[SOLVED] SFCFix ends with error message
Fix result of Farbar Recovery Scan Tool (x64) Version: 06.06.2018 01Ran by administrator (06-06-2018 17:44:32) Run:1
Running from B:\
Loaded Profiles: administrator (Available Profiles: Administrator & Watchman & administrator)
Boot Mode: Normal
fixlist content:
cmd: reg query "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\DriverOperations" /s
========= reg query "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\DriverOperations" /s =========
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\DriverOperations
Current REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\DriverOperations\0
AllowQueryRemove REG_DWORD 0x1
PerformDeviceInstallsPriorToReboot REG_DWORD 0x1
AllowDoqAndPoqSeparate REG_DWORD 0x1
==== End of Fixlog 17:44:32 ====
Remove Update Manually
wusa /uninstall /KB:4041693
Popup box comes up titled "Windows Update Standalone Installer" that says "The update KB4041693 is not installed on this computer".
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
KB4041693 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please attach this to your next reply. It is saved on your desktop named SearchReg.txt.
Since this is Server 2012 R2, it loads Server Manager for "Windows Features". I selected the "Add Roles and Features Wizard", selected the local server, and clicked next past the Roles section and the Features section. I believe this loaded the hive you wanted. Log is attached.
Good job!
FRST Fix
wusa /uninstall /KB:4034681
4. Let me know if it says it was successful or if there are any errors. If there are errors, please do a FRST Registry Search for that update and attach SearchReg.txt
FRST Fix
3. Extract the zip file.
4. Run FRST64 by Right-Clicking on the file and choosing Run as administrator.
5. Press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
6. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
7. Try updates and if any fail, attach CBS.log.
  1. Success! (partially)
  2. Checked for updates and both 2017-12 and 2018-05 were still listed as Important Updates.
  3. Installed only KB4103725 (2018-05) with no issues.
  4. Rebooted and performed a full backup.
  5. Verified that the original major issue has been resolved. The issue was that an SMB update contained in KB4103725 did not allow a machine that had 2018-05 installed to RDP into a machine that did not have 2018-05 installed. This problem is fixed. I was able to RDP into the subject server without issue.
  6. Rebooted and checked for updates. 2017-12 was not listed. KB3185319 was listed as Important.
  7. Tried to install KB3185319. Failed with error 800F0831. CBS logs are at (Download CBS7.zip)
Awesome!
wusa /uninstall /KB:4025335
FRST Fix
Download Fixlog4.zip
Checked for updates - found Important Update KB3185319, Optional Update KB4103724.
Tried KB3185319 alone (failed)
Tried KB4103724 alone (failed)
Rebooted
All updates failed with the same error 0x800f0831.
Download CBS8.zip
Update is not installed for KB4041693.
SearchReg found nothing in the registry for "4041693".
