NO SOUND !!! SFC.DLL is either not designed to run ....
thank you so much, sound is back, can you tell me what is the cause of my problem ? is it my hard disk drive ? is it my Windows ?
Hello samijuana,
That's good to hear that the sound is back :)
All the other files got repaired Successfully, but now more files are showing as corrupt.
\SystemRoot\WinSxS\amd64_microsoft-windows-ndis.resources_31bf3856ad364e35_6.1.7600.16385_en-us_d20f87d50d629c6e\ndis.sys.mui
\SystemRoot\WinSxS\x86_microsoft-windows-e..extension.resources_31bf3856ad364e35_6.1.7600.16385_en-us_b7964020f4f12676\EhStorShell.dll.mui
Once SFCFix has finished can you please run SFC /SCANNOW again then upload the CBS folder?
SFCFIX
 SFCFix version 2.3.0.0 by niemiro.
Start time: 2014-08-01 12:42:05.531
Using .zip script file at C:\Users\Nadia\Desktop\SFCFix31162745.zip [0]
Not using an additional text script file.
Success: File Placement Mode successfully identified and repaired all files and folders.
SFCFix version 2.3.0.0 by niemiro has completed.
Currently storing 8 datablocks.
Finish time: 2014-08-01 12:42:05.843
Script hash: qFmsEQJj1hIpFH6pRbcmRnbJesSRo2miKkr4EiQIW9w=
Hey samijuana,
Can you please delete your current version of SFCFix and and SFC.ZIP files. The above didn't work the way the way it was supposed to.
There might have been an issue with the download as the script hash that was used:
Is different to the one it supposed to be
Ibc6wk0qwBiqi6NEZDKdK7dd/6nTvuW7Q5E3NnmRCq4=
your zip file is not named "SFCFIX.ZIP" it's "SFCFix31162745.zip"
but anyway i did as you said
SFCFIX
Start time: 2014-08-04 09:50:59.593
Finish time: 2014-08-04 09:50:59.951
Script hash: WTr42fFnl58TYhR2nSIH2+vXQr6rmmf/lYKIfxYkwsk=
Hello samijuana
It looks like SFCFix is not ready the txt file that is inside the zip file SFCFix31162745.zip -> Can you please open up this ZIP file and confirm there is a file called SFCFix.txt?
Thanks
Please try this
i couldnt check the sfcfix.txt because the zip file gives me an error when i want to open it like the file is damaged or corrupt
SFCFIX
Start time: 2014-08-05 07:36:50.514
Using .zip script file at C:\Users\Nadia\Desktop\SFCFix.zip [0]
Finish time: 2014-08-05 07:36:50.767
Script hash: IxrCJzqxxdhifLyZtszXiZBj2tYQVff0nGfDfvJNQDs=
