random BSODs new parts
If you get errors in memtest, most likely problem is bad memory? You can try one stick to locate the bad module or just replace the ram...most of it has lifetime warrenty if its a name brand.
Ok i cleared CMOS and ran memtest on both sticks on different slots - again errors after 10 minutes. After that i ran memetest on one stick - 12 passes and no erros. Gonna test other one today. How is it possible that first time when i ran memtest i got 8 passes and no errorss, and now i get them in first pass ?
Qalix,
Dirty slots maybe??? Pretty unlikely...
I have seem memtest error at random before...sometimes memory doesn't fail like you think it would...otherwise one pass would be enough. I have also seen two sticks test fine separate, but always error when tested together....If it were me, and the slots were already cleaned (as well as the memory contacts), I would just replace it all...memory is cheap!
I tested the other stick - 13 passes and no erros. So i guess they only give errrors when theyre together? I remember that I did run my PC with both sticks but in single channel, and then my PC was still crashing.
If you get errors with both sticks together it means they're having issues running in dual channel configuration, most likely. Is the RAM compatible and of the same kit, or are they of different kits and it mixed RAM? Have you tried setting the RAM when together at Auto via the BIOS? If so, try manually setting the timings and voltages.
Regards,
Patrick
So when you test the memory one at a time, they both passes. But when you have both sticks installed, Memtest gives errors?
Regards,
Patrick
What do you have the voltage set to for the sticks default of 1.5v or the 1.65v the sticks(at least the ones in your link) are rated for?
Just had bsod on one stick :/ So I got no idea - is it still ddr ? 13 passes no errors on single stick.
Hi -
Bugcheck was 0x4e (0x99,,,) = corrupted page frame number or table entry
Process listed at the time = dota.exe
0x4e points to RAM or other unknown hardware failure affecting RAMs inability to properly hold kernel code
Did you run memtest86+ on each RAM stick and alternate the slots?
Although this dump does appear hardware related, have you run Driver Verifier?
https://www.sysnative.com/forums/bs...river-verifier-blue-screen-death-related.html
Regards. . .
jcgriff2
Opened log file 'C:\Users\PalmDesert\SysnativeBSODApps\_99-dbug.txt'
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Loading Dump File [C:\Users\PalmDesert\SysnativeBSODApps\091513-6661-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02e66000 PsLoadedModuleList = 0xfffff800`030a9670
Debug session time: Sun Sep 15 14:42:26.813 2013 (UTC - 4:00)
System Uptime: 0 days 2:34:54.202
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 4E, {99, 53986, 2, 83005}
Probably caused by : memory_corruption ( nt!MiBadShareCount+4c )
Followup: MachineOwner
2: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;!peb;!sysinfo cpuinfo;!sysinfo machineid; !sysinfo cpuspeed; !sysinfo smbios .logclose;q
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc).  If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000053986, page frame number
Arg3: 0000000000000002, current page state
Arg4: 0000000000083005, 0
Debugging Details:
BUGCHECK_STR:  0x4E_99
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  dota.exe
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002f6aa0c to fffff80002edbc00
STACK_TEXT:
fffff880`0a247088 fffff800`02f6aa0c : 00000000`0000004e 00000000`00000099 00000000`00053986 00000000`00000002 : nt!KeBugCheckEx
fffff880`0a247090 fffff800`02e881e6 : 00000000`00000000 fffffa80`0224c580 0000000f`ffffffff fffff800`02ef524e : nt!MiBadShareCount+0x4c
fffff880`0a2470d0 fffff800`02ed09a1 : 80a00000`00000000 fffff680`00329da8 00000000`00000200 000fffff`00000001 : nt! ?? ::FNODOBFM::`string'+0x32731
fffff880`0a247150 fffff800`02ec8162 : fffffa80`05cc2040 fffff880`00000000 fffffa80`03cb22d0 fffffa80`03cb2668 : nt!MiDecommitPages+0x1a1
fffff880`0a2479e0 fffff800`02edae93 : ffffffff`ffffffff 00000000`37cde610 00000000`37cde608 00000000`00004000 : nt!NtFreeVirtualMemory+0x382
fffff880`0a247ae0 00000000`77ae14fa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`37cde5d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77ae14fa
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02f6aa0c cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiBadShareCount+4c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  5147d9c6
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x4E_99_nt!MiBadShareCount+4c
rax=0000000000083005 rbx=fffffa8000fac920 rcx=000000000000004e
rdx=0000000000000099 rsi=fffffa8002228640 rdi=0000000000000000
rip=fffff80002edbc00 rsp=fffff8800a247088 rbp=00000000653a500f
 r8=0000000000053986  r9=0000000000000002 r10=0000000000000002
r11=0000058000000000 r12=0000000000053986 r13=fffff68000329d28
r14=fffffa8003cb22d0 r15=fffff68000000000
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00000202
nt!KeBugCheckEx:
fffff800`02edbc00 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:fffff880`0a247090=4e00000000000000
Child-SP          RetAddr           : Args to Child                                                           : Call Site
fffff880`0a247ae0 00000000`77ae14fa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13 (TrapFrame @ fffff880`0a247ae0)
fffff800`00b9e000 fffff800`00ba8000   kdcom    kdcom.dll    Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff800`02e1d000 fffff800`02e66000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff800`02e66000 fffff800`0344c000   nt       ntkrnlmp.exe Mon Mar 18 23:21:42 2013 (5147D9C6)
fffff880`00c2c000 fffff880`00c7b000   mcupdate mcupdate.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`00c7b000 fffff880`00c8f000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00c8f000 fffff880`00ced000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00ced000 fffff880`00dad000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`00dad000 fffff880`00dba000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`00dba000 fffff880`00e00000   dxgmms1  dxgmms1.sys  Tue Apr 09 23:27:15 2013 (5164DC13)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00e33000 fffff880`00e48000   partmgr  partmgr.sys  Sat Mar 17 01:06:09 2012 (4F641BC1)
fffff880`00e48000 fffff880`00e5d000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e5d000 fffff880`00e82000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00e82000 fffff880`00e8d000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e8d000 fffff880`00e9e000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00ea8000 fffff880`00f4c000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f4c000 fffff880`00f5b000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00f5b000 fffff880`00fb2000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`00fb2000 fffff880`00fbb000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fbb000 fffff880`00fc5000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00fc5000 fffff880`00fd2000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00fd2000 fffff880`00fdb000   iusb3hcs iusb3hcs.sys Mon Feb 27 05:58:49 2012 (4F4B61E9)
fffff880`00fdb000 fffff880`00ffd000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`01000000 fffff880`01014000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01014000 fffff880`01051000   MpFilter MpFilter.sys Fri Jun 07 19:01:11 2013 (51B26637)
fffff880`01051000 fffff880`010af000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`010af000 fffff880`010bd000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`010bd000 fffff880`010cd000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`010cd000 fffff880`010d6000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`010dd000 fffff880`01139000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01139000 fffff880`01153000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`01153000 fffff880`0115c000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0115c000 fffff880`01186000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`01186000 fffff880`01191000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`01191000 fffff880`011a1000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`011a1000 fffff880`011ac000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`011ac000 fffff880`011f8000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01207000 fffff880`013a9000   Ntfs     Ntfs.sys     Fri Apr 12 07:54:36 2013 (5167F5FC)
fffff880`013a9000 fffff880`013c4000   ksecdd   ksecdd.sys   Fri Jun 01 22:50:23 2012 (4FC97F6F)
fffff880`013c4000 fffff880`013f4000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`013f4000 fffff880`013fd000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`0143a000 fffff880`01443000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`01443000 fffff880`0144a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0144a000 fffff880`01453000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01454000 fffff880`014c6000   cng      cng.sys      Fri Jun 01 23:25:51 2012 (4FC987BF)
fffff880`014c6000 fffff880`014d7000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`014d7000 fffff880`014e1000   Fs_Rec   Fs_Rec.sys   Wed Feb 29 22:41:06 2012 (4F4EEFD2)
fffff880`014e1000 fffff880`015d4000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`015d4000 fffff880`015fe000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`01600000 fffff880`0163a000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`0163a000 fffff880`0164c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0164c000 fffff880`01655000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`01655000 fffff880`0166b000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0167d000 fffff880`016dd000   NETIO    NETIO.SYS    Wed Aug 22 11:11:28 2012 (5034F6A0)
fffff880`016dd000 fffff880`01707000   ksecpkg  ksecpkg.sys  Fri Jun 01 23:27:11 2012 (4FC9880F)
fffff880`01707000 fffff880`01750000   fwpkclnt fwpkclnt.sys Wed Jan 02 22:06:48 2013 (50E4F5C8)
fffff880`01750000 fffff880`01760000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`01760000 fffff880`017ac000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`017ac000 fffff880`017b4000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`017b4000 fffff880`017ca000   RzFilter RzFilter.sys Wed Jul 31 05:51:22 2013 (51F8DE1A)
fffff880`017ca000 fffff880`017d2080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01800000 fffff880`01a00000   tcpip    tcpip.sys    Tue May 07 23:16:17 2013 (5189C381)
fffff880`02c00000 fffff880`02c0f000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`02c36000 fffff880`02cbf000   afd      afd.sys      Tue Dec 27 22:59:20 2011 (4EFA9418)
fffff880`02cbf000 fffff880`02d04000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`02d04000 fffff880`02d0d000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d0d000 fffff880`02d33000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`02d33000 fffff880`02d42000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d42000 fffff880`02d5f000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`02d5f000 fffff880`02d7a000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`02d7a000 fffff880`02d8e000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff880`02d8e000 fffff880`02ddf000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`02ddf000 fffff880`02deb000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff880`02deb000 fffff880`02df6000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`03a00000 fffff880`03af4000   dxgkrnl  dxgkrnl.sys  Tue Apr 09 23:28:09 2013 (5164DC49)
fffff880`03afb000 fffff880`03b7e000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`03b7e000 fffff880`03b9c000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`03b9c000 fffff880`03bad000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03bad000 fffff880`03bd3000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`03bd3000 fffff880`03bf0900   RzDxgk   RzDxgk.sys   Wed Jul 31 05:51:24 2013 (51F8DE1C)
fffff880`04000000 fffff880`04024000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`04024000 fffff880`04053000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04053000 fffff880`0405e000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`04063000 fffff880`0457a6e0   igdkmd64 igdkmd64.sys Thu Sep 13 23:30:58 2012 (5052A4F2)
fffff880`0457b000 fffff880`045e4000   asmtxhci asmtxhci.sys Thu Nov 08 12:36:21 2012 (509BED95)
fffff880`045e4000 fffff880`045fa000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04800000 fffff880`04843000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`04843000 fffff880`04855000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`0487f000 fffff880`05364000   nvlddmkm nvlddmkm.sys Fri Jun 21 05:06:16 2013 (51C41788)
fffff880`05364000 fffff880`05388000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`05388000 fffff880`053a3000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`053a3000 fffff880`053c4000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`053c4000 fffff880`053de000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`053de000 fffff880`053ed000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`053ed000 fffff880`053fc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05600000 fffff880`0566a000   k57nd60a k57nd60a.sys Tue May 10 00:42:30 2011 (4DC8C236)
fffff880`0566a000 fffff880`05676000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`05676000 fffff880`0567f000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0567f000 fffff880`05695000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`05695000 fffff880`056a5000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`056af000 fffff880`05773000   iusb3xhc iusb3xhc.sys Mon Feb 27 05:56:53 2012 (4F4B6175)
fffff880`05773000 fffff880`05774f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`05775000 fffff880`05788000   HECIx64  HECIx64.sys  Mon Jul 02 18:14:58 2012 (4FF21D62)
fffff880`05788000 fffff880`05799000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05799000 fffff880`057ef000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`057ef000 fffff880`057fb000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`057fb000 fffff880`057fc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`05a00000 fffff880`05a18000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05a2d000 fffff880`05a87000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`05a87000 fffff880`05a9c000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`05a9c000 fffff880`05af8000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`05af8000 fffff880`05b35000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`05b35000 fffff880`05b57000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05b57000 fffff880`05b5c200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`05b5d000 fffff880`05bba000   iusb3hub iusb3hub.sys Mon Feb 27 05:56:50 2012 (4F4B6172)
fffff880`05bba000 fffff880`05bdb000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`05bdb000 fffff880`05bf0000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05c00000 fffff880`05c1d000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`05c1d000 fffff880`05c2b000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05c2b000 fffff880`05c44000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05c44000 fffff880`05c52000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff880`05c52000 fffff880`05c59500   Lachesis Lachesis.sys Fri Oct 16 09:09:12 2009 (4AD87078)
fffff880`05c5a000 fffff880`05c67000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`05c67000 fffff880`05c8a000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05c8e000 fffff880`06111680   RTKVHD64 RTKVHD64.sys Tue Jan 31 05:55:06 2012 (4F27C88A)
fffff880`06112000 fffff880`06120000   MBfilt64 MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
fffff880`06120000 fffff880`06178000   IntcDAud IntcDAud.sys Tue Jun 19 10:40:51 2012 (4FE08F73)
fffff880`06178000 fffff880`0619d000   asmthub3 asmthub3.sys Thu Nov 08 12:36:35 2012 (509BEDA3)
fffff880`0619d000 fffff880`061ab000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`061ab000 fffff880`061b7000   dump_pciidex dump_pciidex.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`061b7000 fffff880`061c2000   dump_msahci dump_msahci.sys Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`061c2000 fffff880`061d5000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`061d5000 fffff880`061e1000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`061e1000 fffff880`061ef000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`061ef000 fffff880`061f9000   mbam     mbam.sys     Thu Feb 28 15:33:07 2013 (512FBF03)
fffff880`06200000 fffff880`06224000   mrxsmb20 mrxsmb20.sys Tue Apr 26 22:39:37 2011 (4DB781E9)
fffff880`0627a000 fffff880`06343000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`06343000 fffff880`06361000   bowser   bowser.sys   Tue Feb 22 23:55:04 2011 (4D649328)
fffff880`06361000 fffff880`06379000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06379000 fffff880`063a6000   mrxsmb   mrxsmb.sys   Tue Apr 26 22:40:38 2011 (4DB78226)
fffff880`063a6000 fffff880`063f4000   mrxsmb10 mrxsmb10.sys Fri Jul 08 22:46:28 2011 (4E17C104)
fffff880`07a03000 fffff880`07aa9000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`07aa9000 fffff880`07ab4000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`07ab4000 fffff880`07ae5000   srvnet   srvnet.sys   Thu Apr 28 23:05:35 2011 (4DBA2AFF)
fffff880`07ae5000 fffff880`07af7000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`07af7000 fffff880`07b60000   srv2     srv2.sys     Thu Apr 28 23:05:46 2011 (4DBA2B0A)
fffff880`07b60000 fffff880`07bf8000   srv      srv.sys      Thu Apr 28 23:06:06 2011 (4DBA2B1E)
fffff880`0a47d000 fffff880`0a488000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`0a488000 fffff880`0a4a3000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`0a4a3000 fffff880`0a4d9000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0a4d9000 fffff880`0a50a000   WUDFRd   WUDFRd.sys   Sat Nov 20 05:43:32 2010 (4CE7A654)
fffff960`000e0000 fffff960`003f7000   win32k   win32k.sys   Tue Jun 04 23:33:59 2013 (51AEB1A7)
fffff960`00550000 fffff960`0055a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff960`00670000 fffff960`00697000   cdd      cdd.dll      Thu Feb 03 06:25:25 2011 (4D4A90A5)
fffff960`00810000 fffff960`00871000   ATMFD    ATMFD.DLL    Sun Dec 16 09:45:03 2012 (50CDDE6F)
Unloaded modules:
fffff880`0a40c000 fffff880`0a47d000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0166b000 fffff880`01679000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`017d3000 fffff880`017df000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`017df000 fffff880`017ea000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`017ea000 fffff880`017fd000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Unloaded modules:
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  0000B000
    Checksum:  00000000
    ImageSize:  00013000
Bugcheck code 0000004E
Arguments 00000000`00000099 00000000`00053986 00000000`00000002 00000000`00083005
PEB at 00000000fffdf000
error 1 InitTypeRead( nt!_PEB at 00000000fffdf000)...
[CPU Information]
~MHz = REG_DWORD 3400
Component Information = REG_BINARY 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Configuration Data = REG_FULL_RESOURCE_DESCRIPTOR ff,ff,ff,ff,ff,ff,ff,ff,0,0,0,0,0,0,0,0
Identifier = REG_SZ Intel64 Family 6 Model 58 Stepping 9
ProcessorNameString = REG_SZ Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Update Signature = REG_BINARY 0,0,0,0,15,0,0,0
Update Status = REG_DWORD 2
VendorIdentifier = REG_SZ GenuineIntel
MSR8B = REG_QWORD 1500000000
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=1483]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = P2.90
BiosReleaseDate = 07/11/2013
SystemManufacturer = To Be Filled By O.E.M.
SystemProductName = To Be Filled By O.E.M.
SystemFamily = To Be Filled By O.E.M.
SystemVersion = To Be Filled By O.E.M.
SystemSKU = To Be Filled By O.E.M.
BaseBoardManufacturer = ASRock
BaseBoardProduct = Z77 Extreme4
BaseBoardVersion =
CPUID:        "Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz"
MaxSpeed:     3400
CurrentSpeed: 3400
dump smbios [-csv | -v | -headers | -devices | -memory | -power | -cpu | -system]
quit:
Hi jcgriff2.
Yes I did run driver verifier before, and fixed all the errors, but i was still getting blue screen. I did run memtest on each stick and had 12 passes with no errors, but when I ran them together they they did throw errors. The last bsod though was on one stick on the same slot where he gave no errors after 12 passes. Should I just order new ddr's and check it this way? All of my friends that could lend my their ram have ddr2.
So it was memory :) I bought new ones month ago and no errors/bsods since then. Thanks everyone for help - love you all <3
