GZ
Visiting Expert
You're going to need a few 4GB dvds to make the image backup.
Do you have an external HDD with some space available?
Get entire chkdsk results from the Event Viewer Application log -
START | type eventvwr.msc | Windows Logs | Application
Log Name: Application
Source: Microsoft-Windows-Wininit
Date: 9/13/2012 7:18:58 PM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: Chris-HP
Description:
Checking file system on C:
CHKDSK is verifying files (stage 1 of 5)...
149760 file records processed.
File verification completed.
163 large file records processed.
0 bad file records processed.
0 EA records processed.
62 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 5)...
202326 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 5)...
149760 file SDs/SIDs processed.
Cleaning up 665 unused index entries from index $SII of file 0x9.
Cleaning up 665 unused index entries from index $SDH of file 0x9.
Cleaning up 665 unused security descriptors.
26284 data files processed.
35373824 USN bytes processed.
CHKDSK is verifying file data (stage 4 of 5)...
Read failure with status 0xc0000185 at offset 0x23d77cc000 for 0x10000 bytes.
Read failure with status 0xc0000185 at offset 0x23d77d6000 for 0x1000 bytes.
Windows replaced bad clusters in file 83014
of name \Windows\MICROS~1.NET\assembly\GAC_64\System.Data\V40_40~1.0__\SYSTEM~1.DLL.
149744 files processed.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
60749214 free clusters processed.
Free space verification is complete.
Adding 1 bad clusters to the Bad Clusters File.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
292773887 KB total disk space.
49457048 KB in 94537 files.
59984 KB in 26285 indexes.
4 KB in bad sectors.
259991 KB in use by the system.
242996860 KB available on disk.
73193471 total allocation units on disk.
60749215 allocation units available on disk.
Internal Info:
00 49 02 00 02 d8 01 00 35 72 03 00 00 00 00 00 .I......5r......
9e 0d 00 00 3e 00 00 00 00 00 00 00 00 00 00 00 ....>...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Event Xml:
<Event xmlns="[URL]http://schemas.microsoft.com/win/2004/08/events/event[/URL]">
<System>
<Provider Name="Microsoft-Windows-Wininit" Guid="{206f6dea-d3c5-4d10-bc72-989f03c8b84b}" EventSourceName="Wininit" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-09-14T02:18:58.000000000Z" />
<EventRecordID>17474</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Chris-HP</Computer>
<Security />
</System>
<EventData>
<Data>
Internal Info:
</Data>
</EventData>
</Event>
Yes... Please do as jc asks...
Usually, when you start getting bad clusters it is a sign the drive is nearing failure... I would like to have you run some Hardware tests on the HDD, but it would be best if you had a recoverable backup of the OS first...
At this point, I cannot say what the true condition of the HDD is.
Code:292773887 KB total disk space. 49457048 KB in 94537 files. 59984 KB in 26285 indexes. [COLOR=#ff0000]4 KB in bad sectors.[/COLOR] 259991 KB in use by the system. 65536 KB occupied by the log file. 242996860 KB available on disk. 4096 bytes in each allocation unit. 73193471 total allocation units on disk.
Okay... Here is the fun part. Do you have any blank CDs?
HDD should be replaced.
Regards. . .
jcgriff2
GZ is the hardware expert here; however the 0xc0000185 exceptions. . . are troublesome to me.
Regards. . .
jcgriff2
This is crazy, this is the third HDD going bad from the same household!
I don't know what to think about it.
At this point the exceptions are Greek to me. Need to do some research to understand what exactly is going on for future reference.
0xC0000185
STATUS_IO_DEVICE_ERROR
The I/O device reported an I/O error.
