[SOLVED] SURT Corruption Issue. Need Help
The Update will not Install, Error 80070490. I then tried the Windows Update.diagcab to see if that would fix the Error but it did not. I attached the Windows Update Log to show you what issues I am having. If you need anything else please let me know.
Try installing it with DISM:
Install Update with DISM
  1. Download the update MSU here: http://download.windowsupdate.com/c..._71b051d4b2eae12423868e28b0e5b04a9e10c048.msu
    cd C:\temp
    expand windows6.1-kb2894844-x64_71b051d4b2eae12423868e28b0e5b04a9e10c048.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb2894844-x64.cab
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
No Good. See below and
C:\temp>expand windows6.1-kb2894844-x64_71b051d4b2eae12423868e28b0e5b04a9e10c048
.msu -f:* C:\temp
Microsoft (R) File Expansion Utility Version 6.1.7600.16385
Adding C:\temp\WSUSSCAN.cab to Extraction Queue
Adding C:\temp\Windows6.1-KB2894844-x64.cab to Extraction Queue
Adding C:\temp\Windows6.1-KB2894844-x64-pkgProperties.txt to Extraction Queue
Adding C:\temp\Windows6.1-KB2894844-x64.xml to Extraction Queue
Expanding Files ....
Expanding Files Complete ...
4 files total.
C:\temp>DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB2894844-
x64.cab
Version: 6.1.7601.24499
Image Version: 6.1.7601.24499
Processing 1 of 1 -
An error occurred - Package_for_KB2894844 Error: 0x80070490
Error: 1168
Element not found.
Start time: 2020-06-09 18:22:21.843
Using .zip script file at C:\Users\LaPuglia\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\servicing\packages
Successfully copied file C:\Users\LaPuglia\AppData\Local\niemiro\Archive\package_for_kb2894844_sp1~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\servicing\packages\package_for_kb2894844_sp1~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\LaPuglia\AppData\Local\niemiro\Archive\package_for_kb2894844_sp1~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\servicing\packages\package_for_kb2894844_sp1~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully restored ownership for C:\Windows\servicing\packages
Successfully restored permissions on C:\Windows\servicing\packages
Finish time: 2020-06-09 18:22:28.114
Script hash: 0WhrzXt5MbtQdlViVPjz8lIESp6ruAHbAAUashzVVdY=
Retrieve Components Hive
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Filedropper or One Drive or SendSpace and then just provide the link in your reply.
PeterJ,
Hey I Restarted my Laptop to do some Work. 15 mins later Windows Update Pops Up and says it Installed the KBKB2894844-x64 Update... I Re-Ran the SURT again. See attached CheckSUR.Log.
joe_rockstart
,|m|
Did you remove a program recently (that uses the .NET Framework) ?
PeterJ',
Recently I Uninstalled the Following Programs and Reinstalled (2). See below.
Recently Uninstalled:
Structure Studios SE3D
Disk SpeedUp 5.0.1.63
Advanced SystemCare 11
Spotify
RoxioNow Player
PictureMover
Phone to PC 4.1.6.2
Dropbox
Backup and Sync from Google
Autodesk ReCap 2016
KC Softwares RAMExpert
Malwarebytes version 4.1.0.56
Synaptics Touch Pad Driver
AOMEI Backupper Standard (Reinstalled)
Python 3.8 (Reinstalled)
Thanks,
joe_rockstart
,|m|
Please report when you uninstall programs during a fix. It might be confusing for the helper.
  3. Press the Fix button.
PeterJ,
You asked recently. When I think recent, I think the last week or so. I removed the programs previously listed prior to creating this thread. The only item that was Uninstalled was the Windows Update KB2894844. Should I still run the above steps or will they be different since I have not Uninstalled anything in the last (4) days? Please let me know.
Thanks,
joe_rockstar
,|m|
The fix will create a restore point first. Please go ahead with the fix.
Binary Version 6.1.7601.22471
Package Version 26.0
2020-06-11 04:52
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 3882
No errors detected
The log is clean. Any remaining issues ?
PeterJ,
I checked the Turn Windows Features On / Off and and that is working correctly now was well. I appreciate you helping me out.
TY,
joe_rockstar
,|m|
