sfc /scannow error "could not perform requested operation"
Can you provide me with any further help? I just ran sfc /scannow and it was still working, but checking for updates has been running for 15 minutes without stopping.
Soon after I sent this windows update told me there were no new updates.
Okay. But when I run DISM I'm still getting an error message. If I need to use system restore to restore my computer to a state before I implemented the fix you gave me, will the fix still be in place? Or will I have to redo it?
I just searched for new updates again and it told me "windows could not search for new updates" and showed error code C80003FA. How should I proceed?
I decided to run sfc /scannow and just searched for new updates again and it came up with servicing stack update KB4540725. Last time I tried installing that back in March it prevented me from searching for new updates and I had to run a system restore. Do you suggest I try to install it again and see what happens?
I installed servicing stack update KB4540725 and ran a dism and this was the result:
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\windows\system32>dism /online /cleanup-image /checkhealth
Version: 6.3.9600.19408
Image Version: 6.3.9600.19397
The component store is repairable.
C:\windows\system32>dism /online /cleanup-image /scanhealth
C:\windows\system32>dism /online /cleanup-image /restorehealth
The restore operation failed. Either the repair source was not found or the comp
onent store cannot be repaired.
Error: 0x800f081f
DISM failed. No operation was performed.
The DISM log file can be found at C:\windows\Logs\DISM\dism.log
I'd like to thank you for the help you've provided me. But I was wondering if you could assist me further in fixing the issue I am having with my computer. I would be happy to compensate you for your services if required. Or, if you could connect me with someone else that could provide me with the assistance I need I would really appreciate it. I don't want to monopolize your time, but I'm very concerned about my computer. Thank you for your time.
Here you go.
CBS copy 2.log
C:\windows\system32>sfc /scannow
Verification 100% complete.
Error: 0x800f081f
Retrieve Components Hive
Afterwards, run DISM again and attach CBS.log.
No component store corruption detected.
The restore operation completed successfully. The component store corruption was
repaired.
Start time: 2020-06-14 21:52:02.563
Using .zip script file at C:\Users\Hollis Mulwray\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18639_none_c6b61992e5d8ab58
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18619_none_c6b418fee5da78aa
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18618_none_c6b42fc6e5da5f09
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18450_none_c6ce8706e5c5bf7b
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004
Successfully took permissions for file or folder C:\windows\WinSxS\Manifests\amd64_709e52c5af6f6ce41a0f60310181636f_31bf3856ad364e35_6.3.9600.17415_none_8fa86ab2d3bfda8d.manifest
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18639_none_c6b61992e5d8ab58\ieetwcollector.exe to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18639_none_c6b61992e5d8ab58\ieetwcollector.exe.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18619_none_c6b418fee5da78aa\ieetwcollector.exe to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18619_none_c6b418fee5da78aa\ieetwcollector.exe.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18618_none_c6b42fc6e5da5f09\ieetwcollector.exe to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18618_none_c6b42fc6e5da5f09\ieetwcollector.exe.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18450_none_c6ce8706e5c5bf7b\ieetwcollector.exe to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18450_none_c6ce8706e5c5bf7b\ieetwcollector.exe.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004\ieetwcollector.exe to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004\ieetwcollector.exe.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004\ieetwproxystub.dll to C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004\ieetwproxystub.dll.
Successfully copied file C:\Users\Hollis Mulwray\AppData\Local\niemiro\Archive\Manifests\amd64_709e52c5af6f6ce41a0f60310181636f_31bf3856ad364e35_6.3.9600.17415_none_8fa86ab2d3bfda8d.manifest to C:\windows\WinSxS\Manifests\amd64_709e52c5af6f6ce41a0f60310181636f_31bf3856ad364e35_6.3.9600.17415_none_8fa86ab2d3bfda8d.manifest.
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18639_none_c6b61992e5d8ab58
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18639_none_c6b61992e5d8ab58
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18619_none_c6b418fee5da78aa
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18619_none_c6b418fee5da78aa
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18618_none_c6b42fc6e5da5f09
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18618_none_c6b42fc6e5da5f09
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18450_none_c6ce8706e5c5bf7b
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.18450_none_c6ce8706e5c5bf7b
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-ie-ieetwcollector_31bf3856ad364e35_11.0.9600.17351_none_c6d93e44e5bdc004
Successfully restored ownership for C:\windows\WinSxS\Manifests\amd64_709e52c5af6f6ce41a0f60310181636f_31bf3856ad364e35_6.3.9600.17415_none_8fa86ab2d3bfda8d.manifest
Successfully restored permissions on C:\windows\WinSxS\Manifests\amd64_709e52c5af6f6ce41a0f60310181636f_31bf3856ad364e35_6.3.9600.17415_none_8fa86ab2d3bfda8d.manifest
Finish time: 2020-06-14 21:52:06.331
Script hash: kHn+6oafGcA/BowNrKPQIlVOx0Smv5fEzwIs3VoCbY8=
CBS.7z
