[SOLVED] SFC unable to repair (hash mismatch)
Here's the result:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-10 21:39:54.223
Using .txt script file at C:\Users\user\Desktop\SFCFixScript.txt [0]
FileScan::
[0: 5] C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7600.16385_none_73a679f8be493c8c\Pretty_Peacock.jpg
 Expected: tfmxBgEeHYSqU0nOhrdrRtqL98a1xYC32if7l90WiOg=
 Expected: 6.1.7600.16385 Found: Version number not available.
Successfully traced component amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7600.16385_none_73a679f8be493c8c.
Microsoft-Windows-TabletPC-OC-Package~31bf3856ad364e35~amd64~~6.1.7600.16385.TabletPCOC
 [C:\Program Files\Common Files\Microsoft Shared\Stationery\Pretty_Peacock.jpg]
 [C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui]
 [C:\Windows\SysWOW64\en-US\iassdo.dll.mui]
 [C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg]
[1: 1] C:\SFCFix\Backups\C\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg
File is untraceable.
 Found: hLMYgoYEaSd6WHNAcMpQlj3ndwYSJanHCJ0EaEjgsTg=
 Found: 6.1.7600.16385
Trace not available.
[2: 2] C:\Windows\winsxs\amd64_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_448b1c3c529ce8ed\iassdo.dll.mui
 Expected: OP2PFNasfNNIWM0oyuajsI6jQ9pkJ7CbHj0zbJYzCpQ=
Successfully traced component amd64_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_448b1c3c529ce8ed.
Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7600.16385.Windows Foundation Language Pack
 [C:\Windows\System32\en-US\iassdo.dll.mui]
[3: 1] C:\SFCFix\Backups\C\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui
 Found: tfmxBgEeHYSqU0nOhrdrRtqL98a1xYC32if7l90WiOg=
Currently storing 13 datablocks.
Finish time: 2018-08-10 21:40:40.617
Script hash: wjvvQdbiHPkUsnmLiwtJ24bZucQ+Uq+q5VlHRLo2IRs=
FRST Fix
FRST Fix
Here it is:
Fix result of Farbar Recovery Scan Tool (x64) Version: 02.08.2018Ran by user (11-08-2018 10:35:45) Run:4
Running from C:\Users\user\Desktop
Loaded Profiles: user (Available Profiles: user)
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
C:\Program Files\Common Files\Microsoft Shared\Stationery\Pretty_Peacock.jpg => moved successfully
C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui => moved successfully
C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg => moved successfully
==== End of Fixlog 10:36:08 ====
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
SFC Scan
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put tags around the log to break up the text.
SFC Scan
Here's the results:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-11 19:29:49.831
Using .zip script file at C:\Users\user\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026
Successfully copied file C:\Users\user\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\pretty_peacock.jpg to C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\pretty_peacock.jpg.
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026
Currently storing 14 datablocks.
Finish time: 2018-08-11 19:29:52.171
Script hash: 5XjX0UDlry6Xo11DEmWBonspCHq5xs2Z0xzexMCXSek=
SFC Scan
SFC Scan
Thanks for the reply. Here's the result:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-14 22:56:30.900
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7
Successfully copied file C:\Users\user\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7
Currently storing 15 datablocks.
Finish time: 2018-08-14 22:56:32.694
Script hash: nScsnpNMXm7cGjw/DfsvtkrbwfcvbxpITDi5Yt04FUg=
SFC Scan
SFC Scan
Here's the result. Is that what I think it is? :grin1:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-15 14:18:27.589
TakePermissions::
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg
TakePermissions:: directive completed successfully.
Delete::
Successfully deleted files matching pattern C:\Windows\WinSxS\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui.
Successfully deleted files matching pattern C:\Windows\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg.
Delete:: directive completed successfully.
RestorePermissions::
Failed to read file attributes for file or folder C:\Windows\WinSxS\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\Windows\WinSxS\x86_microsoft-windows-n..ce_iassdo.resources_31bf3856ad364e35_6.1.7600.16385_en-us_e86c80b89a3f77b7\iassdo.dll.mui. Error code ERROR_FILE_NOT_FOUND.
Failed to read file attributes for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg. Error code ERROR_FILE_NOT_FOUND.
RestorePermissions:: directive failed to complete successfully.
Successfully copied file C:\Users\user\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg to C:\Windows\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.1.7601.17514_none_75d78dc0bb37c026\Pretty_Peacock.jpg.
Currently storing 17 datablocks.
Finish time: 2018-08-15 14:18:28.930
Script hash: 79wKn3J9wi3WaupHABWoUXC47+rc2hVZkv45jOrs36g=
Yes, it's already fixed. Thank you very much for your assistance bro. I really appreciate everything :grin1: :wave:
