sfc /scannow errors
Please don't install any software while cleaning/fixing the machine.
Can we remove the 3 exe files mentioned in my previous post ? Most of the scanners at VirusTotal marks them as unwanted.
  3. Press the Fix button.
Post a screenshot of the Device Manager window.
Right-click PS/2 Compatible Mouse and select Properties.
Post a screenshot of all 5 tabs.
On the tab "Driver" click Uninstall.
Restart the machine when done.
Upon restart Device Manager should detect and install the mouse-driver again.
Does that help ?
