REFERENCE_BY_POINTER WIN 7 HOME
I'm afraid there's a chance the Nvidia GPU might be defective, there's not much that can be done to fix the problem. There are some things you could try, but there are risks involved and they can be expensive with laptops that are older.
If you really want to use the Nvidia GPU, you could have a trained professional reseat the GPU to see if that fixes the problem. They might also be able to replace the Nvidia GPU should that be needed, but the question is if it's replaceable since it's not sold anymore for years.
Another issue is that you can't use recent drivers, because Nvidia stopped supporting this GPU with driver updates before covid.
The best option if you want to continue using this laptop is to accept that the NVidia GPU might be defective, in my opinion it's not worth the cost to have this fixed. Due to the age of Windows 7, the fact it doesn't receive security updates anymore and the age of your laptop that you may likely get more problems down the road, I'd recommend using this as an opportunity to replace the laptop. Fixing hardware related issues with this laptop may become more expensive than replacing the laptop.
1. Today there was a strange incident, how did it happen, check the file attachment
2. Please check the attachment video, is this a problem with the intel or geforce onboard vga? Actually there is another video that was not recorded successfully and until now does not appear
Can you try attaching the file again, I don't see any new attachments
Looks to be a POST error (Power On Self Test) which is a sequence of tests performed before Windows loads to ensure the hardware components necessary for booting are working. In your video I see "fan error has occurred", indicating the laptop won't be able to cool itself.
Are you able to continue booting into Windows or is this a repeating error message you get at each boot?
The fan only turns on during initial boot. after touching the temperature of 80 degrees it does not turn on.
so I remove it and replace it using a 12cm fan
yes can continue booting into Windows
With the new fan how high do the temperatures get, also what fan did you replace with? Do you continue getting the POST error with the new fan?
today the blue screen of death happened again
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1057
Additional information about the problem:
BCCode: 9f
BCP1: 0000000000000003
BCP2: FFFFFA800DDEBA10
BCP3: FFFFF80004C06428
BCP4: FFFFFA80115CBD20
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\063024-15054-01.dmp
I finish remove the NVIDIA display drivers with DDU
before downloading DDU suddenly the blue screen of death occurs again. I wasn't there at the time so I couldn't take a photo of the error code on the screen
Problem signature:
Locale ID: 1057
BCCode: 9f
BCP2: FFFFFA800DDE4A10
BCP3: FFFFF80004BFC428
BCP4: FFFFFA80109277D0
Service Pack: 1_0
Product: 768_1
can you check my SysnativeFileCollectionApp in Jun 23, 2024, why NVIDIA can aappear?
It's better to not install it at all if the GPU is not detected with presumably hardware defect.
