Microsoft Edge Preview Builds
Dev channel update to 100.0.1185.7 is live
Added features:
  • Enabled by default support for Clarity Boost in Xbox Cloud Gaming.
  • Added a prompt to automatically sign into sites (with the same account that’s used for signing into the browser) that are preventing it because they’ve previously been signed out of.
  • Management policies (note that updates to documentation and administrative templates may not have occurred yet):
    • Added a management policy to control if the Edge Asset Delivery Service is Enabled, which is a service that the browser uses to download various configuration files and machine learning models that power certain features.
    • Added support for the PDF Secure Mode management policy, which controls Digital Signature validation of PDFs.
  • Developer:
    • Added an API to WebView2 to update Status Bar text. Note that this API was previously in “Experimental” status and updates to documentation and SDKs may not have occurred yet.
    • Added support for non-value badges on PWA shortcuts to show when a website wants to set an alert but doesn’t want to specify any text on the badge.
Improved reliability:
  • Fixed a crash when using Find on Page.
  • Fixed a crash when opening certain PDFs.
  • Fixed a crash when interacting with IE mode tabs.
  • Fixed a crash when refreshing IE mode tabs.
  • Fixed an issue where the browser sometimes can’t navigate to any websites and load endlessly.
  • Mobile:
    • Fixed a crash when viewing tabs.
    • Fixed a crash when using certain Shopping features.
    • Fixed a crash when using Read Aloud.
Changed behavior:
  • Reduced the number of extensions that block Startup Boost.
  • Fixed an issue where the browser re-opens as soon as it’s closed.
  • Fixed an issue where Family Safety sometimes doesn’t work, and instead launches a regular window.
  • Fixed an issue where clicking websites pinned to the taskbar sometimes activates existing tabs of the same site instead of opening a new tab to the site.
  • Fixed an issue where websites are sometimes attached to the incorrect pinned website icon on the taskbar when there are multiple pages from the same website pinned.
  • Fixed an issue where certain buttons can’t be hidden from the toolbar.
  • Fixed an issue where Tab Groups don’t have the correct colors in certain menus.
  • Management policies:
    • Fixed an issue where certain versions of Windows report that they don’t support enterprise management when they should.
    • Fixed an issue where the management policy to control if Kiosk Address Bar Editing is Enabled sometimes doesn’t work.
    • Removed support for the management policy from Chromium to control if the Lock Icon In the Address Bar is Enabled, which controls which kinds of sites show the lock icon.
  • Mobile:
    • Fixed an issue where downloaded files sometimes can’t be opened.
    • Fixed an issue where files sometimes can’t be downloaded and then shared to OneDrive.
    • Fixed an issue where profiles sometimes can’t be switched after using Guided Switch.
    • Fixed an issue where cookie consent dialogs from certain websites can’t be dismissed.
Dev channel update to 101.0.1198.0 is live
Added features:
  • Enabled by default the ability to view PDF properties and metadata.
  • Added info to the Edge Bar about the current URL.
    • Added a policy to control if Kiosk Swipe Gestures are Enabled, which controls if swipe gestures to navigate forward and back are functional in Kiosk mode.
    • Added a policy to Configure Keyboard Shortcuts, which configures which keyboard shortcuts are disabled.
    • Added a policy to control if the Microsoft Office Menu is Enabled.
    • Added a policy in Internet Explorer Mode to Enable Save page As, which has previously been disabled in IE mode tabs.
    • Added support on Mac for the policy to set the Auto Update Check Period in Minutes.
  • Developer (note that updates to documentation and SDKs may not have occurred yet):
    • Added an API to WebView2 for initial support for multiple profiles. Note that this API was previously in the “Experimental” status.
    • Added an API to WebView2 to set the default download location. Note that this API was previously in the “Experimental” status.
    • Added an experimental API to WebView2 to verify or block a certificate from the server when an error is detected.
  • Fixed a crash on launch.
  • Fixed an issue where closing a tab group sometimes crashes the browser.
  • Fixed a crash when typing into a webpage.
  • Fixed a crash when changing certain Settings.
  • Fixed a crash when signing out of the browser.
  • Fixed a crash when using Picture in Picture.
  • Fixed an issue where the Spotify PWA sometimes crashes.
  • Fixed a hang.
  • Mobile:
    • Fixed a crash when interacting with the address bar.
    • Fixed a crash when navigating using Top Sites.
    • Fixed a crash when performing a search.
    • Fixed a crash when editing autofill data.
    • Fixed a crash when changing accessibility settings.
    • Fixed a crash on Surface Duo when dragging and dropping text.
    • Fixed a crash when accessing edge://policy.
    • Fixed a hang when using Read Aloud.
Changed behavior:
  • Fixed an issue where Spellcheck sometimes doesn’t work.
  • Fixed an issue on Mac where the window control buttons aren’t available after exiting fullscreen.
  • Fixed an issue where the Pin To Taskbar option for websites installed as apps and PWAs sometimes doesn’t work.
  • Fixed an issue where uninstalling websites installed as apps sometimes doesn’t properly uninstall them on other machines when App syncing is enabled.
  • Fixed an issue where the dialog to add a new profile sometimes doesn’t open when clicking the button to open it.
  • Fixed an issue where the Travel recommendation popup sometimes appears blank.
  • Fixed an issue where certain browsing data is sometimes unintentionally deleted when other browsing data is intentionally deleted.
  • Fixed an issue where tabs sometimes enter IE mode unexpectedly.
  • Fixed an issue where the IME popup is sometimes placed incorrectly.
  • Mobile:
    • Fixed an issue where tabs sometimes can’t be selected in the Tab Center.
    • Fixed an issue where Read Aloud sometimes fails when online voices can’t be used instead of falling back to offline voices.
    • Fixed an issue where Read Aloud doesn’t start if there’s no network connection.
    • Fixed an issue where certain Collection items sometimes are unintentionally deleted when other items are intentionally deleted.
    • Fixed an issue on Android where the Search widget doesn’t work.
    • Fixed an issue where feedback can’t be sent.
    • Fixed an issue where Top Sites sometimes can’t be manually added.
    • Fixed an issue where the option to share a tab sometimes isn’t available.
    • Fixed an issue where updating a password sometimes changes the wrong password.
  • Developer:
    • Fixed a WebView2 issue where apps created using certain SDKs report 0 for both MouseEvent movement properties (Issue 2220).
    • Fixed an issue in WebView2 apps where popups like permission prompts and context menus sometimes don’t appear.
Dev channel update to 101.0.1210.1 is live
Added features:
  • Added support for viewing PDFs in fullscreen.
  • Enabled by default the Performance hub and its Efficiency Mode.
  • Enabled by default the in-browser assistance search box.
  • Enterprise:
    • Added functionality to Application Guard to make network isolation policies optional.
    • Added a management policy to control if Edge Spaces are Enabled (formerly known as Workspaces). Note that updates to documentation and administrative templates may not have occurred yet.
    • Added an API to WebView2 to allow apps to automatically change their color scheme to light or dark mode depending on the current OS settings. Note that this API was previously in the “Experimental” status.
    • Added an experimental API to WebView2 to listen to HTTP Status Codes from navigations.
    • Added an Experimental API to WebView2 get favicons and listen for changes to them.
  • Fixed an issue where the browser won’t open.
  • Fixed a crash on launch when certain sidebars are enabled.
  • Fixed a crash when restarting the browser.
  • Fixed a crash when closing a tab.
  • Fixed a crash when closing a window.
  • Fixed a crash when closing a tab while certain popups are open.
  • Fixed a crash when interacting with misspelled words in text boxes.
  • Fixed a crash when viewing edge://crashes.
  • Fixed a crash when searching from the Edge Bar.
  • Fixed a crash when zooming a webpage.
  • Fixed a crash when adding a profile to the browser.
  • Fixed a crash when closing the browser.
  • Fixed a crash when pinning a website to the Taskbar.
  • Fixed a crash on Linux when signing into the browser with a work or school account.
  • Mobile:
    • Fixed a crash when interacting with the password saving dialog.
    • Fixed a crash when interacting with password popups.
    • Fixed a crash on the new tab page.
Changed behavior:
  • Fixed an issue where Netflix is slow or hangs.
  • Fixed an issue where opening multiple Collection items at a time opens them in the wrong order.
  • Fixed an issue where title bar text and icons are pink.
  • Fixed an issue where websites sometimes show up as being blocked even though they’re not.
  • Fixed an issue where the PDF toolbar sometimes doesn’t appear.
  • Fixed an issue where websites sometimes can’t be pinned to the Taskbar.
  • Fixed an issue where a Sidebar button on the toolbar couldn’t be disabled.
  • Fixed an issue where certain Settings pages take a long time to load.
  • Fixed an issue where IE mode tabs sometimes fail to open.
  • Fixed an issue with IE mode cookie syncing where cookies sometimes get out of sync.
  • Fixed an issue where downloading files from IE mode tabs sometimes leaves extra tabs open.
  • Mobile:
    • Fixed an issue on iOS where credit card autofill doesn’t work on some websites.
    • Fixed an issue where the new tab page feed is blank.
    • Fixed an issue on mobile where the setting to make the browser the default browser sometimes doesn’t work.
    • Fixed an issue where Read Aloud sometimes skips or stutters when starting.
    • Fixed an issue where Read Aloud unexpectedly stops.
    • Fixed an issue where downloads sometimes can’t be opened from completion notifications.
    • Fixed an issue on mobile where certain Shopping popups can’t be closed.
    • Disabled screenshots on the New Tab Page on mobile because they aren’t functional.
Dev channel update to 102.0.1217.0 is live. Also see Sleeping tabs in Microsoft Edge: Save even more resources with recent updates.
Added features:
  • Added a button to the toolbar for Web Select.
  • Added a management policy to control if All Http Auth Schemes are Allowed For Origins, which controls the list of origins that allow all HTTP Authentication schemes. Updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash when navigating to certain websites.
  • Fixed a crash when downloading certain items.
  • Fixed a crash when opening popups like the Downloads menu in Guest windows.
  • Fixed a crash on Mac when interacting with Tab Groups.
  • Mobile:
    • Fixed an issue where using InPrivate tabs sometimes crashes the browser.
  • Fixed a crash in WebView2 applications when viewing Office documents.
Changed behavior:
  • Improved autofill when performing travel-related tasks.
  • Fixed an issue where Sleeping Tabs settings are missing on some devices.
  • Fixed an issue where the IE mode site list is erased after updating the browser.
  • Fixed an issue where payment cards can’t be manually added in Settings.
  • Fixed an issue where Spellcheck sometimes can’t be enabled.
  • Fixed an issue where pages sometimes flash red when loading.
  • Fixed an issue where certain borders are pink.
  • Fixed a blank popup.
  • Fixed an issue where autofill popups sometimes suggest the same entry multiple times.
  • Fixed an issue where the option to hide the Smart Explore buttons sometimes doesn’t work.
  • Mobile:
    • Fixed an issue where PDFs can’t be opened.
    • Fixed an issue where editing a Collection sometimes causes images in it to disappear.
    • Fixed an issue where the button to add the current page to favorites is missing.
    • Fixed an issue where passwords sometimes aren’t autofilled.
    • Fixed an issue where the new tab page feed doesn’t work in landscape mode.
  • Fixed an issue with WebView2 apps where zoom levels are sometimes inadvertently reset.
  • Disabled Web Capture in IE mode tabs because it’s not functional.
Dev channel update to 102.0.1220.1 is live
Added features:
  • Added a prompt to pin PWAs after they’ve been installed from the Microsoft Store.
  • Redesigned the Apps management page.
  • Added the ability to import passwords on mobile.
  • Added a management policy to control if the Outlook Hub Menu is Enabled. Note that updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash when using 2-factor authentication to sign into the browser.
  • Fixed a crash on Android.
  • Fixed a crash on Android when using the search widget.
Changed behavior:
  • Fixed an issue where the tab bar sometimes disappears.
  • Fixed an issue where the Setting to use a custom Secure DNS provider doesn’t work.
  • Fixed an issue where the Find bar shows 0 matches even though there are related matches shown on the page.
  • Fixed an issue where the window control buttons are sometimes invisible when certain themes are applied.
  • Fixed an issue where background tabs are sometimes invisible when certain themes are applied.
  • Fixed an issue on mobile where signing into the browser fails.
  • Fixed an issue in WebView2 apps where URL fragments are sometimes inadvertently removed during a navigation redirection.
  • Disabled Kids Mode in Application Guard windows.
Dev channel update to 102.0.1235.1 is live
Added features:
  • Added a link to Tabs From Other Devices in the Tab Actions menu.
  • Enabled support for a management policy from Chromium to control if the javascript engine behavior to Set Timeout Without 1 Ms Clamp is Enabled, which controls if calls to setTimeout() with a 0ms timeout are changed to have a 1ms timeout. Note that updates to documentation and administrative templates may not have occurred yet.
  • Fixed an issue where all tabs crash with an error code: FACILITY_VISUALCPP/ERROR_PROC_NOT_FOUND.
  • Fixed a crash on mobile when sending feedback.
  • Fixed an issue where WebView2 apps crash when setting User Data Folder Access options (Issue 2363).
  • Fixed a crash on Xbox when using Tab Search.
Changed behavior:
  • Improved how many types of tabs can be put to sleep.
  • Reduced the number of tabs that are discarded due to memory pressure in certain situations.
  • Fixed an issue where Tab Search doesn’t work.
  • Fixed an issue where printing and print preview sometimes doesn’t work.
  • Fixed an issue where certain search engines can’t be removed from Settings.
  • Fixed an issue where certain languages aren’t available in Spell Check.
  • Fixed an issue where IE mode sometimes can’t be enabled or configured.
  • Fixed an issue in Application Guard windows where downloads are sometimes blocked when they shouldn’t.
  • Fixed an issue where work/school results don’t appear in the search engine when searching from the address bar.
  • Mobile:
    • Fixed an issue where Top Sites can’t be edited because the edit button is too hard to hit.
    • Fixed an issue where Read Aloud sometimes doesn’t highlight words that it should, or says words that it shouldn’t.
    • Fixed an issue where the Read Aloud controls sometimes don’t appear in the notification shade.
Microsoft Edge Dev Build 102.0.1245.3 has been released. There is no blog post about the update. Via Missy Q (Community Manager for Microsoft Edge Insiders) in Twitter: "We opted to not do anything this go. We're working on getting 102 into Beta."
Dev channel update to 102.0.1245.3 is live has been posted for the update released on Saturday.
Added features:
  • Added support for a custom IE mode list in Settings.
  • Added the ability to add a password directly in Settings.
  • Enabled support for XCloud Clarity Boost by default.
  • Enabled support for a management policy from Chromium to control if the User Agent Client Hints GREASE Update is Enabled, which controls if the updated GREASE specification is used (which could lead to broken websites) or an older version. Note that updates to documentation and administrative templates may not be available yet.
  • Developer (note that updates to documentation and SDKs may not be available yet, and all of the below APIs were previously in the “Experimental” status):
    • Added an API to WebView2 to Clear Browsing Data.
    • Added an API to WebView2 apps to handle Server Certificate Errors.
    • Added an API to WebView2 to monitor HTTP navigation Status Codes.
  • Fixed a crash when sending feedback.
  • Fixed a crash on Mac when syncing.
  • Fixed a crash when viewing certain Settings pages.
  • Developer:
    • Fixed a crash in WebView2 applications when running them elevatged/with admin privileges (Issue 2356).
    • Fixed a crash in WebView2 applications when they change focus (Issue 1552, Issue 1681, Issue 2311).
  • Fixed a crash on mobile when interacting with content on the new tab page.
Changed behavior:
  • Fixed an issue where search engines disappear from Settings.
  • Fixed an issue where exported enterprise site lists don’t contain a version number.
  • Fixed an issue where the browser sometimes can’t be closed while downloading something.
  • Fixed an issue where the Downloads popup sometimes appears in the wrong window when multiple windows are open.
  • Fixed an issue where Enhanced Security mode settings sometimes aren’t visible.
  • Fixed an issue on Mac where the Performance Hub is missing some information.
  • Fixed an issue where searching using Alt+Enter on Windows results in the address bar showing the wrong text on other tabs.
  • Fixed an issue where clicking on notifications in the Windows Action Center sometimes fails.
  • Fixed an issue where Print Preview is blank.
  • Fixed an issue where printing a PDF sometimes doesn’t work correctly.
  • Fixed an issue where text on Extension badges is red.
  • Fixed an issue where the Find on Page popup is red.
  • Fixed an issue where the Picture in Picture controls are red.
  • Fixed an issue where parts of the browser don’t use dark theme in InPrivate windows.
  • Mobile:
    • Fixed an issue where the new tab page sometimes doesn’t scroll properly.
    • Fixed an issue where links opened from Outlook sometimes don’t work.
    • Fixed an issue where adding or editing a Collection sometimes fails.
    • Fixed an issue where certain Read Aloud voices are missing.
    • Fixed an issue where Read Aloud doesn’t work.
Dev channel update to 103.0.1253.0 is live
Added features:
  • Added the ability to pin PWA/websites installed as apps to the taskbar from their … menus.
  • Enabled by default the ability to search in the History popup using natural language (for example, “Youtube from last week”).
  • Added a management policy to set the Internet Explorer mode Zoom Display type, which controls if the browser’s zoom level takes into account the current display scale like IE used to (for example, if display scaling is set to 150%, then IE’s default zoom level would show 150%). Note that updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash when visiting certain websites.
  • Fixed a crash when adding items to Collections.
  • Fixed a crash when switching profiles in the Edge Bar.
  • Fixed a crash in WebView2 applications when adding Status Bar text (Issue 2414).
Changed behavior:
  • Temporarily disabled the search box in the Alerts and Tips popup.
  • Fixed an issue where the browser sometimes doesn’t respond to links clicked from other applications if it’s not already open.
  • Fixed an issue where the browser isn’t brought into the foreground if it’s minimized when clicking on a notification in the Windows Action Center.
  • Fixed an issue where previously-opened tabs are sometimes restored when first opening the browser even though they’re not supposed to be.
  • Fixed an issue where vertical tabs are improperly colored when using custom themes.
  • Fixed an issue where the Find on Page UI is red.
  • Fixed an issue where navigator.mediaCapabilities sometimes doesn’t report proper decodingInfo to websites.
  • Fixed an issue where app or popup windows opened from IE mode tabs don’t automatically resize when they’re supposed to.
  • Fixed an issue in WebView2 apps where the on-screen keyboard sometimes doesn’t appear (Issue 460).
Dev channel update to 103.0.1255.0 is live
Added features:
  • Added features to Support launch some universal links which weren't supported before.
  • Added support features for Presentations and Spreadsheets searches.
  • Added Feature to a group policy for guided switch. This is a mandatory group policy. Once configured, it does not allow user to override this setting on Browser by changing the value of `Automatic Profile Switching’. If the policy is not configured to change the value on settings page.
  • Added feature to trigger for full address fill logic.
  • Added a management policy to control if Guided Switch is Enabled, which controls the prompt to switch to another profile when a website won’t work for the current one.
  • Added a .NET API to WebView2 to support multiple profiles.
  • Improved Reliability of Camera Capture.
  • Improved Behavior so that Once design suggestions appear on the webpage, the entry button/flyout should not disappear if user stays on the page.
  • Improved Reliability by re-enabling and reverting to navigating to the downloads page instead of going to settings.
  • Improved reliability by skipping Mobile variation header hack for requests whose transition type is not new navigation as it doesn’t work for them.
  • Improved reliability for check validity or registry.
  • Improved reliability of Personal Database Manger.
  • Improved behavior on image super resolution feature.
Changed behavior:
  • Changed Behavior so that Visual Search side pane is closed while opening collections.
  • Changed Behavior by re-enabling and reverting to navigating to the downloads page instead of going to settings.
  • Changed behavior of how overflow issues are handled in various text fields in one tap dialog.
  • Changed behavior on settings button in reading mode page being misplaced.
  • Enabled by default vertical tabs in full screen mode.
  • Chanced Efficiency Mode to be enabled whenever a game application is detected to be running.
  • Fixed a crash on mobile when interacting with the address bar.
  • Fixed an issue where the browser is sometimes running in the background when it shouldn’t be.
  • Fixed a crash on mobile when interacting with the new tab page.
  • Fixed a crash on Xbox.
  • Fixed an issue where the tab context menu option to move tabs to other windows only shows the new window option, not any options for any other windows.
  • Fixed an issue on mobile where the image of the day doesn’t load on the new tab page.
  • Fixed an issue where the Extensions menu is blank.
  • Fixed an issue on mobile where the back button sometimes doesn’t work when it should.
Dev channel updates are live for 103.0.1264.2
Added features:
  • Added features to drag the create tab group feature by default.
  • Added features to Polices for Mobile.
  • Added features so that a new language is added to preferred language list, Expanded the spellcheck language so that the state and level of support is advertised.
  • Added features to Make Editor languages be enabled by default when adding new language to accept languages list.
    • Made enhanced spellcheck state coordinated with basic spellcheck state and vice versa. User toggle on/off spellcheck in one should also cause the other to be toggled on/off.
    • Fixed existing broken state where a language can have its basic spellcheck. Turned on but its enhanced spellcheck turned off.
  • Improved reliability by refreshing token for MS Rewards POST.
  • Improved reliability that manages null properly.
  • Improved reliability with new illustrations for defaults screen in Browser.
  • Improved reliability by formatting Edge contributions in the Browser folder.
  • Improved reliability of Microsoft browser process on launch.
  • Improved reliability by enabling feedback prompt.
  • Improved reliability of translator in one Go on Mobile.
  • Improved performance of battery saver icon.
  • Improved reliability by removing redundant resources for pdf viewer and print viewer.
  • Improved reliability to update the style and layout to get a good layout state.
  • Improved reliability on Accessibility features.
  • Improved reliability of Mobile smart screens.
  • Improved reliability by fixing interface and updating Mobile.
  • Improved reliability for this MSB flighting feature being turned on by default so that we can rely on service driven experimentation to power our enterprise Edge features through all the channels.
  • Improved policy by only allowing required trusted types in Browser.
  • Improved reliability due to Narrator announcing an intentional white space. The white space was unnecessary, so it has been removed and narrator has stopped announcing it.
  • Improved reliability to Keep spellcheck languages expanded by default when adding new ones so that the state and level of support is advertised.
Changed behavior:
  • Changed behavior fixing multilanguage in Browser by not showing misspelled words for Editor-supported languages.
  • Changed behavior due to multiple things being duplicated by incorrect merge resolutions.
  • Changed Browser tasks shutdown behavior.
  • Changed behavior by sending images info in JPG format to Web Bing.
  • Changed behavior to move alerts & tips to "help & feedback.
  • Changed behavior by changing reconciles with an upstream change because there is no longer any need to call a V8 API to enable the desired functionality.
  • Changed behavior in Mobile by adding/correcting triggers and tags for writing assistant feature experiment.
Dev channel update to 104.0.1271.2 is now live!
Added features: 
  • Added a group policy that allows enterprises to restrict the max length of username/password values added to the Edge Password Manager.
  • iOS: Added a delete button for individual apps on the block external app list.
  • Improved features in SharePoint for translation.
  • Improved features with the ability to select the download location and the interface to continue to display the selection dialog or not, to prevent it from not being displayed next time after a wrong touch.
  • Improved cache performance for profile pictures in Mobile.
  • Improved strings for sidebar search text when reading with a screen reader to find the area more clearly.
  • Improved web select/web capture keyboard controls with multiple displays.
Changed behavior: 
  • Fixed an issue where the search bar in the Downloads hub would lose focus when typing.
  • Fixed a crash when using the Send Tab feature.
  • Changed behavior of disposable email on select for passwords and invoked autosave flow on submission. We also updated priority to autosave on consent.
  • Fixed high memory usage from WebResourceRequested events – GitHub Issue#2171
  • Activated the browser/host app in windowed or visual hosting mode when closing the find on page bar.
  • Fixed a crash when using Read Aloud online.
  • Mobile
    • Fixed a crash on AAD (Azure Active Directory) sign in.
Dev channel update to 104.0.1278.2 is now live!
This week we invite you to take our feedback survey. This is anonymous and may take about 15-20 minutes to complete, but it will help us understand your likes and dislikes about various feedback platforms and your thoughts on the engagement opportunities with your feedback. We are looking for more details from users like yourselves who let us know in the February 2022 survey that improvements to feedback communications are needed, and this will help us determine what changes exactly you would like to see.
Added features: 
  • Added support for displaying the correct channel-specific Edge icon in the Search and Spotlight UI for macOS.
  • Improved the width of the text content display box in reading mode on tablets. 
Changed behavior: 
  • iOS: Improved performance on Citrix. 
Dev channel update to 104.0.1287.1 is now live!
Added features: 
  • Added a display notification when Microsoft Rewards points increase. 
  • Added an option to provide translation information with feedback for Android.
  • Added a new policy to manage mini menu settings.
  • Improved various UX issues seen while searching on the Edge Bar.
  • Improved reliability for importing favorites from an html file.
  • Improved the displayed icon on InPrivate browsing page on mobile.
  • Improved grammar suggestions by adding a header in the submenu.
  • Enabled the ability to return to the new tab page news feed after opening an article by pressing the back button.
Changed behavior: 
  • Improved accessibility for screen readers by changing the narrator announcement from "item, selected" to "item, checked/unchecked" after invoking a checkbox menu item. 
  • Fixed a crash when selecting an option on the permissions notification on mobile. 
  • Improved discoverability of restored bookmarks, instead of putting them into the Other Favorites they now go into a folder called Restored Favorites
Dev channel update to 104.0.1293.1 is now live!
Added features:  
  • Mobile: Improved the loading time of Read Aloud 
  • Improved browser so that changing between light or dark theme is smoother
  • Improved the logic for image enhancement.
Changed behavior:  
  • Mobile:
    • Fixed the false upgrade alert under Settings > About Microsoft Edge
    • Read Aloud button will now only show for websites that have the feature enabled
  • Updated speech settings on reader mode for Android
Dev channel update to 105.0.1300.0 is now live!
The update includes improvements to old features, improved reliability, and changed the behavior of more things this week.   The latest content from the team:
Added features:  
  • Added a button in the PDF toolbar to share documents. 
  • Added new policies by improving trending searches in Microsoft Edge 
  • Improved efficiency mode strings and its feature settings
  • Improved the phrasing in the sleeping tabs policy to be clearer when it is off/on.
  • Improved keyboard UX on Android
  • Improved the Print dialog’s Options announcements for screen readers.
  • Improved Android to remove the mask of the entire article after starting Read aloud and now use assorted color schemes for highlights under different themes 
  • Improved trending searches in Microsoft Edge 
Changed behavior:  
  • Fixed an animation error on the mobile sync settings page 
  • Fixed an issue when clicking on the search box above top sites on mobile. 
Dev channel update to 105.0.1321.0 is now live!
 Added features:  
  • Added language region information to the offline voices for iOS 
  • Added the “x” close button to the Share pane 
  • Added in a notification when users try to Share a PDF larger than 25MB 
  • Added a tooltip for MicroFeedback (thumbs up/thumbs down icons) in settings 
  • Improved Edge Cloud Control Platform for Android and iOS 
  • Improvements for Android Read aloud 
  • Improved tooltips on the mini menu
  • Improved Designer hub behavior to properly open and close on macOS 
  • Improved the tabs' view for iOS 
  • Improved accessibility by adding announcements for the translate and cancel buttons on translate pane in Immersive Reader for mobile 
  • Improved drag/drop functionality 
  • Improved features for Autofill 
  • Ensured YouTube will load when clicking on the Windows notification
 Changed behavior:  
  • Fixed iOS app popup menu 
  • Fixed issue where icon styling was making doc icons appear as circles 
  • Changed the behavior when closing out of a text-note window on PDFs to focus back on the note highlight 
  • Optimized mobile notification requests 
  • Fixed a visual issue where the optional diagnostics box did not appear unchecked on Android  
  • Completed changes for the Digital Signature icon on toolbar for Microsoft Browser 
  • Fixed saved passwords from re-organizing after searching for a password on iOS 
  • Fixed the issue were clicking on Windows notifications from a website does not open that website
  • Fixed an issue were Read Aloud does not start
  • Updated announcement phrase for the InfoBar after updating cookie settings
  • Selecting Customize toolbar from the toolbar’s right-click menu will land users directly on the Customize toolbar section in Settings 
Dev channel update to 105.0.1329.1 is now live!
See Disk caching in Microsoft Edge - Microsoft Edge Blog (windows.com)
Added features:  
  • Added a mute indicator on tabs when the browser is muted in the volume mixer
  • Updated max URL length in the side pane for visual search
  • We added an "always enforce" list to Enhanced Security mode
  • Improved iOS Feedback prompt to notify when connection is blocking the ability to send feedback
 Changed behavior:  
  • Fixed a crash when getting the page count in print preview
  • Fixed the downloads toolbar icon disappearing after a download started and the flyout was closed
  • Fixed the blank space in the Guest mode indicator
  • Fixed a crash on iOS when closing tabs while Read Aloud is active
  • Fixed a crash when restoring tabs from a previously closed window
  • Fixed a crash when adding a Favorites folder on iOS
  • Fixed an issue where Microsoft Reward was not displaying in Settings on mobile
Dev channel update to 105.0.1336.2 is now live!
Added features:  
  • Added Narrator announcing 'banner' on 'Learn more' link in Microsoft Edge 
  • Added support for a management policy from Chromium to control if Unthrottled Nested Timeout is Enabled - this will be deprecated in the future
  • Performance improvements to IMap properties 
  • Improved iOS tooltips 
  • Improved Android shared device support 
  • Optimized read aloud voice options page for Android  
 Changed behavior:  
  • Fixed an issue where the profile popup sometimes is cut off
  • Fixed various crashes 
  • Fixed Diagnostic button layout 
  • Fixed Drag and Drop for Collections
  • Fixed a crash when clicking the Tab Actions Menu button  
Dev channel update to 106.0.1349.1 is now live!
Added features: 
  • Added new policies from upstream and corresponding downstream changes
  • Added History Date Filtering on the full page for History
  • Enabled the Password nickname feature
  • Disabled pinning options in the menu for a specific website, if the website is already pinned to the taskbar
  • Improved smart history searches (e.g.: “videos from last week”)
  • Improved camera feature for websites on Android
Changed behavior: 
  • Fixed an issue where certain address bar instant answers were unnecessarily truncated
  • Fixed Narrator announcements in Settings
  • Updated a Policy, so when signed into Microsoft Edge with a work or school account (AAD), feedback is associated with account and organization
  • Fixed an issue where feedback cannot be sent from within the side pane
  • Fixed an error when attempting to generate a QR code on Android
  • Fixed a crash when changing profiles on iOS
Also of interest is A better printing experience for Azure Virtual Desktop with Universal Print.
