[SOLVED] SFC can't fix some errors at 17% UIAutomationProvider.dll
Did you run SFC after running SFCFix?
Follow these instructions then :)
System File Checker (SFC)
    Run as Administrator
Results of instructions of 7:54AM
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sfc /scannow
Verification 100% complete.
C:\Windows\system32>copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.tx
t"
1 file(s) copied.
CBS file log link: https://drive.google.com/file/d/0B3uZT_J3_Uz5Q1M0WWVCU0VfalU/view?usp=sharing
SFC completed it's scan at 100%, and the CBS.log is clean. Looks like your issue has been solved. Is there anything else that you need, Windows Update related? :)
Aura, thank you for all your help with this issue. While the time to resolution was over a couple days, I accept full responsibility as your attentiveness was greatly appreciated.
No problem TheBuzz, you're welcome :)
Usually I reply faster since I can work on these while at work when I do automated tasks but right now we are in a rush (and we'll be for the next few months) so my response time is a bit affected. Hopefully it'll get better as time goes by :)
