Sysnative Windows Update
Inactive
- Oct 9, 2014
- 741
Export Component Based Servicing
Once done please upload ComponentBasedServicing.zip via DropBox OneDrive or SendSpace
- Download SFCFix.exe (by niemiro) and save this to your Desktop.
- Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip.
- Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a file should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
- Click on the Start button and in the search box, type regedit
- When you see regedit on the list, right-click on it and select Run as administrator
- When regedit opens, using the left pane, navigate to the following registry key and select it by clicking on it once.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\
- Once selected, click File > Export....
- Change the Save as type: to Registry Hive Files (*.*)
- Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
- Right Click on the ComponentBasedServicing file on your Desktop and choose Send To -> Compressed (Zipped) Folder.
