[SOLVED] sfcfix help, windows 7 pro sr1 64
Update
Actually I think it is the exact same result, FC matches them line-for-line apart from the timestamp.
Right-click the Start button and click Command prompt(Administrator).
If you get a popup about UserAccountControl, allow the program to run.
When command prompt opens, copy and paste the following command into it, then press enter.
dism /online /remove-package /PackageName:Package_for_KB2952664~31bf3856ad364e35~amd64~~6.1.16.5
Provide a screenshot of the result.
I noticed CBS.log also had today's date so I've attached that too in addition to CheckSUR.log
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\windows\system32>dism /online /remove-package /PackageName:Package_for_KB2952
Version: 6.1.7601.24499
Image Version: 6.1.7601.24499
Processing 1 of 1 - Removing package Package_for_KB2952664~31bf3856ad364e35~amd6
4~~6.1.1.3
We can try to cleanup the 2 remaining issues but maybe that is not needed.
Check Windows Update again. Provide a screenshot of the available important updates only. Do not install any of them yet.
Important and Optional categories.
Try to install the important update only.
If it fails, attach the file C:\Windows\Logs\CBS\cbs.log.
Sorry if this isn't clear, I ran checksur as well because that seemed to make the list of updates appear.
Then I've tried to download and manually install two updates that seemed to be listed as inportant. It is a bit wierd though because in each case if you go to MS you get a list of six files, I don't know if that means the updates are roll-up updates or just that they are packaged with prerequisites to save time.
Some system tray tools seem to work now that didn't before, including the Intel RST controls.
  3. Press the Fix button.
Sorry there's more since my last post...
I've tried a couple of other things since then, mainly kb3125574 in the hope it might overwrite some of the problems and a few attempts to get the Diagnostic Policy Service to run (it didn't).
Here's the latest CBS.log.
Lets concentrate on the 2 issues in the file CheckSur.log first.
Please perform the 2 steps given in my previous post.
I'm going to factory restore it today. There's no longer any need to recover the installation as we now have the install files and license for the software.
Thanks for all the help.
Your welcome.
Take care.
