Problems with update W10 22H2 KB5049981 error 0x80073701
Please provide a new copy of the Components Based Servicing hive
Export CBS (Component Based Servicing) hive
  • Click on the Start button and type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
Please export the Components Based Servicing key as hive file not *.reg, see the red arrow in my previous post...
Please follow the instructions below, don't export the registry as *.reg but as *.HIV file.
Follow these instructions to remove an update.
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:5041580
  • Let me know if it says it was successful or you get the message: The update KB5041580 is not installed on this computer.
1. Start the
Command Prompt as administrator.
  • Open the startmenu and type the command cmd.
  • After you find the Command Prompt, right click on it and select Run as Administrator.
  • Copy and paste the following into the Command Prompt and press enter.
2.Right-click on the file
FRST.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Registry button.
KB5041580
  • When the scan is complete, a message will display that SearchReg.txt is saved in the same folder FRST was started from.
  • Post the logfile SearchReg.txt as attachment in your next reply.
Start the
  • Press the Fix button.
Afterwards attempt to update. If it fails attach a new copy of the CBS logs.
