SFC and DISM Not Working on Server 2012 R2
arremondo
Contributor
I am having difficulty running SFC /scannow and the DSIM utility. DISM gives an error "1812 An initialization error occurred" and SFC Gives the error "Windows Resurce Protection could not start the repair service." I have tried all the "fixes" I found through a Google search and nothing worked. I think i narrowed it down to the error "DISM OS Provider: PID=6224 TID=7000 Failed trying to determine the OS Version" from the DISM log and it further relates to the folder "amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19991_none_fa0fb7959b4c8c91" in the C:\Windows\WinSXS folder and the accompanying registry entry. I tried running both SFCfix and the ComponentsScanner. They both completed without making any changes. I have attached the ComponentsScanner.txt file and the zip of the CBS folder to this thread.
I accidentally posted this in the Windows update thread but I don't know how to move it so I just recreated this one. I really need some help on this.
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to Gofile or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply.
  • Download
The content is below:
__________________________
Start time: 2024-03-25 15:41:48.816
Microsoft Windows Server 2012 R2 Update 3 - amd64
Using .txt script file at \\DC2\Users\ITNSPro\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19991_none_fa0fb7959b4c8c91.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19991_none_fa0fb7959b4c8c91.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19991_none_fa0fb7959b4c8c91.
Finish time: 2024-03-25 15:44:27.947
Script hash: lH72XRrBOvc60mmDnV9sB0jvE1XjTvldcqDnFwsOP3g=
SFC still didn't work, same error.
Copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
Restart the machine.
  • Run the tool
    ComponentsScanner again.
  • Once complete, a report will be saved to your desktop called ComponentsScanner.txt.
Restart the computer.
Run the command SFC /SCANNOW in an elevated command prompt and report the result.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
SFC and DISM both tried to run this time but ultimately both failed. The logs are attached.
  • CBS.zip
    CBS.zip
Something odd happens. The previous log file cbs.log ended on March 25, 2024.
The latest log file cbs.log ended on March 19, 2024 !?
Did you change the system date ?
Is the system date and time correct ?
Run the command SFC /SCANNOW in an elevated command prompt only and report the result. Do NOT run any other tool, like DISM.
My post got deleted for some reason. On the 28th I reported the following:
SFC failed again with an error, "Windows Resource Protection found corrupt files but was unable to fix some of them."
Start time: 2024-03-31 09:31:17.534
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb.
Currently storing 33 datablocks.
Finish time: 2024-03-31 09:31:17.957
Script hash: Lf1xkq3T+QMMMIr9hDIWo4DKj4GWcC+REqZpQmt+5aE=
See attached CBS log.
FRST Search
  3. Select the Programs group.
  5. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Right-click on the file FRST64.exe and choose Run as administrator.
  7. Copy and paste SearchAll:amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb into the Search box and click the Search Files button.
  8. When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'Search.txt' to your next reply.
The SFCFix.txt text is below and the search.txt is attached:
-----------------Start------------------
Start time: 2024-04-02 21:02:52.608
Using .zip script file at \\DC2\Users\ITNSPro\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\servicing\packages
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB4597253~31bf3856ad364e35~amd64~~6.3.1.3377.cat to C:\Windows\servicing\packages\Package_for_KB4597253~31bf3856ad364e35~amd64~~6.3.1.3377.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB4597253~31bf3856ad364e35~amd64~~6.3.1.3377.mum to C:\Windows\servicing\packages\Package_for_KB4597253~31bf3856ad364e35~amd64~~6.3.1.3377.mum.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB4601058~31bf3856ad364e35~amd64~~6.3.1.3396.cat to C:\Windows\servicing\packages\Package_for_KB4601058~31bf3856ad364e35~amd64~~6.3.1.3396.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB4601058~31bf3856ad364e35~amd64~~6.3.1.3396.mum to C:\Windows\servicing\packages\Package_for_KB4601058~31bf3856ad364e35~amd64~~6.3.1.3396.mum.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5001845~31bf3856ad364e35~amd64~~6.3.1.3415.cat to C:\Windows\servicing\packages\Package_for_KB5001845~31bf3856ad364e35~amd64~~6.3.1.3415.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5001845~31bf3856ad364e35~amd64~~6.3.1.3415.mum to C:\Windows\servicing\packages\Package_for_KB5001845~31bf3856ad364e35~amd64~~6.3.1.3415.mum.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5003545~31bf3856ad364e35~amd64~~6.3.1.3445.cat to C:\Windows\servicing\packages\Package_for_KB5003545~31bf3856ad364e35~amd64~~6.3.1.3445.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5003545~31bf3856ad364e35~amd64~~6.3.1.3445.mum to C:\Windows\servicing\packages\Package_for_KB5003545~31bf3856ad364e35~amd64~~6.3.1.3445.mum.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5004118~31bf3856ad364e35~amd64~~6.3.1.3460.cat to C:\Windows\servicing\packages\Package_for_KB5004118~31bf3856ad364e35~amd64~~6.3.1.3460.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5004118~31bf3856ad364e35~amd64~~6.3.1.3460.mum to C:\Windows\servicing\packages\Package_for_KB5004118~31bf3856ad364e35~amd64~~6.3.1.3460.mum.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5004754~31bf3856ad364e35~amd64~~6.3.1.3475.cat to C:\Windows\servicing\packages\Package_for_KB5004754~31bf3856ad364e35~amd64~~6.3.1.3475.cat.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\Package_for_KB5004754~31bf3856ad364e35~amd64~~6.3.1.3475.mum to C:\Windows\servicing\packages\Package_for_KB5004754~31bf3856ad364e35~amd64~~6.3.1.3475.mum.
Successfully restored ownership for C:\Windows\servicing\packages
Successfully restored permissions on C:\Windows\servicing\packages
Currently storing 34 datablocks.
Finish time: 2024-04-02 21:02:57.233
Script hash: yvl9IVmFNIL+F4FWHKO/XVJP0WVL+fKzpPgr1udUuiA=
SFCFix.txt contents are as follows:
Start time: 2024-04-03 17:54:10.502
Successfully took permissions for file or folder C:\Windows\winsxs
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb.
Successfully copied file C:\Users\ITNSPro\AppData\Local\niemiro\Archive\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb\CredentialUIBroker.exe to C:\Windows\winsxs\amd64_microsoft-windows-a..cation-creduibroker_31bf3856ad364e35_6.3.9600.19913_none_bbc3f61ee0f7eacb\CredentialUIBroker.exe.
Successfully restored ownership for C:\Windows\winsxs
Successfully restored permissions on C:\Windows\winsxs
Currently storing 35 datablocks.
Finish time: 2024-04-03 17:54:18.552
Script hash: ykvsrfIlZuubKME7rg0m9oO+jVILC//R9NV1ePoFbM8=
Run the command SFC /SCANNOW in an elevated command prompt again and report the result.
