Need help updating from Windows 8.1 -> 10
jj426
Active member
I get the Modern Setup Host error every time I try.
The different tests I have tried:
SFC Scan - no integrity violations found
SURT/DISM Scan - nothing found
CBS Files located here.
SFC Fix:
Start time: 2020-12-22 00:38:34.239
Finish time: 2020-12-22 00:41:22.303
Hi!
I saw someone solved this after a reset to the default settings of MS internet Explorer, deleting also personal preferences and settings.
If this won't work, wait for a Windows update analyst.
Sysnative log collector is here.
Other logs links for are here:
C:\$WINDOWS.~BT\Sources\Panther\mndFE6F.diagerr.mdmp
C:\$Windows.~bt\sources\panther
C:\$Windows.~bt\Sources\Rollback
C:\Windows\inf\setupapi.dev.log
FRST Scan:
  2. Right-click to run the tool as administrator. When the tool opens click Yes to disclaimer.
  3. Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  4. Press the Scan button.
  5. Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  6. Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
Hi PeterJ,
Thank you for your response. Attached are the two files returned from the scan.
Thanks
Clarification on the BSOD instances - once it was because I overclocked and another time because I was stress testing.
Uninstall Driver Booster 7
Reboot the machine.
Start "Malwarebytes", click on "Dashboard" and next on the button "Scan Now".
If updates are available these will be downloaded first, then the scan will start.
The scan can take some time so please be patient.
When finished do not let Malwarebytes remove them yet.
Click Reports in Malwarebytes.
Put a checkmark at the latest scanreport, click View report, click Export en select Text File (*.txt).
Enter a filename and save it on your desktop.
Attach this text file to your next reply.
  3. Press the Fix button.
Try the upgrade again and report the result.
Unhandled exception at 0x00007FFD0DEDE611 (appraiser.dll) in SetupHost.exe: 0xC0000005: Access violation reading location 0x0000000000000000.
Check Windows Update only.
Post a screenshot of the available updates.
