[SOLVED] Missing Cat and Mum files
mclovis
Contributor
I have been having issues with windows update and SURT reports issues. Can anyone help?
Attached is log
Hi and welcome to Sysnative. Your machine appears to be missing (or have corrupt) updates from 122 different windows updates. What other issues have you been having with your machine besides Windows Updates not working?
That is the only one, there were some issues, but I backup my system using Acronis. This started when I allowed windows to clean up the system and it apparently deleted updates that had been previously applied. The inability to do a Windows Update started soon after. Thanks, Thanks, Thanks for the help.
As additional information, when I tried to install the latest Windows 64 bit Pro security update (rollup). This is the error code "WindowsUpdate_80073701" "WindowsUpdate_dt000"
Yup, that likely caused it.
Please attempt to install an update and when it fails please zip up and attach your c:\windows\logs\CBS.log
Thanks.
Per reliability..
Installation Failure: Windows failed to install the following update with error 0x80073701: January, 2017 Security Monthly Quality Rollup for Windows 7 for x64-based Systems (KB3212646).
Please do the following.
Remove Update Manually
1. Click on the Start
wusa /uninstall /KB:2994023
Repeat the same for the following and let me know the results.
wusa /uninstall /KB:3185330
wusa /uninstall /KB:2984976
wusa /uninstall /KB:3048070
wusa /uninstall /KB:3197868
caused an error "Installer encountered an error 0x80070490 Element not found
Same error is encountered for all wusa commands listed
Attached is the "popup" when running the wusa command(s) such as wusa /? or wusa /log, etc.
OK, please start with the following.
Step#1 - SFCFix Script
Please do the following again.
Thanks, I will. As an FYI, it needed to run overnight to "succeed", but UI did not show any error messages. I will try again.
OK, I see the error and would like to try a few things.
2017-02-07 18:57:28, Info                  CBS    Failed to resolve item[0] in Package: Package_67_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5, Update: 3197868-167_neutral_LDR [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
Start with the following again but only for the one update listed.
