I did notice however I was busy yesterday evening so I had no time to reply. As for your BSOD issues, you'll be in the good hands of the BSOD Kernel Dump Experts :) Here's another fix, after that, there should only be 1 file left to replace.
SFCFix - Fix Time
Download SFCFix and move the executable on your Desktop;
Download the attached SFCFix.zip and move the archive to your Desktop; Note: Make sure that the file is named SFCFix.zip, do not rename it.
Save any work you have open, and close every programs;
Drag the SFCFix.zip archive file over the SFCFix.exe executable and release it;
SFCFix will launch, let it complete;
Once done, a file will appear on your Desktop, called SFCFix.txt;
Open the file, then copy and paste its content in your next reply;
