[SOLVED] SFC/SCANNOW not repair damaged files.
Hello Solitario,
As Go The Power has explained I will be assisting you under his supervision.
If you have questions about the instructions provided at any point please feel free to ask :)
I have created a package for SFCFix to replace the corrupted files on your system.
Step 1 - SFCFix Script
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put tags around the log to break up the text.
sfcfix.zip
Step 2 - DISM
DISM Scan
  1. Right click on the
    button
  3. Inside the Command Prompt windows copy and paste the following command DISM /Online /Cleanup-Image /RestoreHealth
Convert CBS.log to CBS.txt
    button
  2. Click on Run => Inside the run box copy and paste the following command:
  3. Press Enter
  4. Once this has completed please go to your Desktop and you will find CBS.txt, please rename this file to CBS_{Insert forum username here}_{insert todays Date here}.txt For example "cbs_zcomputerwiz_0630.txt"
  5. Please upload CBS_{Username}_{Date}.txt to this thread.
Please Note:: if the file is too big to upload to your next post please upload via Dropbox or One Drive
Start time: 2015-07-02 08:59:21.243
Using .zip script file at C:\Users\Emanuel\Desktop\sfcfix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_6.3.9600.16384_none_380ae8ef6539f2d1\InstallPersistSqlState.sql
Successfully took permissions for file or folder C:\WINDOWS\winsxs\Manifests
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf
Successfully took permissions for file or folder C:\WINDOWS\servicing\Packages
Successfully took permissions for file or folder C:\WINDOWS\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully took permissions for file or folder C:\WINDOWS\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum
Successfully took permissions for file or folder C:\WINDOWS\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully took permissions for file or folder C:\WINDOWS\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-p..ns-platform-library_31bf3856ad364e35_6.3.9600.16456_none_7775637956939b58.
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-c..t-resources-mrmcore_31bf3856ad364e35_6.3.9600.16461_none_dc4fab2635ce6a77.
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-c..ialmigrationhandler_31bf3856ad364e35_6.3.9600.16443_none_64df3819cac3c551.
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62.
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.16452_none_5a15684b60ab1b33.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_6.3.9600.16384_none_380ae8ef6539f2d1\InstallPersistSqlState.sql to C:\WINDOWS\winsxs\x86_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_6.3.9600.16384_none_380ae8ef6539f2d1\InstallPersistSqlState.sql.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel.activation_31bf3856ad364e35_4.0.9600.20681_none_7b76a9e26196ee3a.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel.activation_31bf3856ad364e35_4.0.9600.20681_none_7b76a9e26196ee3a.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.17187_none_47beba5522d99523.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.17187_none_47beba5522d99523.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.20681_none_30f199cf3c805f80.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.20681_none_30f199cf3c805f80.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel.web_31bf3856ad364e35_4.0.9600.20681_none_d304432ef4a0d6f8.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel.web_31bf3856ad364e35_4.0.9600.20681_none_d304432ef4a0d6f8.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel_b77a5c561934e089_4.0.9600.17187_none_6a949f2d30b66d01.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel_b77a5c561934e089_4.0.9600.17187_none_6a949f2d30b66d01.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.servicemodel_b77a5c561934e089_4.0.9600.20681_none_53c77ea74a5d375e.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.servicemodel_b77a5c561934e089_4.0.9600.20681_none_53c77ea74a5d375e.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.serviceprocess_b03f5f7f11d50a3a_4.0.9600.20681_none_03db09ba3c4c953e.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.serviceprocess_b03f5f7f11d50a3a_4.0.9600.20681_none_03db09ba3c4c953e.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.threading.timer_b03f5f7f11d50a3a_4.0.9600.20681_none_f4307c83d3d19123.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.threading.timer_b03f5f7f11d50a3a_4.0.9600.20681_none_f4307c83d3d19123.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.17187_none_38ba61496a5b28c5.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.17187_none_38ba61496a5b28c5.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.20681_none_21ed40c38401f322.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.20681_none_21ed40c38401f322.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.17187_none_43094cd5c3a01485.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.17187_none_43094cd5c3a01485.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.20681_none_2c3c2c4fdd46dee2.manifest to C:\WINDOWS\winsxs\Manifests\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.20681_none_2c3c2c4fdd46dee2.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\x86_microsoft-windows-rastls_31bf3856ad364e35_6.3.9600.16475_none_0110c2916bb47018.manifest to C:\WINDOWS\winsxs\Manifests\x86_microsoft-windows-rastls_31bf3856ad364e35_6.3.9600.16475_none_0110c2916bb47018.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\Manifests\x86_microsoft-windows-settingsynchost_31bf3856ad364e35_6.3.9600.16474_none_148dc2e43ebb1059.manifest to C:\WINDOWS\winsxs\Manifests\x86_microsoft-windows-settingsynchost_31bf3856ad364e35_6.3.9600.16474_none_148dc2e43ebb1059.manifest.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-p..ns-platform-library_31bf3856ad364e35_6.3.9600.16456_none_7775637956939b58\wpncore.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-p..ns-platform-library_31bf3856ad364e35_6.3.9600.16456_none_7775637956939b58\wpncore.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf to C:\WINDOWS\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..t-resources-mrmcore_31bf3856ad364e35_6.3.9600.16461_none_dc4fab2635ce6a77\mrmcorer.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..t-resources-mrmcore_31bf3856ad364e35_6.3.9600.16461_none_dc4fab2635ce6a77\mrmcorer.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..ialmigrationhandler_31bf3856ad364e35_6.3.9600.16443_none_64df3819cac3c551\credentialmigrationhandler.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..ialmigrationhandler_31bf3856ad364e35_6.3.9600.16443_none_64df3819cac3c551\credentialmigrationhandler.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winload.efi to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winload.efi.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winload.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winload.exe.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winresume.efi to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winresume.efi.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winresume.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.3.9600.16452_none_4c038b5340875d62\winresume.exe.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.16452_none_5a15684b60ab1b33\winresume.efi to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.16452_none_5a15684b60ab1b33\winresume.efi.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.16452_none_5a15684b60ab1b33\winresume.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.16452_none_5a15684b60ab1b33\winresume.exe.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat to C:\WINDOWS\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum to C:\WINDOWS\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_168_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\Packages\package_168_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_168_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\Packages\package_168_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_169_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\Packages\package_169_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_169_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\Packages\package_169_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_170_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\Packages\package_170_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_170_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\Packages\package_170_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat to C:\WINDOWS\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum to C:\WINDOWS\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat to C:\WINDOWS\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum to C:\WINDOWS\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum.
Successfully restored ownership for C:\WINDOWS\winsxs\x86_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_6.3.9600.16384_none_380ae8ef6539f2d1\InstallPersistSqlState.sql
Successfully restored permissions on C:\WINDOWS\winsxs\x86_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_6.3.9600.16384_none_380ae8ef6539f2d1\InstallPersistSqlState.sql
Successfully restored ownership for C:\WINDOWS\winsxs\Manifests
Successfully restored permissions on C:\WINDOWS\winsxs\Manifests
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf
Successfully restored ownership for C:\WINDOWS\servicing\Packages
Successfully restored permissions on C:\WINDOWS\servicing\Packages
Successfully restored ownership for C:\WINDOWS\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully restored permissions on C:\WINDOWS\servicing\Packages\package_101_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully restored ownership for C:\WINDOWS\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum
Successfully restored permissions on C:\WINDOWS\servicing\Packages\package_155_for_kb2962409~31bf3856ad364e35~amd64~~6.3.1.2.mum
Successfully restored ownership for C:\WINDOWS\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully restored permissions on C:\WINDOWS\servicing\Packages\package_56_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully restored ownership for C:\WINDOWS\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Successfully restored permissions on C:\WINDOWS\servicing\Packages\package_57_for_kb2984006~31bf3856ad364e35~amd64~~6.3.1.4.mum
Currently storing 9 datablocks.
Finish time: 2015-07-02 09:04:29.104
Script hash: HjC6BPudZLuvwNzkW9v44hiuh8PikHzM1/5SVSeaeKM=
CBS txt: https://mega.co.nz/#!uFwzRI6a!svLBDekCzu2gIrrmkKc2sakxFquibT7YdJ21iG13J_U
Dism
Hello! Thanks a lot! Here are the logs. The DISM command gave me the error 0x800f0906. I will be attentive to your instructions.
Greetings and thank you.
Looks like we got the majority of the files, lets replace this one and see where we're at.
I have created another package for SFCFix to replace the corrupted file on your system.
View attachment sfcfix.zip
Step 2 - DISM
DISM Scan
    button
    button
  3. Press Enter
Start time: 2015-07-03 10:12:07.723
Successfully took permissions for file or folder C:\WINDOWS\servicing\packages
Successfully took permissions for file or folder C:\WINDOWS\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.mum
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.cat to C:\WINDOWS\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.cat.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.mum to C:\WINDOWS\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.mum.
Successfully restored ownership for C:\WINDOWS\servicing\packages
Successfully restored permissions on C:\WINDOWS\servicing\packages
Successfully restored ownership for C:\WINDOWS\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.mum
Successfully restored permissions on C:\WINDOWS\servicing\packages\Package_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.mum
Currently storing 11 datablocks.
Finish time: 2015-07-03 10:12:30.270
Script hash: 6HgF6tBpsKsZ5UNsevXeAGEonfDMAZwo9NxGm500gUw=
CBS: https://mega.co.nz/#!OFRAmIQZ!4ikwq-iORQyyXCZ2y0ygmyqvfLYq9f5Wn4Y6rVQZj5o
Thanks a lot.
Best regards.
The SFC command still fails. I have attached an image.
Thank you very much for the help.
Best regards.
Please try running SFC again and upload the log.
SFC Scan
    button
  3. Inside the Command Prompt windows copy and paste the following command SFC /ScanNow
    button
  3. Press Enter
Start time: 2015-07-05 08:27:26.909
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-font-truetype-simhei_31bf3856ad364e35_6.3.9600.16384_none_e4e61669480be9c8\simhei.ttf
   CBS & SFC total detected corruption count:     1
   CBS & SFC total unimportant corruption count:  0
   CBS & SFC total fixed corruption count:        0
   SURT total detected corruption count:          0
   SURT total unimportant corruption count:       0
   SURT total fixed corruption count:             0
Currently storing 12 datablocks.
Finish time: 2015-07-05 09:48:18.050
SFC Scan
    button
    button
  3. Press Enter
Start time: 2015-07-06 15:24:37.074
Successfully created directory tree \\?\C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80CHS.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80CHS.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80CHT.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80CHT.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80DEU.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80DEU.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ENU.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ENU.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ESP.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ESP.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80FRA.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80FRA.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ITA.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80ITA.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80JPN.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80JPN.dll.
Successfully copied file C:\Users\Emanuel\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80KOR.dll to C:\WINDOWS\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\mfc80KOR.dll.
Finish time: 2015-07-06 15:25:04.792
Script hash: dlWjz3iEzfmMyWr/R2Hiv6K3I0r8wnUmdE4nlXUtqgc=
CBS: https://mega.co.nz/#!6VpXgA7S!xh2Oz-FzLBb0gBnxtTBcQRgpEUnYkYaE_8BoTYhNZlQ
Thank you, greetings.
