Updated to 10586.14
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
Verification 100% complete.
C:\WINDOWS\system32>Dism /Online /Cleanup-Image /ScanHealth
Version: 10.0.10586.0
Image Version: 10.0.10586.0
The component store is repairable.
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see
Configure a Windows Repair Source.
2015-11-26 13:56:22, Info DISM PID=6364 TID=7732 Scratch directory set to 'C:\Users\Ryan\AppData\Local\Temp\'. - CDISMManager:
ut_ScratchDir
2015-11-26 13:56:22, Info DISM PID=6364 TID=7732 DismCore.dll version: 10.0.10586.0 - CDISMManager::FinalConstruct
2015-11-26 13:56:22, Info DISM PID=6364 TID=7732 Successfully loaded the ImageSession at "C:\WINDOWS\System32\Dism" - CDISMManager::LoadLocalImageSession
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:22, Info DISM DISM Manager: PID=6364 TID=7732 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2015-11-26 13:56:22, Info DISM DISM.EXE:
2015-11-26 13:56:22, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2015-11-26 13:56:22, Info DISM DISM.EXE: Host machine information: OS Version=10.0.10586, Running architecture=amd64, Number of processors=4
2015-11-26 13:56:22, Info DISM DISM.EXE: Dism.exe version: 10.0.10586.0
2015-11-26 13:56:22, Info DISM DISM.EXE: Executing command line: Dism /Online /Cleanup-Image /ScanHealth
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Getting Provider FolderManager - CDISMProviderStore::GetProvider
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Loading Provider from location C:\WINDOWS\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:22, Info DISM DISM Provider Store: PID=6364 TID=7732 Connecting to the provider located at C:\WINDOWS\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:22, Info DISM DISM Manager: PID=6364 TID=7732 physical location path: C:\ - CDISMManager::CreateImageSession
2015-11-26 13:56:22, Info DISM DISM Manager: PID=6364 TID=7732 Event name for current DISM session is Global\{56E488EF-9E37-46D8-9A0B-348B3E1F8C11} - CDISMManager::CheckSessionAndLock
2015-11-26 13:56:22, Info DISM DISM Manager: PID=6364 TID=7732 Create session event 0x16c for current DISM session and event name is Global\{56E488EF-9E37-46D8-9A0B-348B3E1F8C11} - CDISMManager::CheckSessionAndLock
2015-11-26 13:56:22, Info DISM DISM Manager: PID=6364 TID=7732 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2015-11-26 13:56:23, Info DISM DISM Manager: PID=6364 TID=7732 Successfully loaded the ImageSession at "C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F" - CDISMManager::LoadRemoteImageSession
2015-11-26 13:56:23, Info DISM DISM Image Session: PID=7916 TID=5868 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM OS Provider: PID=7916 TID=5868 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM OS Provider: PID=7916 TID=5868 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM OS Provider: PID=7916 TID=5868 Host OS verion is 10.0 - CDISMOSServiceManager::SetDllSearchPath
2015-11-26 13:56:23, Warning DISM DISM OS Provider: PID=7916 TID=5868 Unable to set the DLL search path to the servicing stack folder. C:\Windows may not point to a valid Windows folder. - CDISMOSServiceManager::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Warning DISM DISM Provider Store: PID=7916 TID=5868 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Manager: PID=6364 TID=7732 Image session successfully loaded from the temporary location: C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F - CDISMManager::CreateImageSession
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Getting Provider OSServices - CDISMProviderStore::GetProvider
2015-11-26 13:56:23, Info DISM DISM.EXE: Target image information: OS Version=10.0.10586.0, Image architecture=amd64
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\IBSProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM OS Provider: PID=7916 TID=5868 Successfully loaded the hive. - CDISMOSServiceManager:
etermineBootDrive
2015-11-26 13:56:23, Info DISM DISM Driver Manager: PID=7916 TID=5868 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\Wow64provider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Warning DISM DISM Provider Store: PID=7916 TID=5868 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002)
2015-11-26 13:56:23, Warning DISM DISM Provider Store: PID=7916 TID=5868 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002)
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\EmbeddedProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Warning DISM DISM Provider Store: PID=7916 TID=5868 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\AppxProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\ProvProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\AssocProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\GenericProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\OfflineSetupProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\63925599-B3C0-4E22-A0EC-563F90AA5B3F\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 13:56:23, Info DISM DISM Transmog Provider: PID=7916 TID=5868 Current image session is [ONLINE] - CTransmogManager::GetMode
2015-11-26 13:56:23, Info DISM DISM Transmog Provider: PID=7916 TID=5868 Audit Mode: [No] - CTransmogManager::Initialize
2015-11-26 13:56:23, Info DISM DISM Transmog Provider: PID=7916 TID=5868 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2015-11-26 13:56:23, Info DISM DISM Transmog Provider: PID=7916 TID=5868 Product Type: [WinNT] - CTransmogManager::Initialize
2015-11-26 13:56:23, Info DISM DISM Transmog Provider: PID=7916 TID=5868 Product Type ServerNT : [No] - CTransmogManager::Initialize
2015-11-26 13:56:23, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2015-11-26 13:56:23, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2015-11-26 13:56:23, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2015-11-26 13:56:23, Info DISM DISM Provider Store: PID=7916 TID=5868 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:
rivate_ValidateCmdLine
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2015-11-26 13:56:23, Info DISM DISM Package Manager: PID=7916 TID=5868 CBS session options=0x4100! - CDISMPackageManager::Internal_Finalize
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 - CDISMPackageManager::Internal_Finalize
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 <----- Starting corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
(p) CSI Payload Corrupt wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll
Summary:
Operation: Detect only
Operation result: 0x0
Last Successful Step: CSI store detection completes.
Total Detected Corruption: 1
CBS Manifest Corruption: 0
CBS Metadata Corruption: 0
CSI Manifest Corruption: 0
CSI Metadata Corruption: 0
CSI Payload Corruption: 1
Total Repaired Corruption: 0
CBS Manifest Repaired: 0
CSI Manifest Repaired: 0
CSI Payload Repaired: 0
CSI Store Metadata refreshed: True
Total Operation Time: 102 seconds.
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 <----- Ending corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 DISM has detected a DISM component change. Requesting a shutdown. - CDISMPackageManager::Internal_Finalize
2015-11-26 13:58:06, Info DISM DISM Image Session: PID=7916 TID=5868 The image session needs to be closed and re-opened before any servicing operations can be performed. - CDISMImageSession:
ut_ImageState
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Package Manager: PID=7916 TID=5868 Finalizing CBS core. - CDISMPackageManager::Finalize
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=7916 TID=5868 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Manager: PID=6364 TID=7732 Closing session event handle 0x16c - CDISMManager::CloseImageSession
2015-11-26 13:58:06, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2015-11-26 13:58:06, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=6364 TID=7732 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=6364 TID=7732 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 13:58:06, Info DISM DISM Provider Store: PID=6364 TID=7732 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:06:17, Info DISM PID=6856 TID=7500 Scratch directory set to 'C:\Users\Ryan\AppData\Local\Temp\'. - CDISMManager:
ut_ScratchDir
2015-11-26 14:06:17, Info DISM PID=6856 TID=7500 DismCore.dll version: 10.0.10586.0 - CDISMManager::FinalConstruct
2015-11-26 14:06:17, Info DISM PID=6856 TID=7500 Successfully loaded the ImageSession at "C:\WINDOWS\System32\Dism" - CDISMManager::LoadLocalImageSession
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2015-11-26 14:06:17, Info DISM DISM.EXE:
2015-11-26 14:06:17, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2015-11-26 14:06:17, Info DISM DISM.EXE: Host machine information: OS Version=10.0.10586, Running architecture=amd64, Number of processors=4
2015-11-26 14:06:17, Info DISM DISM.EXE: Dism.exe version: 10.0.10586.0
2015-11-26 14:06:17, Info DISM DISM.EXE: Executing command line: Dism /Online /Cleanup-Image /RestoreHealth
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Getting Provider FolderManager - CDISMProviderStore::GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Loading Provider from location C:\WINDOWS\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=6856 TID=7500 Connecting to the provider located at C:\WINDOWS\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 physical location path: C:\ - CDISMManager::CreateImageSession
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Event name for current DISM session is Global\{5802D181-42A5-4EF5-B78D-28B3C5E2E1F3} - CDISMManager::CheckSessionAndLock
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Create session event 0x164 for current DISM session and event name is Global\{5802D181-42A5-4EF5-B78D-28B3C5E2E1F3} - CDISMManager::CheckSessionAndLock
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Successfully loaded the ImageSession at "C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF" - CDISMManager::LoadRemoteImageSession
2015-11-26 14:06:17, Info DISM DISM Image Session: PID=3336 TID=6432 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:17, Info DISM DISM OS Provider: PID=3336 TID=6432 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM OS Provider: PID=3336 TID=6432 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM OS Provider: PID=3336 TID=6432 Host OS verion is 10.0 - CDISMOSServiceManager::SetDllSearchPath
2015-11-26 14:06:17, Warning DISM DISM OS Provider: PID=3336 TID=6432 Unable to set the DLL search path to the servicing stack folder. C:\Windows may not point to a valid Windows folder. - CDISMOSServiceManager::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Warning DISM DISM Provider Store: PID=3336 TID=6432 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Manager: PID=6856 TID=7500 Image session successfully loaded from the temporary location: C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF - CDISMManager::CreateImageSession
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Getting Provider OSServices - CDISMProviderStore::GetProvider
2015-11-26 14:06:17, Info DISM DISM.EXE: Target image information: OS Version=10.0.10586.0, Image architecture=amd64
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:17, Info DISM DISM Provider Store: PID=3336 TID=6432 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\IBSProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM OS Provider: PID=3336 TID=6432 Successfully loaded the hive. - CDISMOSServiceManager:
etermineBootDrive
2015-11-26 14:06:18, Info DISM DISM Driver Manager: PID=3336 TID=6432 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\Wow64provider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Warning DISM DISM Provider Store: PID=3336 TID=6432 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002)
2015-11-26 14:06:18, Warning DISM DISM Provider Store: PID=3336 TID=6432 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002)
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\EmbeddedProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Warning DISM DISM Provider Store: PID=3336 TID=6432 Failed to Load the provider: C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\AppxProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\ProvProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\AssocProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\GenericProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\OfflineSetupProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Loading Provider from location C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Connecting to the provider located at C:\Users\Ryan\AppData\Local\Temp\A769019F-FE85-42FD-9478-45D098E960FF\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-11-26 14:06:18, Info DISM DISM Transmog Provider: PID=3336 TID=6432 Current image session is [ONLINE] - CTransmogManager::GetMode
2015-11-26 14:06:18, Info DISM DISM Transmog Provider: PID=3336 TID=6432 Audit Mode: [No] - CTransmogManager::Initialize
2015-11-26 14:06:18, Info DISM DISM Transmog Provider: PID=3336 TID=6432 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2015-11-26 14:06:18, Info DISM DISM Transmog Provider: PID=3336 TID=6432 Product Type: [WinNT] - CTransmogManager::Initialize
2015-11-26 14:06:18, Info DISM DISM Transmog Provider: PID=3336 TID=6432 Product Type ServerNT : [No] - CTransmogManager::Initialize
2015-11-26 14:06:18, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2015-11-26 14:06:18, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2015-11-26 14:06:18, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider
2015-11-26 14:06:18, Info DISM DISM Provider Store: PID=3336 TID=6432 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2015-11-26 14:06:18, Info DISM DISM Package Manager: PID=3336 TID=6432 CBS session options=0x48100! - CDISMPackageManager::Internal_Finalize
2015-11-26 14:08:08, Info DISM DISM Package Manager: PID=3336 TID=3108 Error in operation: source for package or file not found, ResolveSource() unsuccessful. (CBS HRESULT=0x800f081f) - CCbsConUIHandler::Error
2015-11-26 14:08:08, Error DISM DISM Package Manager: PID=3336 TID=6432 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f081f)
2015-11-26 14:08:08, Error DISM DISM Package Manager: PID=3336 TID=6432 The source files could not be found; their location must be specified using the /source option to restore the feature. - GetCbsErrorMsg
2015-11-26 14:08:08, Error DISM DISM Package Manager: PID=3336 TID=6432 Failed processing package changes with session option CbsSessionOptionRepairStoreCorruption - CDISMPackageManager::RestoreHealth(hr:0x800f081f)
2015-11-26 14:08:08, Error DISM DISM Package Manager: PID=3336 TID=6432 Failed to restore the image health. - CPackageManagerCLIHandler:
rocessCmdLine_CleanupImage(hr:0x800f081f)
2015-11-26 14:08:08, Error DISM DISM Package Manager: PID=3336 TID=6432 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2015-11-26 14:08:08, Info DISM DISM Package Manager: PID=3336 TID=6432 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Package Manager: PID=3336 TID=6432 Finalizing CBS core. - CDISMPackageManager::Finalize
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=3336 TID=6432 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Manager: PID=6856 TID=7500 Closing session event handle 0x164 - CDISMManager::CloseImageSession
2015-11-26 14:08:08, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2015-11-26 14:08:08, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=6856 TID=7500 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=6856 TID=7500 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2015-11-26 14:08:08, Info DISM DISM Provider Store: PID=6856 TID=7500 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
