Ongoing DPC latency problem
I'd say to reinstall everything but Hitman pro and verify again another day.
Then the final test is to reinstall Hitman pro and confirm it's the culprit.
Later, inform its developers about this problem so they can solve it.
About latencymon: if you don't have the problem anymore, you can ignore and uninstall it.
No sorry, not yet. I haven't had the time to do any photo-editing. Hopefully I can do sokme editing this weekend.
regards,
Erik
Too bad. Although it looed promising after uninstalling Hitma the Nvidia driver keeps spiking and video and audi is still being interupted (although the interuption is for a brief moment and not as long as it was before)
Download:
- Intel® Network Adapter Driver for Windows® 10.
- X570 AORUS ELITE (rev. 1.0) (intel) LAN driver (to use it just in case the previous one shouldn't work).
Launch this command from an elevated command prompt (command prompt (admin):
dism /online /get-drivers /format:table | findstr /i /c:"intel"
I get (I used "amd" as an example):
Remove all intel drivers with:
pnputil /delete-driver oem-NUMBER.inf /uninstall /force
Then install the downloaded intel driver.
I am very sorry for my late response, but I haven't been able to work on this lately. I have launched the commands and got the overview of drivers. When launching the command to remove all Intel drivers however I got the message
Driver package uninstalled.
Failed to delete driver package: The specified file is not an installed OEM INF file.
Regards,
Erik
Shame on me, I typed a hyphen between oem and the number. Now I got this message again on one driver. All other six drivers were removed. I installed the downloaded Intel driver and now only one Intel driver shows up. I will test for latency this weekend and will post the results.
regards,
Erik
