? If yes, the usual reply is that they can't be decrypted now. But we will do some search about this, at the end of the procedure.
Alright.4. Corrupted files
We are going to check this after I review your fresh logs in a while.
Log:Please post the log in your next reply.
Windows Resource Protection found corrupt files and successfully repaired them
Windows Resource Protection found corrupt files but was unable to fix some of them
Windows Resource Protection could not perform the requested operation
I got this:Run Deployment Image Servicing and Management (DISM)
- Click on the Start button and in the search box, type Command Prompt
- When you see Command Prompt on the list, right-click on it and select Run as administrator
- Enter the command below and press on Enter;
Code:DISM /Online /Cleanup-Image /RestoreHealth
Yes, please do the above actions again, with internet.
Dism /Online /Cleanup-Image /StartComponentCleanup
I did that and started the DISM. It's been more than 30 minutes, but the process has not started yet. Shall I try the second method? Or shall I wait for some more time? If so, how long should I wait?Troubleshoot
Ok, I'll wait for another half an hour.Wait another half an hour and let me know. No errors, right?
Edit:
The troubleshooting process was slightly different from what you had mentioned above. The process I did:
1. In the Control Panel, clicked on Troubleshooting.
2. Selected "Fix problems with Windows Update" under System and Security".
Two issues were fixed.
Yes, I could not find the troubleshooting option in Settings, so I used the other way.That's because you went via Control Panel and not via Settings.
