- May 7, 2013
- 10,406
I forgot to post this, but here's some more information about Symbol Files - DebugInfo.com - Matching debug information
I have the exact same problem.I've been getting errors on every dmp lately
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!KPRCB ***
Anyone have any ideas?
I'm trying to analyze several XP dumps and all fail.Is it aW10 dump, Bruce?
We're all having problems with W10 dumps.
