- Mar 16, 2015
- 8,061
Let's trace something. Follow the instructions below please.
SFCFix - Fix Time
- Download SFCFix and move the executable on your Desktop;
- On your Desktop, right-click and select New, then Text Document. Give it the name SFCFixScript (it should be a .txt) extension;
- Open the SFCFixScript.txt file you just created, and copy/paste the following in it;
Code:FileScan:: usbhub.sys.mui
- Save any work you have open, and close every programs;
- Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it;
- SFCFix will launch, let it complete;
- Once done, a file will appear on your Desktop, called SFCFix.txt;
- Open the file, then copy and paste its content in your next reply;
