Symbols could not be loaded for win32k.sys
The missing symbols issue for win32k.sys has been around for a long while.
I didn't get any win32k.sys errors on the batch of dumps from Mike's first post - but I did get ntoskrnl.exe symbol errors on all (so that might prevent the win32k.sys from being picked up)
Got win32k.sys errors on all dumps after upgrading to the latest version of the SysnativeBSODApps.exe
I plan on reinstalling Win8 and the Debugging Tools today - I'll post back if things change.
Any difference in the version of KD being used?
Any difference when using WinDbg? In my case, WinDbg is able to get the ntoskrnl.exe symbols - and then gives me the win32k.sys errors.
Could it be that either kd.exe or the SysnativeBSODApps.exe is causing my ntoskrnl.exe errors - and the symbol server is causing the win32k.sys errors?
As I recall, we had a similar issue a while back (but it was with ntoskrnl.exe - and it was that the binary wasn't on the symbol server, but the symbols were.
To check this, we'll need access to system with the errors and the ability to run the debugger on that system. In that case put the path to win32k.sys into the .exepath
I'd suppose you could do this on your system - but wonder if the differences in the versions would cause issues for your system (or for the dumps that were run). If able to verify versions of win32k.sys you might be able to get away with running any dumps that have the same version - at least to see if it fixes the win32k.sys error. (maybe get them to zip up and upload a copy of their win32k.sys?)
EDIT: Strikeouts are due to the fix in locating ntoskrnl.exe symbol errors on my system.
Any chance of a !sym noisy and logfile for some of these dumps?
DBGENG:  win32k.sys - Partial symbol image load missing image infoDBGHELP: No header for win32k.sys.  Searching for dbg file
DBGHELP: .\win32k.dbg - file not found
DBGHELP: .\sys\win32k.dbg - path not found
DBGHELP: .\symbols\sys\win32k.dbg - path not found
DBGHELP: win32k.sys missing debug info.  Searching for pdb anyway
DBGHELP: Can't use symbol server for win32k.pdb - no header information available
DBGHELP: win32k.pdb - file not found
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
DBGHELP: win32k - no symbols loaded
fffff960`00050000 fffff960`00365000   win32k   [B]win32k.sys   unavailable (00000000)[/B]
fffff960`000b0000 fffff960`003c5000 win32k [B]win32k.sys Mon Jun 11 21:08:09 2012 (4FD6B299)[/B]
I will also supply you with 0.9.9.5 that has the problem fixed for these two cases of win32k.sys:
[LIST=1]
[*][B][COLOR=RED]FIXED[/COLOR][/B] Problem with template loading if template lines are longer than 255 characters
[*][B][COLOR=RED]FIXED[/COLOR][/B] Problem with win32k.sys symbols if the module information is unavailable or timestamp has 08:09 2012 in the timestamp
[/LIST]
Found the email I sent to the symbol server folks back in March of 2010.
I sent a copy of the !symnoisy to them with a request that they have a look at their servers.
Thanks. This may be a local issue for the unavailable case with OPs having an incomplete .dmp or a bad win32k.sys driver.
I am curious to see what they say about the Mon Jun 11 21:08:09 2012 timestamp, though. Let us know if you get any feedback.
I'm not getting win32k.sys symbol errors any more. Using 995 of the app - so I suspect that they're being suppressed.
Anyone else seeing the errors?
Do you still see them for the files in this thread? https://www.sysnative.com/forums/attachment.php?attachmentid=1477&d=1345489187
0.9.9.5 does not suppress the messages. It will still output the message if win32k.sys actually has symbol issues. What it does not do is go online to get symbols if the module list itself already has unavailable for win32k.sys or if it has the 08:09 2012 timestamp since online symbols cannot currently resolve these two issues. I am not sure if online symbols can ever resolve the unavailable case. In those two cases, you should still get messages that win32k.sys symbols could not be verified.
Also, here is a .dmp with the 08:09 2012 timestamp: View attachment 071712-19188-01.zip
Thanks Mike!
I guess that I got lucky in the last few dumps that I've done - no win32k.sys issues
I still see them in the above examples - so it's certain that it's not fixed yet.
I haven't received an email back from the symbol server folks - and as I recall they were very good about emailing me back.
Hmmmmm........
You're welcome :smile9:
I'll check the .dmps included in this thread periodically. I'll run them through WinDbg with online symbols, and then I will update the program accordingly if the symbols are cleared up for the win32k.sys module.
Hopefully the symbol server folks get back to you, too. It would be nice to know whether the issue is on their side or on the OP's side.
Same here - wun32k sym error -
win32k.sys   Mon Jun 11 23:08:09 2012 (4FD6B299)
Windbg:
6: kd> [COLOR="#FF0000"]lmvm win32k[/COLOR]
fffff960`000b0000 fffff960`003c5000   win32k   T (no symbols)
    Loaded symbol image file: win32k.sys
    Image path: \SystemRoot\System32\win32k.sys
    Image name: win32k.sys
    Timestamp:        Mon Jun 11 23:08:09 2012 (4FD6B299)
    CheckSum:         00308196
    ImageSize:        00315000
6: kd> [COLOR="#FF0000"]lml[/COLOR]
fffff800`05c62000 fffff800`0624a000   nt         (pdb symbols)          a:\symbols\ntkrnlmp.pdb\ABD176D2C7AE41B88BBF2837A09A462C2\ntkrnlmp.pdb
6: kd>[COLOR="#FF0000"] !sym noisy[/COLOR]
noisy mode - symbol prompts on
6: kd> [COLOR="#FF0000"].reload [/COLOR]
DBGHELP: a:\symbols\ntoskrnl.exe\4FA390F35e8000\ntoskrnl.exe - OK
DBGENG:  a:\symbols\ntoskrnl.exe\4FA390F35e8000\ntoskrnl.exe - Mapped image memory
DBGHELP: nt - public symbols
Loading Kernel Symbols
SYMSRV:  a:\symbols\halaacpi.dll\4CE7C66949000\halaacpi.dll not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/halaacpi.dll/4CE7C66949000/halaacpi.dll not found
SYMSRV:  a:\symbols\halacpi.dll\4CE7C66949000\halacpi.dll not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/halacpi.dll/4CE7C66949000/halacpi.dll not found
SYMSRV:  a:\symbols\halapic.dll\4CE7C66949000\halapic.dll not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/halapic.dll/4CE7C66949000/halapic.dll not found
SYMSRV:  a:\symbols\halmacpi.dll\4CE7C66949000\halmacpi.dll not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/halmacpi.dll/4CE7C66949000/halmacpi.dll not found
SYMSRV:  a:\symbols\halmps.dll\4CE7C66949000\halmps.dll not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/halmps.dll/4CE7C66949000/halmps.dll not found
DBGHELP: a:\symbols\hal.dll\4CE7C66949000\hal.dll - OK
DBGENG:  a:\symbols\hal.dll\4CE7C66949000\hal.dll - Mapped image memory
DBGHELP: a:\symbols\kdcom.dll\4D4D8061a000\kdcom.dll - OK
DBGENG:  a:\symbols\kdcom.dll\4D4D8061a000\kdcom.dll - Mapped image memory
Loading User Symbols
Loading unloaded module list
6: kd> [COLOR="#FF0000"].reload win32k[/COLOR]
"win32k" was not found in the image list.
Debugger will attempt to load "win32k" at given base 00000000`00000000.
Please provide the full image name, including the extension (i.e. kernel32.dll)
for more reliable results.Base address and size overrides can be given as
.reload <image.ext>=<base>,<size>.
DBGENG:  win32k - Partial symbol image load missing image info
DBGHELP: No header for win32k.  Searching for dbg file
DBGHELP: win32k missing debug info.  Searching for pdb anyway
DBGHELP: win32k_0 - no symbols loaded
Unable to add module at 00000000`00000000
6: kd> [COLOR="#FF0000"]vertarget[/COLOR]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (12 procs) Free x64
Built by: 7601.17835.amd64fre.win7sp1_gdr.120503-2030
Machine Name:
DBGHELP: a:\symbols\srv.sys\4DBA2B1E98000\srv.sys - OK
DBGENG:  a:\symbols\srv.sys\4DBA2B1E98000\srv.sys - Mapped image memory
DBGHELP: srv - public symbols
         a:\symbols\srv.pdb\957B3A5B8F9E4F6C8B9B130B44A459CE2\srv.pdb
Kernel base = 0xfffff800`05c62000 PsLoadedModuleList = 0xfffff800`05ea6670
Debug session time: Tue Jul 17 03:15:30.568 2012 (UTC - 4:00)
System Uptime: 0 days 0:15:14.427
SYMSRV:  a:\symbols\win32k.sys\4FD6B299315000\win32k.sys not found
SYMSRV:  http://msdl.microsoft.com/download/symbols/win32k.sys/4FD6B299315000/win32k.sys not found
DBGHELP: C:\Users\PALMDE~1\AppData\Local\Temp\SAL675.tmp\win32k.sys - file not found
DBGENG:  \SystemRoot\System32\win32k.sys - Image mapping disallowed by non-local path.
fffff960`000b0000 fffff960`003c5000   win32k     (deferred)
    CheckSum:         00308196
    ImageSize:        00315000
6: kd> [COLOR="#FF0000"]lm[/COLOR]
fffff800`05c19000 fffff800`05c62000   hal        (deferred)
fffff800`06408000 fffff800`06412000   kdcom      (deferred)
fffff880`00c00000 fffff880`00c72000   cng        (deferred)
fffff880`00c96000 fffff880`00ce5000   mcupdate_GenuineIntel   (deferred)
fffff880`00ce5000 fffff880`00cf9000   PSHED      (deferred)
fffff880`00cf9000 fffff880`00d57000   CLFS       (deferred)
fffff880`00d57000 fffff880`00d8a000   pci        (deferred)
fffff880`00d8a000 fffff880`00de6000   volmgrx    (deferred)
fffff880`00e00000 fffff880`00ea4000   Wdf01000   (deferred)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR     (deferred)
fffff880`00eb3000 fffff880`00ec0000   vdrvroot   (deferred)
fffff880`00ed1000 fffff880`00f91000   CI         (deferred)
fffff880`00f91000 fffff880`00fe8000   ACPI       (deferred)
fffff880`00fe8000 fffff880`00ff1000   WMILIB     (deferred)
fffff880`00ff1000 fffff880`00ffb000   msisadrv   (deferred)
fffff880`01000000 fffff880`0102a000   ataport    (deferred)
fffff880`0102b000 fffff880`0178a000   kl1        (deferred)
fffff880`0178a000 fffff880`0179f000   partmgr    (deferred)
fffff880`0179f000 fffff880`017b4000   volmgr     (deferred)
fffff880`017b4000 fffff880`017b5e00   AiChargerPlus   (deferred)
fffff880`017b6000 fffff880`017d0000   mountmgr   (deferred)
fffff880`017d0000 fffff880`017d9000   atapi      (deferred)
fffff880`017d9000 fffff880`017e4000   msahci     (deferred)
fffff880`017e4000 fffff880`017f4000   PCIIDEX    (deferred)
fffff880`01800000 fffff880`0185e000   msrpc      (deferred)
fffff880`0185e000 fffff880`01879000   raspppoe   (deferred)
fffff880`01879000 fffff880`0189a000   raspptp    (deferred)
fffff880`0189a000 fffff880`018b4000   rassstp    (deferred)
fffff880`018b7000 fffff880`048bb000   iaStorA    (deferred)
fffff880`048bb000 fffff880`0491e000   storport   (deferred)
fffff880`0491e000 fffff880`0492a000   asahci64   (deferred)
fffff880`0492a000 fffff880`04935000   amdxata    (deferred)
fffff880`04935000 fffff880`04981000   fltmgr     (deferred)
fffff880`04981000 fffff880`04995000   fileinfo   (deferred)
fffff880`04995000 fffff880`049c3000   symsnap    (deferred)
fffff880`04a00000 fffff880`04a1b000   ksecdd     (deferred)
fffff880`04a1b000 fffff880`04a2c000   pcw        (deferred)
fffff880`04a2c000 fffff880`04a36000   Fs_Rec     (deferred)
fffff880`04a36000 fffff880`04a48000   umbus      (deferred)
fffff880`04a4b000 fffff880`04bee000   Ntfs       (deferred)
fffff880`04c07000 fffff880`04cfa000   ndis       (deferred)
fffff880`04cfa000 fffff880`04d5a000   NETIO      (deferred)
fffff880`04d5a000 fffff880`04d84000   ksecpkg    (deferred)
fffff880`04d84000 fffff880`04de8000   asmtxhci   (deferred)
fffff880`04de8000 fffff880`04df7000   mouclass   (deferred)
fffff880`04e00000 fffff880`04e3a000   fvevol     (deferred)
fffff880`04e3a000 fffff880`04e50000   disk       (deferred)
fffff880`04e50000 fffff880`04e80000   CLASSPNP   (deferred)
fffff880`04e98000 fffff880`04ebc000   rasl2tp    (deferred)
fffff880`04ebc000 fffff880`04ecb000   kbdclass   (deferred)
fffff880`04ed1000 fffff880`050d4000   tcpip      (deferred)
fffff880`050d4000 fffff880`0511e000   fwpkclnt   (deferred)
fffff880`0511e000 fffff880`0516a000   volsnap    (deferred)
fffff880`0516a000 fffff880`05172000   spldr      (deferred)
fffff880`05172000 fffff880`051ac000   rdyboost   (deferred)
fffff880`051ac000 fffff880`051be000   mup        (deferred)
fffff880`051be000 fffff880`051c7000   iaStorF    (deferred)
fffff880`051c7000 fffff880`051d0000   hwpolicy   (deferred)
fffff880`051d0000 fffff880`051ff000   ndiswan    (deferred)
fffff880`07c00000 fffff880`07c51000   rdbss      (deferred)
fffff880`07c51000 fffff880`07c5d000   nsiproxy   (deferred)
fffff880`07c5d000 fffff880`07c68000   mssmbios   (deferred)
fffff880`07c68000 fffff880`07c77000   discache   (deferred)
fffff880`07c79000 fffff880`07d02000   afd        (deferred)
fffff880`07d02000 fffff880`07d47000   netbt      (deferred)
fffff880`07d47000 fffff880`07d50000   wfplwf     (deferred)
fffff880`07d50000 fffff880`07d76000   pacer      (deferred)
fffff880`07d76000 fffff880`07d7f000   klim6      (deferred)
fffff880`07d7f000 fffff880`07d8e000   netbios    (deferred)
fffff880`07d8e000 fffff880`07da9000   wanarp     (deferred)
fffff880`07da9000 fffff880`07dbd000   termdd     (deferred)
fffff880`07dbd000 fffff880`07ddb000   dfsc       (deferred)
fffff880`07ddb000 fffff880`07dec000   blbdrive   (deferred)
fffff880`07dec000 fffff880`07df3000   AsUpIO     (deferred)
fffff880`07df3000 fffff880`07df9000   AsIO       (deferred)
fffff880`08000000 fffff880`08031000   ctoss2k    (deferred)
fffff880`08031000 fffff880`08039000   ctprxy2k   (deferred)
fffff880`08039000 fffff880`0803e200   ksthunk    (deferred)
fffff880`0803f000 fffff880`08095000   USBPORT    (deferred)
fffff880`08095000 fffff880`080a2000   tap0901    (deferred)
fffff880`080a9000 fffff880`08151b80   ctaud2k    (deferred)
fffff880`08152000 fffff880`0818f000   portcls    (deferred)
fffff880`0818f000 fffff880`081b1000   drmk       (deferred)
fffff880`081b1000 fffff880`081f4000   ks         (deferred)
fffff880`081f4000 fffff880`081ff000   btath_bus   (deferred)
fffff880`08200000 fffff880`08257000   e1c62x64   (deferred)
fffff880`0825c000 fffff880`08350000   dxgkrnl    (deferred)
fffff880`08350000 fffff880`08396000   dxgmms1    (deferred)
fffff880`08396000 fffff880`083ba000   HDAudBus   (deferred)
fffff880`083ba000 fffff880`083cb000   HECIx64    (deferred)
fffff880`083cb000 fffff880`083dc000   usbehci    (deferred)
fffff880`083dc000 fffff880`083e9000   GEARAspiWDM   (deferred)
fffff880`083e9000 fffff880`083f5000   ICCWDT     (deferred)
fffff880`083f5000 fffff880`083fe000   wmiacpi    (deferred)
fffff880`083fe000 fffff880`083ff480   swenum     (deferred)
fffff880`08637000 fffff880`08691000   usbhub     (deferred)
fffff880`08691000 fffff880`086a6000   NDProxy    (deferred)
fffff880`086a6000 fffff880`08702000   HdAudio    (deferred)
fffff880`08702000 fffff880`08738000   fastfat    (deferred)
fffff880`08738000 fffff880`08770000   ctsfm2k    (deferred)
fffff880`08770000 fffff880`087ad000   CT20XUT    (deferred)
fffff880`087ad000 fffff880`087c5000   BTHUSB     (deferred)
fffff880`087c5000 fffff880`087e9e00   btath_rcp   (deferred)
fffff880`08c92000 fffff880`08cf9000   btath_a2dp   (deferred)
fffff880`08cf9000 fffff880`08d5c000   btath_hcrp   (deferred)
fffff880`08d5c000 fffff880`08d6b000   btath_flt   (deferred)
fffff880`08d6b000 fffff880`08d7e000   btath_lwflt   (deferred)
fffff880`08d7e000 fffff880`08da1000   luafv      (deferred)
fffff880`08da1000 fffff880`08db6000   lltdio     (deferred)
fffff880`08db6000 fffff880`08dce000   rspndr     (deferred)
fffff880`08e00000 fffff880`08e4a000   emupia2k   (deferred)
fffff880`08e57000 fffff880`08fe4000   ha20x22k   (deferred)
fffff880`08fe4000 fffff880`09000000   CTHWIUT    (deferred)
fffff880`0920e000 fffff880`09372000   CTEXFIFX   (deferred)
fffff880`09372000 fffff880`09396000   asmthub3   (deferred)
fffff880`09396000 fffff880`093a4000   ASUSFILTER   (deferred)
fffff880`093a4000 fffff880`093ec000   btfilter   (deferred)
fffff880`09400000 fffff880`0942c000   rfcomm     (deferred)
fffff880`0942c000 fffff880`0943c000   BthEnum    (deferred)
fffff880`0943c000 fffff880`0945c000   bthpan     (deferred)
fffff880`0945c000 fffff880`09473000   bthmodem   (deferred)
fffff880`09483000 fffff880`0950f000   bthport    (deferred)
fffff880`0950f000 fffff880`09510f00   USBD       (deferred)
fffff880`09511000 fffff880`0952e000   cdfs       (deferred)
fffff880`0952e000 fffff880`0953a000   Dxapi      (deferred)
fffff880`0953a000 fffff880`09548000   crashdmp   (deferred)
fffff880`09548000 fffff880`09552000   dump_diskdump   (deferred)
fffff880`09552000 fffff880`09565000   dump_dumpfve   (deferred)
fffff880`09565000 fffff880`09582000   usbccgp    (deferred)
fffff880`09582000 fffff880`09590000   hidusb     (deferred)
fffff880`09590000 fffff880`095a9000   HIDCLASS   (deferred)
fffff880`095a9000 fffff880`095b1080   HIDPARSE   (deferred)
fffff880`095b2000 fffff880`095bf000   mouhid     (deferred)
fffff880`095bf000 fffff880`095c9000   klmouflt   (deferred)
fffff880`095c9000 fffff880`095d7000   kbdhid     (deferred)
fffff880`095d7000 fffff880`095e5000   monitor    (deferred)
fffff880`0ac00000 fffff880`0ac4e000   mrxsmb10   (deferred)
fffff880`0ac4e000 fffff880`0ac72000   mrxsmb20   (deferred)
fffff880`0acb2000 fffff880`0ad7b000   HTTP       (deferred)
fffff880`0ad7b000 fffff880`0ad99000   bowser     (deferred)
fffff880`0ad99000 fffff880`0adb1000   mpsdrv     (deferred)
fffff880`0adb1000 fffff880`0adde000   mrxsmb     (deferred)
fffff880`0bc00000 fffff880`0bc69000   srv2       (deferred)
fffff880`0bcb4000 fffff880`0bd5a000   peauth     (deferred)
fffff880`0bd5a000 fffff880`0bd65000   secdrv     (deferred)
fffff880`0bd65000 fffff880`0bd96000   srvnet     (deferred)
fffff880`0bd96000 fffff880`0bda8000   tcpipreg   (deferred)
fffff880`0be58000 fffff880`0bef0000   srv        (pdb symbols)          a:\symbols\srv.pdb\957B3A5B8F9E4F6C8B9B130B44A459CE2\srv.pdb
fffff880`0bef0000 fffff880`0bf61000   spsys      (deferred)
fffff880`0bf61000 fffff880`0bf62f80   MSTEE      (deferred)
fffff880`0bf63000 fffff880`0bf65b80   MSKSSRV    (deferred)
fffff880`12800000 fffff880`12810000   watchdog   (deferred)
fffff880`12810000 fffff880`12819000   RDPCDD     (deferred)
fffff880`12819000 fffff880`12822000   rdpencdd   (deferred)
fffff880`12822000 fffff880`1282b000   rdprefmp   (deferred)
fffff880`1282b000 fffff880`12836000   Msfs       (deferred)
fffff880`12836000 fffff880`12847000   Npfs       (deferred)
fffff880`12847000 fffff880`12869000   tdx        (deferred)
fffff880`12869000 fffff880`12876000   TDI        (deferred)
fffff880`12876000 fffff880`1287d000   kl2        (deferred)
fffff880`1287d000 fffff880`128a3000   tunnel     (deferred)
fffff880`128a3000 fffff880`128b9000   GenericMount   (deferred)
fffff880`128b9000 fffff880`128cf000   AgileVpn   (deferred)
fffff880`128cf000 fffff880`158d3000   dump_iaStorA   (deferred)
fffff880`158f3000 fffff880`1591d000   cdrom      (deferred)
fffff880`1591d000 fffff880`159b3000   klif       (deferred)
fffff880`159b3000 fffff880`159bc000   Null       (deferred)
fffff880`159bc000 fffff880`159c3000   Beep       (deferred)
fffff880`159c3000 fffff880`159d1000   vga        (deferred)
fffff880`159d1000 fffff880`159f6000   VIDEOPRT   (deferred)
fffff880`15a00000 fffff880`15a10000   CompositeBus   (deferred)
fffff880`15a10000 fffff880`15a1b000   rdpbus     (deferred)
fffff880`15a1b000 fffff880`167dd000   nvlddmkm   (deferred)
fffff880`167dd000 fffff880`167f3000   intelppm   (deferred)
fffff880`167f3000 fffff880`167ff000   ndistapi   (deferred)
fffff960`00460000 fffff960`0046a000   TSDDD      (deferred)
fffff960`00660000 fffff960`00687000   cdd        (deferred)
Unloaded modules:
fffff880`04e80000 fffff880`04e8e000   crashdmp.sys
fffff880`04e8e000 fffff880`04e98000   dump_storpor
fffff880`128dc000 fffff880`158e0000   dump_iaStorA
fffff880`158e0000 fffff880`158f3000   dump_dumpfve
These 2 security related drivers & a few other MS showing sym errors too.
https://www.sysnative.com/drivers/driver.php?id=spldr.sys
https://www.sysnative.com/drivers/driver.php?id=secdrv.sys
6: kd> [COLOR="#FF0000"]!for_each_module !chkimg @#ModuleName [/COLOR]
0 errors : hal
0 errors : nt
0 errors : kdcom
0 errors : cng
0 errors : mcupdate_GenuineIntel
0 errors : PSHED
0 errors : CLFS
0 errors : pci
0 errors : volmgrx
0 errors : Wdf01000
0 errors : WDFLDR
0 errors : vdrvroot
0 errors : CI
0 errors : ACPI
0 errors : WMILIB
0 errors : msisadrv
0 errors : ataport
Error for kl1: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : partmgr
0 errors : volmgr
Error for AiChargerPlus: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : mountmgr
0 errors : atapi
0 errors : msahci
0 errors : PCIIDEX
0 errors : msrpc
0 errors : raspppoe
0 errors : raspptp
0 errors : rassstp
Error for iaStorA: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : storport
Error for asahci64: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for amdxata: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : fltmgr
0 errors : fileinfo
Error for symsnap: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : ksecdd
0 errors : pcw
0 errors : Fs_Rec
0 errors : umbus
0 errors : Ntfs
0 errors : ndis
0 errors : NETIO
0 errors : ksecpkg
Error for asmtxhci: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : mouclass
0 errors : fvevol
0 errors : disk
0 errors : CLASSPNP
0 errors : rasl2tp
0 errors : kbdclass
0 errors : tcpip
0 errors : fwpkclnt
0 errors : volsnap
[COLOR="#FF0000"]Error for spldr: Could not find image file for the module. Make sure binaries are included in the symbol path.[/COLOR]
0 errors : rdyboost
0 errors : mup
Error for iaStorF: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : hwpolicy
0 errors : ndiswan
0 errors : rdbss
0 errors : nsiproxy
0 errors : mssmbios
0 errors : discache
Error for afd: Could not find module base
0 errors : netbt
0 errors : wfplwf
0 errors : pacer
Error for klim6: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : netbios
0 errors : wanarp
0 errors : termdd
0 errors : dfsc
0 errors : blbdrive
Error for AsUpIO: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for AsIO: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ctoss2k: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ctprxy2k: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : ksthunk
0 errors : USBPORT
Error for tap0901: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ctaud2k: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : portcls
Error for drmk: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : ks
Error for btath_bus: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for e1c62x64: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : dxgkrnl
0 errors : dxgmms1
0 errors : HDAudBus
Error for HECIx64: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : usbehci
Error for GEARAspiWDM: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ICCWDT: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : wmiacpi
0 errors : swenum
0 errors : usbhub
0 errors : NDProxy
0 errors : HdAudio
0 errors : fastfat
Error for ctsfm2k: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for CT20XUT: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : BTHUSB
Error for btath_rcp: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for btath_a2dp: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for btath_hcrp: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for btath_flt: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for btath_lwflt: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : luafv
0 errors : lltdio
0 errors : rspndr
Error for emupia2k: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ha20x22k: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for CTHWIUT: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for CTEXFIFX: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for asmthub3: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for ASUSFILTER: Could not find image file for the module. Make sure binaries are included in the symbol path.
Error for btfilter: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : rfcomm
0 errors : BthEnum
0 errors : bthpan
0 errors : bthmodem
0 errors : bthport
0 errors : USBD
0 errors : cdfs
0 errors : Dxapi
0 errors : crashdmp
0 errors : dump_diskdump
0 errors : dump_dumpfve
0 errors : usbccgp
0 errors : hidusb
0 errors : HIDCLASS
0 errors : HIDPARSE
0 errors : mouhid
Error for klmouflt: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : kbdhid
0 errors : monitor
0 errors : mrxsmb10
0 errors : mrxsmb20
0 errors : HTTP
0 errors : bowser
0 errors : mpsdrv
0 errors : mrxsmb
0 errors : srv2
Error for peauth: Could not find image file for the module. Make sure binaries are included in the symbol path.
[COLOR="#FF0000"]Error for secdrv: Could not find image file for the module. Make sure binaries are included in the symbol path.[/COLOR]
0 errors : srvnet
0 errors : tcpipreg
0 errors : srv
Error for spsys: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : MSTEE
0 errors : MSKSSRV
0 errors : watchdog
0 errors : RDPCDD
0 errors : rdpencdd
0 errors : rdprefmp
0 errors : Msfs
0 errors : Npfs
0 errors : tdx
0 errors : TDI
Error for kl2: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : tunnel
Error for GenericMount: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : AgileVpn
Error for dump_iaStorA: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : cdrom
Error for klif: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : Null
0 errors : Beep
0 errors : vga
0 errors : VIDEOPRT
0 errors : CompositeBus
0 errors : rdpbus
Error for nvlddmkm: Could not find image file for the module. Make sure binaries are included in the symbol path.
0 errors : intelppm
0 errors : ndistapi
[COLOR="#FF0000"]Error for win32k: Could not find image file for the module. Make sure binaries are included in the symbol path.[/COLOR]
0 errors : TSDDD
Error for cdd: Could not find module base
Ask OP to check Device Manager, show hidden devices, non PnP
Would be iinteresting to know if red/yellow flags are present.
Yeah, I have also noticed other system drivers have unavailable next to them when win32k.sys does. CDD.dll was one in a .dmp I scrutinized at one point.
fffff880`05d9e000 fffff880`05ddc000   1394ohci 1394ohci.sys Sat Nov 20 03:44:56 2010 (4CE7A6A8)
fffff880`048aa000 fffff880`048b6000   Acceler  Acceler.sys  Fri Jun 26 14:56:34 2009 (4A453602)
fffff880`00f79000 fffff880`00fd0000   ACPI     ACPI.sys     Sat Nov 20 02:19:16 2010 (4CE79294)
fffff880`02c00000 fffff880`02c89000   afd      afd.sys      Tue Dec 27 20:59:20 2011 (4EFA9418)
fffff880`04fc0000 fffff880`04fd6000   AgileVpn AgileVpn.sys Mon Jul 13 18:10:24 2009 (4A5BCCF0)
fffff880`00df2000 fffff880`00dfd000   amdxata  amdxata.sys  Fri Mar 19 10:18:18 2010 (4BA3A3CA)
fffff880`00c76000 fffff880`00c7f000   atapi    atapi.sys    Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`00dbd000 fffff880`00de7000   ataport  ataport.SYS  Sat Nov 20 02:19:15 2010 (4CE79293)
fffff880`051ad000 fffff880`051c8000   AtihdW76 AtihdW76.sys Fri May 11 02:25:40 2012 (4FACCD04)
fffff880`048e4000 fffff880`04fc0000   atikmdag atikmdag.sys Tue Jun 01 19:37:54 2010 (4C05B5F2)
fffff880`03a00000 fffff880`03a46000   atikmpag atikmpag.sys Tue Jun 01 19:42:47 2010 (4C05B717)
[B][COLOR=#FF0000]fffff960`00970000 fffff960`009d1000   ATMFD    ATMFD.DLL    unavailable (00000000)[/COLOR][/B]
fffff880`00d9c000 fffff880`00da8000   BATTC    BATTC.SYS    Mon Jul 13 17:31:01 2009 (4A5BC3B5)
fffff880`015f0000 fffff880`015f7000   Beep     Beep.SYS     Mon Jul 13 18:00:13 2009 (4A5BCA8D)
fffff880`03b88000 fffff880`03b99000   blbdrive blbdrive.sys Mon Jul 13 17:35:59 2009 (4A5BC4DF)
fffff880`062eb000 fffff880`06309000   bowser   bowser.sys   Tue Feb 22 21:55:04 2011 (4D649328)
fffff880`082f3000 fffff880`08303000   BthEnum  BthEnum.sys  Mon Jul 13 18:06:52 2009 (4A5BCC1C)
fffff880`08303000 fffff880`08323000   bthpan   bthpan.sys   Mon Jul 13 18:07:00 2009 (4A5BCC24)
fffff880`08231000 fffff880`082bd000   bthport  bthport.sys  Fri Jul 06 14:07:41 2012 (4FF7458D)
fffff880`063c0000 fffff880`063d8000   BTHUSB   BTHUSB.sys   Wed Apr 27 21:54:56 2011 (4DB8E510)
fffff880`0835d000 fffff880`083e3000   btwaudio btwaudio.sys Wed Jul 01 07:54:56 2009 (4A4B6AB0)
fffff880`08800000 fffff880`0887b000   btwavdt  btwavdt.sys  Wed Jun 24 23:50:13 2009 (4A431015)
fffff880`0887b000 fffff880`08887000   btwl2cap btwl2cap.sys Fri Apr 03 18:28:45 2009 (49D6A9BD)
fffff880`08887000 fffff880`0888a880   btwrchid btwrchid.sys Wed Jun 24 23:51:37 2009 (4A431069)
[B][COLOR=#FF0000]fffff960`00750000 fffff960`00777000   cdd      cdd.dll      unavailable (00000000)[/color][/b]
fffff880`01000000 fffff880`0102a000   cdrom    cdrom.sys    Sat Nov 20 02:19:20 2010 (4CE79298)
fffff880`00e06000 fffff880`00ec6000   CI       CI.dll       Sat Nov 20 06:12:36 2010 (4CE7C944)
fffff880`019c0000 fffff880`019f0000   CLASSPNP CLASSPNP.SYS Sat Nov 20 02:19:23 2010 (4CE7929B)
fffff880`00cf6000 fffff880`00d54000   CLFS     CLFS.SYS     Mon Jul 13 17:19:57 2009 (4A5BC11D)
fffff880`05dfa000 fffff880`05dfe500   CmBatt   CmBatt.sys   Mon Jul 13 17:31:03 2009 (4A5BC3B7)
fffff880`014fa000 fffff880`0156c000   cng      cng.sys      Fri Jun 01 21:25:51 2012 (4FC987BF)
fffff880`00ff0000 fffff880`00ff9000   compbatt compbatt.sys Mon Jul 13 17:31:02 2009 (4A5BC3B6)
fffff880`048cc000 fffff880`048dc000   CompositeBus CompositeBus.sys Sat Nov 20 03:33:17 2010 (4CE7A3ED)
fffff880`01f3e000 fffff880`01f4c000   crashdmp crashdmp.sys Mon Jul 13 18:01:01 2009 (4A5BCABD)
fffff880`01f13000 fffff880`01f3d2a0   CtClsFlt CtClsFlt.sys Sun Jun 14 23:06:41 2009 (4A35D6E1)
fffff880`03b6a000 fffff880`03b88000   dfsc     dfsc.sys     Sat Nov 20 02:26:31 2010 (4CE79447)
fffff880`03b5b000 fffff880`03b6a000   discache discache.sys Mon Jul 13 17:37:18 2009 (4A5BC52E)
fffff880`019aa000 fffff880`019c0000   disk     disk.sys     Mon Jul 13 17:19:57 2009 (4A5BC11D)
fffff880`0503d000 fffff880`0505f000   drmk     drmk.sys     Mon Jul 13 19:01:25 2009 (4A5BD8E5)
fffff880`01f4c000 fffff880`01f58000   dump_dumpata dump_dumpata.sys Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`01f63000 fffff880`01f76000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 17:21:51 2009 (4A5BC18F)
fffff880`01f58000 fffff880`01f63000   dump_msahci dump_msahci.sys Sat Nov 20 03:33:58 2010 (4CE7A416)
fffff880`02cce000 fffff880`02cda000   Dxapi    Dxapi.sys    Mon Jul 13 17:38:28 2009 (4A5BC574)
fffff880`0406a000 fffff880`0415e000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 02:50:50 2010 (4CE799FA)
fffff880`0415e000 fffff880`041a4000   dxgmms1  dxgmms1.sys  Sat Nov 20 02:49:53 2010 (4CE799C1)
fffff880`09000000 fffff880`09036000   fastfat  fastfat.SYS  Mon Jul 13 17:23:28 2009 (4A5BC1F0)
fffff880`01099000 fffff880`010ad000   fileinfo fileinfo.sys Mon Jul 13 17:34:25 2009 (4A5BC481)
fffff880`0104d000 fffff880`01099000   fltmgr   fltmgr.sys   Sat Nov 20 02:19:24 2010 (4CE7929C)
fffff880`0157d000 fffff880`01587000   Fs_Rec   Fs_Rec.sys   Wed Feb 29 20:41:06 2012 (4F4EEFD2)
fffff880`01970000 fffff880`019aa000   fvevol   fvevol.sys   Sat Nov 20 02:24:06 2010 (4CE793B6)
fffff880`01831000 fffff880`0187b000   fwpkclnt fwpkclnt.sys Sat Nov 20 02:21:37 2010 (4CE79321)
fffff880`041ea000 fffff880`041f7000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 06:17:04 2009 (4A1151C0)
fffff800`03204000 fffff800`0324d000   hal      hal.dll      Sat Nov 20 06:00:25 2010 (4CE7C669)
fffff880`041a4000 fffff880`041c8000   HDAudBus HDAudBus.sys Sat Nov 20 03:43:42 2010 (4CE7A65E)
fffff880`041c8000 fffff880`041d9000   HECIx64  HECIx64.sys  Thu Sep 17 13:54:16 2009 (4AB293E8)
fffff880`0833f000 fffff880`0835d000   hidbth   hidbth.sys   Mon Jul 13 18:06:52 2009 (4A5BCC1C)
fffff880`051d6000 fffff880`051ef000   HIDCLASS HIDCLASS.SYS Sat Nov 20 03:43:49 2010 (4CE7A665)
fffff880`051ef000 fffff880`051f7080   HIDPARSE HIDPARSE.SYS Mon Jul 13 18:06:17 2009 (4A5BCBF9)
fffff880`051c8000 fffff880`051d6000   hidusb   hidusb.sys   Sat Nov 20 03:43:49 2010 (4CE7A665)
fffff880`06222000 fffff880`062eb000   HTTP     HTTP.sys     Sat Nov 20 02:24:30 2010 (4CE793CE)
fffff880`01967000 fffff880`01970000   hwpolicy hwpolicy.sys Sat Nov 20 02:18:54 2010 (4CE7927E)
fffff880`05ddc000 fffff880`05dfa000   i8042prt i8042prt.sys Mon Jul 13 17:19:57 2009 (4A5BC11D)
fffff880`04885000 fffff880`048a9e00   Impcd    Impcd.sys    Mon Oct 12 20:00:51 2009 (4AD3DF53)
fffff880`048b6000 fffff880`048cc000   intelppm intelppm.sys Mon Jul 13 17:19:25 2009 (4A5BC0FD)
fffff880`05600000 fffff880`0560f000   kbdclass kbdclass.sys Mon Jul 13 17:19:50 2009 (4A5BC116)
fffff880`03ae4000 fffff880`03af2000   kbdhid   kbdhid.sys   Sat Nov 20 03:33:25 2010 (4CE7A3F5)
fffff800`00b9e000 fffff800`00ba8000   kdcom    kdcom.dll    Sat Feb 05 09:52:49 2011 (4D4D8061)
fffff880`050e9000 fffff880`0512c000   ks       ks.sys       Sat Nov 20 03:33:23 2010 (4CE7A3F3)
fffff880`013d8000 fffff880`013f3000   ksecdd   ksecdd.sys   Fri Jun 01 20:50:23 2012 (4FC97F6F)
fffff880`01200000 fffff880`0122a000   ksecpkg  ksecpkg.sys  Fri Jun 01 21:27:11 2012 (4FC9880F)
fffff880`0505f000 fffff880`05064200   ksthunk  ksthunk.sys  Mon Jul 13 18:00:19 2009 (4A5BCA93)
fffff880`0888b000 fffff880`0889e000   LHidFilt LHidFilt.Sys Wed Jun 17 10:49:39 2009 (4A391EA3)
fffff880`01fc8000 fffff880`01fdd000   lltdio   lltdio.sys   Mon Jul 13 18:08:50 2009 (4A5BCC92)
fffff880`0889e000 fffff880`088b2000   LMouFilt LMouFilt.Sys Wed Jun 17 10:49:43 2009 (4A391EA7)
fffff880`01f84000 fffff880`01fa7000   luafv    luafv.sys    Mon Jul 13 17:26:13 2009 (4A5BC295)
fffff880`00c93000 fffff880`00ce2000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 06:03:51 2010 (4CE7C737)
fffff880`091db000 fffff880`091ffe00   mfeapfk  mfeapfk.sys  Fri Aug 26 14:45:37 2011 (4E5805F1)
fffff880`03bbf000 fffff880`03bf4e00   mfeavfk  mfeavfk.sys  Fri Aug 26 14:46:03 2011 (4E58060B)
fffff880`010e2000 fffff880`0117c680   mfehidk  mfehidk.sys  Fri Aug 26 14:44:44 2011 (4E5805BC)
fffff880`0187b000 fffff880`018be380   mfewfpk  mfewfpk.sys  Fri Aug 26 14:45:00 2011 (4E5805CC)
fffff880`01f76000 fffff880`01f84000   monitor  monitor.sys  Mon Jul 13 17:38:52 2009 (4A5BC58C)
fffff880`04056000 fffff880`04065000   mouclass mouclass.sys Mon Jul 13 17:19:50 2009 (4A5BC116)
fffff880`03ad7000 fffff880`03ae4000   mouhid   mouhid.sys   Mon Jul 13 18:00:20 2009 (4A5BCA94)
fffff880`00c5c000 fffff880`00c76000   mountmgr mountmgr.sys Sat Nov 20 02:19:21 2010 (4CE79299)
fffff880`010ad000 fffff880`010e2000   MpFilter MpFilter.sys Fri Mar 09 04:05:26 2012 (4F59E3F6)
fffff880`06309000 fffff880`06321000   mpsdrv   mpsdrv.sys   Mon Jul 13 18:08:25 2009 (4A5BCC79)
fffff880`06321000 fffff880`0634e000   mrxsmb   mrxsmb.sys   Tue Apr 26 20:40:38 2011 (4DB78226)
fffff880`0634e000 fffff880`0639c000   mrxsmb10 mrxsmb10.sys Fri Jul 08 20:46:28 2011 (4E17C104)
fffff880`0639c000 fffff880`063c0000   mrxsmb20 mrxsmb20.sys Tue Apr 26 20:39:37 2011 (4DB781E9)
fffff880`00de7000 fffff880`00df2000   msahci   msahci.sys   Sat Nov 20 03:33:58 2010 (4CE7A416)
fffff880`02d2b000 fffff880`02d36000   Msfs     Msfs.SYS     Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`00fd9000 fffff880`00fe3000   msisadrv msisadrv.sys Mon Jul 13 17:19:26 2009 (4A5BC0FE)
fffff880`01189000 fffff880`011e7000   msrpc    msrpc.sys    Sat Nov 20 02:21:56 2010 (4CE79334)
fffff880`03b50000 fffff880`03b5b000   mssmbios mssmbios.sys Mon Jul 13 17:31:10 2009 (4A5BC3BE)
fffff880`01955000 fffff880`01967000   mup      mup.sys      Mon Jul 13 17:23:45 2009 (4A5BC201)
fffff880`01400000 fffff880`014f3000   ndis     ndis.sys     Sat Nov 20 02:23:30 2010 (4CE79392)
fffff880`03a46000 fffff880`03a52000   ndistapi ndistapi.sys Mon Jul 13 18:10:00 2009 (4A5BCCD8)
fffff880`01e53000 fffff880`01e66000   ndisuio  ndisuio.sys  Sat Nov 20 03:50:08 2010 (4CE7A7E0)
fffff880`03a52000 fffff880`03a81000   ndiswan  ndiswan.sys  Sat Nov 20 03:52:32 2010 (4CE7A870)
fffff880`05198000 fffff880`051ad000   NDProxy  NDProxy.SYS  Sat Nov 20 03:52:20 2010 (4CE7A864)
fffff880`02dbb000 fffff880`02dca000   netbios  netbios.sys  Mon Jul 13 18:09:26 2009 (4A5BCCB6)
fffff880`02d76000 fffff880`02dbb000   netbt    netbt.sys    Sat Nov 20 02:23:18 2010 (4CE79386)
fffff880`01587000 fffff880`015e7000   NETIO    NETIO.SYS    Sat Nov 20 02:23:13 2010 (4CE79381)
fffff880`0565c000 fffff880`05d09000   NETw5s64 NETw5s64.sys Tue Sep 15 13:40:39 2009 (4AAFEDB7)
fffff880`08323000 fffff880`0833f000   NisDrvWFP NisDrvWFP.sys Fri Mar 09 04:05:35 2012 (4F59E3FF)
fffff880`02d36000 fffff880`02d47000   Npfs     Npfs.SYS     Mon Jul 13 17:19:48 2009 (4A5BC114)
fffff880`03b44000 fffff880`03b50000   nsiproxy nsiproxy.sys Mon Jul 13 17:21:02 2009 (4A5BC15E)
fffff800`0324d000 fffff800`03835000   nt       ntkrnlmp.exe Fri May 04 02:18:59 2012 (4FA390F3)
fffff880`01235000 fffff880`013d8000   Ntfs     Ntfs.sys     Thu Mar 10 20:39:39 2011 (4D79997B)
fffff880`015e7000 fffff880`015f0000   Null     Null.SYS     Mon Jul 13 17:19:37 2009 (4A5BC109)
fffff880`01e00000 fffff880`01e53000   nwifi    nwifi.sys    Mon Jul 13 18:07:23 2009 (4A5BCC3B)
fffff880`02c92000 fffff880`02cb8000   pacer    pacer.sys    Sat Nov 20 03:52:18 2010 (4CE7A862)
fffff880`00d87000 fffff880`00d9c000   partmgr  partmgr.sys  Fri Mar 16 23:06:09 2012 (4F641BC1)
fffff880`00d54000 fffff880`00d87000   pci      pci.sys      Sat Nov 20 02:19:11 2010 (4CE7928F)
fffff880`00c7f000 fffff880`00c8f000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 17:19:48 2009 (4A5BC114)
fffff880`0156c000 fffff880`0157d000   pcw      pcw.sys      Mon Jul 13 17:19:27 2009 (4A5BC0FF)
fffff880`088e6000 fffff880`0898c000   peauth   peauth.sys   Mon Jul 13 19:01:19 2009 (4A5BD8DF)
fffff880`05000000 fffff880`0503d000   portcls  portcls.sys  Mon Jul 13 18:06:27 2009 (4A5BCC03)
fffff880`00ce2000 fffff880`00cf6000   PSHED    PSHED.dll    Mon Jul 13 19:32:23 2009 (4A5BE027)
fffff880`0117d000 fffff880`01188e00   PxHlpa64 PxHlpa64.sys Tue Jun 23 17:16:35 2009 (4A416253)
fffff880`04fd6000 fffff880`04ffa000   rasl2tp  rasl2tp.sys  Sat Nov 20 03:52:34 2010 (4CE7A872)
fffff880`03a81000 fffff880`03a9c000   raspppoe raspppoe.sys Mon Jul 13 18:10:17 2009 (4A5BCCE9)
fffff880`03a9c000 fffff880`03abd000   raspptp  raspptp.sys  Sat Nov 20 03:52:31 2010 (4CE7A86F)
fffff880`03abd000 fffff880`03ad7000   rassstp  rassstp.sys  Mon Jul 13 18:10:25 2009 (4A5BCCF1)
fffff880`03af3000 fffff880`03b44000   rdbss    rdbss.sys    Sat Nov 20 02:27:51 2010 (4CE79497)
fffff880`02d10000 fffff880`02d19000   RDPCDD   RDPCDD.sys   Mon Jul 13 18:16:34 2009 (4A5BCE62)
fffff880`02d19000 fffff880`02d22000   rdpencdd rdpencdd.sys Mon Jul 13 18:16:34 2009 (4A5BCE62)
fffff880`02d22000 fffff880`02d2b000   rdprefmp rdprefmp.sys Mon Jul 13 18:16:35 2009 (4A5BCE63)
fffff880`0191b000 fffff880`01955000   rdyboost rdyboost.sys Sat Nov 20 02:43:10 2010 (4CE7982E)
fffff880`082c7000 fffff880`082f3000   rfcomm   rfcomm.sys   Mon Jul 13 18:06:56 2009 (4A5BCC20)
fffff880`05d2f000 fffff880`05d48000   rimspe64 rimspe64.sys Wed Jul 01 17:54:49 2009 (4A4BF749)
fffff880`05d16000 fffff880`05d2f000   risdpe64 risdpe64.sys Wed Jul 01 03:31:57 2009 (4A4B2D0D)
fffff880`05d48000 fffff880`05d9e000   rixdpe64 rixdpe64.sys Sat Jul 04 04:27:00 2009 (4A4F2E74)
fffff880`01e66000 fffff880`01e7e000   rspndr   rspndr.sys   Mon Jul 13 18:08:50 2009 (4A5BCC92)
fffff880`04800000 fffff880`04885000   Rt64win7 Rt64win7.sys Fri Jun 10 00:33:15 2011 (4DF1BAAB)
fffff880`088b2000 fffff880`088bd000   secdrv   secdrv.SYS   Wed Sep 13 07:18:38 2006 (4508052E)
fffff880`01913000 fffff880`0191b000   spldr    spldr.sys    Mon May 11 10:56:27 2009 (4A0858BB)
fffff880`0910d000 fffff880`091a5000   srv      srv.sys      Thu Apr 28 21:06:06 2011 (4DBA2B1E)
fffff880`090a4000 fffff880`0910d000   srv2     srv2.sys     Thu Apr 28 21:05:46 2011 (4DBA2B0A)
fffff880`0898c000 fffff880`089bd000   srvnet   srvnet.sys   Thu Apr 28 21:05:35 2011 (4DBA2AFF)
fffff880`0190b000 fffff880`01913000   stdflt   stdflt.sys   Thu Jul 16 09:36:50 2009 (4A5F4912)
fffff880`05065000 fffff880`050e4000   stwrt64  stwrt64.sys  Thu Jan 21 03:15:11 2010 (4B58292F)
fffff880`04065000 fffff880`04066480   swenum   swenum.sys   Mon Jul 13 18:00:18 2009 (4A5BCA92)
fffff880`0560f000 fffff880`0565a000   SynTP    SynTP.sys    Mon Aug 24 11:37:05 2009 (4A92CFC1)
fffff880`0162e000 fffff880`01831000   tcpip    tcpip.sys    Fri Mar 30 02:34:26 2012 (4F757012)
fffff880`089bd000 fffff880`089cf000   tcpipreg tcpipreg.sys Sat Nov 20 03:51:48 2010 (4CE7A844)
fffff880`02d69000 fffff880`02d76000   TDI      TDI.SYS      Sat Nov 20 02:22:06 2010 (4CE7933E)
fffff880`02d47000 fffff880`02d69000   tdx      tdx.sys      Sat Nov 20 02:21:54 2010 (4CE79332)
fffff880`02de5000 fffff880`02df9000   termdd   termdd.sys   Sat Nov 20 04:03:40 2010 (4CE7AB0C)
[B][COLOR=#FF0000]fffff960`00560000 fffff960`0056a000   TSDDD    TSDDD.dll    unavailable (00000000)[/color][/b]
fffff880`03b99000 fffff880`03bbf000   tunnel   tunnel.sys   Sat Nov 20 03:51:50 2010 (4CE7A846)
fffff880`01e7e000 fffff880`01e85000   TurboB   TurboB.sys   Mon Nov 02 13:47:34 2009 (4AEF4566)
fffff880`0512c000 fffff880`0513e000   umbus    umbus.sys    Sat Nov 20 03:44:37 2010 (4CE7A695)
fffff880`01600000 fffff880`0161d000   usbccgp  usbccgp.sys  Thu Mar 24 21:29:14 2011 (4D8C0C0A)
fffff880`0565a000 fffff880`0565bf00   USBD     USBD.SYS     Thu Mar 24 21:28:59 2011 (4D8C0BFB)
fffff880`041d9000 fffff880`041ea000   usbehci  usbehci.sys  Thu Mar 24 21:29:04 2011 (4D8C0C00)
fffff880`0513e000 fffff880`05198000   usbhub   usbhub.sys   Thu Mar 24 21:29:25 2011 (4D8C0C15)
fffff880`04000000 fffff880`04056000   USBPORT  USBPORT.SYS  Thu Mar 24 21:29:12 2011 (4D8C0C08)
fffff880`01ee5000 fffff880`01f12280   usbvideo usbvideo.sys Sat Nov 20 03:44:34 2010 (4CE7A692)
fffff880`00fe3000 fffff880`00ff0000   vdrvroot vdrvroot.sys Mon Jul 13 18:01:31 2009 (4A5BCADB)
fffff880`0102a000 fffff880`01038000   vga      vga.sys      Mon Jul 13 17:38:47 2009 (4A5BC587)
fffff880`02cdb000 fffff880`02d00000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 17:38:51 2009 (4A5BC58B)
fffff880`00da8000 fffff880`00dbd000   volmgr   volmgr.sys   Sat Nov 20 02:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 02:20:43 2010 (4CE792EB)
fffff880`018bf000 fffff880`0190b000   volsnap  volsnap.sys  Sat Nov 20 02:20:08 2010 (4CE792C8)
fffff880`05d09000 fffff880`05d16000   vwifibus vwifibus.sys Mon Jul 13 18:07:21 2009 (4A5BCC39)
fffff880`02cb8000 fffff880`02cce000   vwififlt vwififlt.sys Mon Jul 13 18:07:22 2009 (4A5BCC3A)
fffff880`082bd000 fffff880`082c7000   vwifimp  vwifimp.sys  Mon Jul 13 18:07:28 2009 (4A5BCC40)
fffff880`02dca000 fffff880`02de5000   wanarp   wanarp.sys   Sat Nov 20 03:52:36 2010 (4CE7A874)
fffff880`02d00000 fffff880`02d10000   watchdog watchdog.sys Mon Jul 13 17:37:35 2009 (4A5BC53F)
fffff880`00ec6000 fffff880`00f6a000   Wdf01000 Wdf01000.sys Mon Jul 13 17:22:07 2009 (4A5BC19F)
fffff880`00f6a000 fffff880`00f79000   WDFLDR   WDFLDR.SYS   Mon Jul 13 17:19:54 2009 (4A5BC11A)
fffff880`02c89000 fffff880`02c92000   wfplwf   wfplwf.sys   Mon Jul 13 18:09:26 2009 (4A5BCCB6)
[B][COLOR=#FF0000]fffff960`00020000 fffff960`00335000   win32k   win32k.sys   unavailable (00000000)[/color][/b]
fffff880`041f7000 fffff880`04200000   wmiacpi  wmiacpi.sys  Mon Jul 13 17:31:02 2009 (4A5BC3B6)
fffff880`00fd0000 fffff880`00fd9000   WMILIB   WMILIB.SYS   Mon Jul 13 17:19:51 2009 (4A5BC117)
fffff880`01fa7000 fffff880`01fc8000   WudfPf   WudfPf.sys   Sat Nov 20 03:42:44 2010 (4CE7A624)
Got this from the symbol server folks:
Sorry for the slow response - it's been a busy month.
This is a problem before even getting a chance go query the symbol server. The issue is that the dump file doesn't have the information needed to do a symbol server look up. You can see this in the line
I'm not sure why the dump wouldn't contain the necessary information. The image header (more accurately, enough of it to perform symbol server resolution of the image) should be coming from the loaded module list. Which OS version is the dump for? If you run:
!lmi win32k.sys
do you get anything that resembles image header information:
I don't have an example from a dump handy, but full information looks something like:
0:000> !lmi notepad.exe
Loaded Module Info: [notepad.exe]
Module: notepad
Base Address: 00000000ff3e0000
Image Name: notepad.exe
Machine Type: 34404 (X64)
Time Stamp: 4a5bc9b3 Mon Jul 13 16:56:35 2009
CheckSum: 3e749
Characteristics: 22
Debug Data Dirs: Type Size VA Pointer
CODEVIEW 24, b74c, ad4c RSDS - GUID: {36CFD5F9-888C-4483-B522-B9DB242D8478}
Age: 2, Pdb: notepad.pdb
CLSID 4, b748, ad48 [Data not mapped]
Symbol Type: DEFERRED - No error - symbol load deferred
Load Report: no symbols loaded
For pdb resolution via the symbol server, either the first two bolded fields or the last bolded field needs to be present.
I'd guess it's either the kd.exe (unlikely since we use different versions) or that it's something in the scripts (but I have no clue how/what/why)?
Anyone still have the old jcgriff2 scripts installed? That way we can run them to see if they generate the win32k.sys errors.
The fact that the same problem exists in WinDbg is enough for me to doubt it is the scripts at fault here. It seems to be something with the .dmps themselves...
All the .dmps are from Windows 7 systems with SP1 installed. I do not know if the .dmps are being corrupted or what is the issue. It's very strange. https://www.sysnative.com/forums/sh...-once-in-a-while?p=24893&viewfull=1#post24893 has one of the unverified win32k.sys symbol errors, but the sigcheck came back clean.
From WinDbg:
Microsoft (R) Windows Debugger Version 6.2.8229.0 AMD64
Loading Dump File [C:\Users\Mike\Downloads\win32kCases\081612-18673-01.dmp]
Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0xfffff800`0324d000 PsLoadedModuleList = 0xfffff800`03491670
Debug session time: Thu Aug 16 02:19:45.505 2012 (UTC - 6:00)
System Uptime: 0 days 0:44:23.941
TRIAGER: Could not open triage file : C:\Program Files (x86)\Windows Kits\8.0\Debuggers\x64\triage\oca.ini, error 2
TRIAGER: Could not open triage file : C:\Program Files (x86)\Windows Kits\8.0\Debuggers\x64\winxp\triage.ini, error 2
BugCheck A, {a, 2, 1, fffff800032d81a8}
*** WARNING: Unable to verify timestamp for mfehidk.sys
*** ERROR: Module load completed but symbols could not be loaded for mfehidk.sys
TRIAGER: Could not open triage file : C:\Program Files (x86)\Windows Kits\8.0\Debuggers\x64\triage\modclass.ini, error 2
Probably caused by : mfehidk.sys ( mfehidk+54028 )
Followup: MachineOwner
0: kd> !lmi win32k.sys
Loaded Module Info: [win32k.sys]
Cannot read Image header @ fffff96000020000
Loading Dump File [C:\Users\Mike\Downloads\win32kCases\071712-19188-01.dmp]
Machine Name:
Debug session time: Tue Jul 17 01:15:30.568 2012 (UTC - 6:00)
BugCheck 19, {3, fffffa80181eeb00, fffffa80081eeb00, fffffa80081eeb00}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+a53 )
Followup: Pool_corruption
6: kd> !lmi win32k.sys
Cannot read Image header @ fffff960000b0000
Loading Dump File [C:\Users\Mike\Downloads\win32kCases\052012-78000-01.dmp]
Built by: 7601.17803.amd64fre.win7sp1_gdr.120330-1504
Machine Name:
Kernel base = 0xfffff800`03457000 PsLoadedModuleList = 0xfffff800`0369b670
Debug session time: Sun May 20 22:55:00.517 2012 (UTC - 6:00)
System Uptime: 0 days 1:25:15.000
BugCheck D1, {9, 2, 1, fffff880045ed288}
*** WARNING: Unable to verify timestamp for PxHlpa64.sys
*** ERROR: Module load completed but symbols could not be loaded for PxHlpa64.sys
Probably caused by : usbehci.sys ( usbehci!EHCI_AcquireAsyncDoorbellLock+0 )
3: kd> !lmi win32k.sys
The following is from the thread: https://www.sysnative.com/forums/sh...-once-in-a-while?p=24893&viewfull=1#post24893
c:\windows\system32\win32k.sys:	Verified:	Signed
	Catalog:	C:\Windows\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2731847~31bf3856ad364e35~amd64~~6.1.1.2.cat
	Signers:
		Microsoft Windows
		Microsoft Windows Verification PCA
		Microsoft Root Certificate Authority
	Signing date:	4:38 PM 7/18/2012
	Publisher:	Microsoft Corporation
	Description:	Multi-User Win32 Driver
	Product:	Microsoft® Windows® Operating System
	Version:	6.1.7600.16385
	File version:	6.1.7600.16385 (win7_rtm.090713-1255)
Loading Dump File [C:\Users\BSODAnalyst\Downloads\SysnativeFiles\BSOD82212\outputDmps\2012_Aug_23_20_20\082212-16426-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (6 procs) Free x64
Machine Name:
Kernel base = 0xfffff800`0384e000 PsLoadedModuleList = 0xfffff800`03a92670
Debug session time: Wed Aug 22 21:17:56.727 2012 (UTC - 6:00)
System Uptime: 0 days 0:01:05.866
BugCheck C4, {0, 0, 0, 0}
Probably caused by : tcpipreg.sys ( tcpipreg!InterfaceAddressRegKeyChangeHandler+109 )
4: kd> !lmi win32k.sys
4: kd> lmtsmn
fffff880`05867000 fffff880`058a5000   1394ohci 1394ohci.sys Sat Nov 20 03:44:56 2010 (4CE7A6A8)
fffff880`00f49000 fffff880`00fa0000   ACPI     ACPI.sys     Sat Nov 20 02:19:16 2010 (4CE79294)
fffff880`02c16000 fffff880`02c9f000   afd      afd.sys      Tue Dec 27 20:59:20 2011 (4EFA9418)
fffff880`058c1000 fffff880`058d7000   AgileVpn AgileVpn.sys Mon Jul 13 18:10:24 2009 (4A5BCCF0)
fffff880`04311000 fffff880`04326000   amdppm   amdppm.sys   Mon Jul 13 17:19:25 2009 (4A5BC0FD)
fffff880`01062000 fffff880`0106d000   amdxata  amdxata.sys  Fri Mar 19 10:18:18 2010 (4BA3A3CA)
fffff880`042e3000 fffff880`042eb000   AppleCharger AppleCharger.sys Mon Jan 10 02:57:29 2011 (4D2AD809)
fffff880`00ff3000 fffff880`00ffc000   atapi    atapi.sys    Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`0102d000 fffff880`01057000   ataport  ataport.SYS  Sat Nov 20 02:19:15 2010 (4CE79293)
fffff880`0488f000 fffff880`05389000   atikmdag atikmdag.sys Thu Apr 05 19:48:25 2012 (4F7E4B69)
fffff880`0432f000 fffff880`04389000   atikmpag atikmpag.sys Thu Apr 05 19:10:44 2012 (4F7E4294)
fffff960`00870000 fffff960`008d1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`019ef000 fffff880`019f6000   Beep     Beep.SYS     Mon Jul 13 18:00:13 2009 (4A5BCA8D)
fffff880`042d2000 fffff880`042e3000   blbdrive blbdrive.sys Mon Jul 13 17:35:59 2009 (4A5BC4DF)
fffff880`0557e000 fffff880`0559c000   bowser   bowser.sys   Tue Feb 22 21:55:04 2011 (4D649328)
fffff960`00770000 fffff960`00797000   cdd      cdd.dll      unavailable (00000000)
fffff880`0158e000 fffff880`015b8000   cdrom    cdrom.sys    Sat Nov 20 02:19:20 2010 (4CE79298)
fffff880`00cd9000 fffff880`00d99000   CI       CI.dll       Sat Nov 20 06:12:36 2010 (4CE7C944)
fffff880`01600000 fffff880`01630000   CLASSPNP CLASSPNP.SYS Sat Nov 20 02:19:23 2010 (4CE7929B)
fffff880`00c7b000 fffff880`00cd9000   CLFS     CLFS.SYS     Mon Jul 13 17:19:57 2009 (4A5BC11D)
fffff880`0112b000 fffff880`0119d000   cng      cng.sys      Fri Jun 01 21:25:51 2012 (4FC987BF)
fffff880`058b1000 fffff880`058c1000   CompositeBus CompositeBus.sys Sat Nov 20 03:33:17 2010 (4CE7A3ED)
fffff880`072a5000 fffff880`072b3000   crashdmp crashdmp.sys Mon Jul 13 18:01:01 2009 (4A5BCABD)
fffff880`04231000 fffff880`042b4000   csc      csc.sys      Sat Nov 20 02:27:12 2010 (4CE79470)
fffff880`042b4000 fffff880`042d2000   dfsc     dfsc.sys     Sat Nov 20 02:26:31 2010 (4CE79447)
fffff880`011f0000 fffff880`011ff000   discache discache.sys Mon Jul 13 17:37:18 2009 (4A5BC52E)
fffff880`019d9000 fffff880`019ef000   disk     disk.sys     Mon Jul 13 17:19:57 2009 (4A5BC11D)
fffff880`07254000 fffff880`07276000   drmk     drmk.sys     Mon Jul 13 19:01:25 2009 (4A5BD8E5)
fffff880`072b3000 fffff880`072bf000   dump_dumpata dump_dumpata.sys Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`072ca000 fffff880`072dd000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 17:21:51 2009 (4A5BC18F)
fffff880`072bf000 fffff880`072ca000   dump_msahci dump_msahci.sys Sat Nov 20 03:33:58 2010 (4CE7A416)
fffff880`07299000 fffff880`072a5000   Dxapi    Dxapi.sys    Mon Jul 13 17:38:28 2009 (4A5BC574)
fffff880`04408000 fffff880`044fc000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 02:50:50 2010 (4CE799FA)
fffff880`044fc000 fffff880`04542000   dxgmms1  dxgmms1.sys  Sat Nov 20 02:49:53 2010 (4CE799C1)
fffff880`04812000 fffff880`0481fe80   EtronHub3 EtronHub3.sys Mon Jul 25 15:30:59 2011 (4E2DE093)
fffff880`04566000 fffff880`04579500   EtronXHCI EtronXHCI.sys Mon Jul 25 15:30:56 2011 (4E2DE090)
fffff880`010b9000 fffff880`010cd000   fileinfo fileinfo.sys Mon Jul 13 17:34:25 2009 (4A5BC481)
fffff880`0106d000 fffff880`010b9000   fltmgr   fltmgr.sys   Sat Nov 20 02:19:24 2010 (4CE7929C)
fffff880`0197b000 fffff880`0199f000   fltsrv   fltsrv.sys   Thu Nov 17 05:29:13 2011 (4EC4FE19)
fffff880`013ec000 fffff880`013f6000   Fs_Rec   Fs_Rec.sys   Wed Feb 29 20:41:06 2012 (4F4EEFD2)
fffff880`0199f000 fffff880`019d9000   fvevol   fvevol.sys   Sat Nov 20 02:24:06 2010 (4CE793B6)
fffff880`01878000 fffff880`018c2000   fwpkclnt fwpkclnt.sys Sat Nov 20 02:21:37 2010 (4CE79321)
fffff880`059ac000 fffff880`059b9000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 06:17:04 2009 (4A1151C0)
fffff800`03805000 fffff800`0384e000   hal      hal.dll      Sat Nov 20 06:00:25 2010 (4CE7C669)
fffff880`04542000 fffff880`04566000   HDAudBus HDAudBus.sys Sat Nov 20 03:43:42 2010 (4CE7A65E)
fffff880`045e3000 fffff880`045fc000   HIDCLASS HIDCLASS.SYS Sat Nov 20 03:43:49 2010 (4CE7A665)
fffff880`05389000 fffff880`05391080   HIDPARSE HIDPARSE.SYS Mon Jul 13 18:06:17 2009 (4A5BCBF9)
fffff880`077ef000 fffff880`077fd000   hidusb   hidusb.sys   Sat Nov 20 03:43:49 2010 (4CE7A665)
fffff880`054b5000 fffff880`0557e000   HTTP     HTTP.sys     Sat Nov 20 02:24:30 2010 (4CE793CE)
fffff880`01972000 fffff880`0197b000   hwpolicy hwpolicy.sys Sat Nov 20 02:18:54 2010 (4CE7927E)
fffff880`0539d000 fffff880`053ac000   kbdclass kbdclass.sys Mon Jul 13 17:19:50 2009 (4A5BC116)
fffff880`04396000 fffff880`043a4000   kbdhid   kbdhid.sys   Sat Nov 20 03:33:25 2010 (4CE7A3F5)
fffff800`00bae000 fffff800`00bb8000   kdcom    kdcom.dll    Sat Feb 05 09:52:49 2011 (4D4D8061)
fffff880`053bb000 fffff880`053fe000   ks       ks.sys       Sat Nov 20 03:33:23 2010 (4CE7A3F3)
fffff880`013c0000 fffff880`013db000   ksecdd   ksecdd.sys   Fri Jun 01 20:50:23 2012 (4FC97F6F)
fffff880`01564000 fffff880`0158e000   ksecpkg  ksecpkg.sys  Fri Jun 01 21:27:11 2012 (4FC9880F)
fffff880`07276000 fffff880`0727b200   ksthunk  ksthunk.sys  Mon Jul 13 18:00:19 2009 (4A5BCA93)
fffff880`077e7000 fffff880`077ee500   Lachesis Lachesis.sys Fri Oct 16 07:09:12 2009 (4AD87078)
fffff880`073c0000 fffff880`073d5000   lltdio   lltdio.sys   Mon Jul 13 18:08:50 2009 (4A5BCC92)
fffff880`072eb000 fffff880`0730e000   luafv    luafv.sys    Mon Jul 13 17:26:13 2009 (4A5BC295)
fffff880`07400000 fffff880`07407100   Lycosa   Lycosa.sys   Tue Sep 07 21:01:26 2010 (4C86FC86)
fffff880`00c5a000 fffff880`00c67000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:29:09 2009 (4A5BDF65)
fffff880`072dd000 fffff880`072eb000   monitor  monitor.sys  Mon Jul 13 17:38:52 2009 (4A5BC58C)
fffff880`053ac000 fffff880`053bb000   mouclass mouclass.sys Mon Jul 13 17:19:50 2009 (4A5BC116)
fffff880`04389000 fffff880`04396000   mouhid   mouhid.sys   Mon Jul 13 18:00:20 2009 (4A5BCA94)
fffff880`00e67000 fffff880`00e81000   mountmgr mountmgr.sys Sat Nov 20 02:19:21 2010 (4CE79299)
fffff880`0559c000 fffff880`055b4000   mpsdrv   mpsdrv.sys   Mon Jul 13 18:08:25 2009 (4A5BCC79)
fffff880`055b4000 fffff880`055e1000   mrxsmb   mrxsmb.sys   Tue Apr 26 20:40:38 2011 (4DB78226)
fffff880`05400000 fffff880`0544e000   mrxsmb10 mrxsmb10.sys Fri Jul 08 20:46:28 2011 (4E17C104)
fffff880`0544e000 fffff880`05472000   mrxsmb20 mrxsmb20.sys Tue Apr 26 20:39:37 2011 (4DB781E9)
fffff880`01057000 fffff880`01062000   msahci   msahci.sys   Sat Nov 20 03:33:58 2010 (4CE7A416)
fffff880`01200000 fffff880`0120b000   Msfs     Msfs.SYS     Mon Jul 13 17:19:47 2009 (4A5BC113)
fffff880`045db000 fffff880`045e3000   mshidkmdf mshidkmdf.sys Mon Jul 13 18:06:24 2009 (4A5BCC00)
fffff880`00fa9000 fffff880`00fb3000   msisadrv msisadrv.sys Mon Jul 13 17:19:26 2009 (4A5BC0FE)
fffff880`010cd000 fffff880`0112b000   msrpc    msrpc.sys    Sat Nov 20 02:21:56 2010 (4CE79334)
fffff880`02c00000 fffff880`02c0b000   mssmbios mssmbios.sys Mon Jul 13 17:31:10 2009 (4A5BC3BE)
fffff880`01960000 fffff880`01972000   mup      mup.sys      Mon Jul 13 17:23:45 2009 (4A5BC201)
fffff880`01411000 fffff880`01504000   ndis     ndis.sys     Sat Nov 20 02:23:30 2010 (4CE79392)
fffff880`059c4000 fffff880`059d0000   ndistapi ndistapi.sys Mon Jul 13 18:10:00 2009 (4A5BCCD8)
fffff880`059d0000 fffff880`059ff000   ndiswan  ndiswan.sys  Sat Nov 20 03:52:32 2010 (4CE7A870)
fffff880`0487a000 fffff880`0488f000   NDProxy  NDProxy.SYS  Sat Nov 20 03:52:20 2010 (4CE7A864)
fffff880`02d1f000 fffff880`02d2e000   netbios  netbios.sys  Mon Jul 13 18:09:26 2009 (4A5BCCB6)
fffff880`02c9f000 fffff880`02ce4000   netbt    netbt.sys    Sat Nov 20 02:23:18 2010 (4CE79386)
fffff880`01504000 fffff880`01564000   NETIO    NETIO.SYS    Sat Nov 20 02:23:13 2010 (4CE79381)
fffff880`02ddd000 fffff880`02df7000   NNSAlpc  NNSAlpc.sys  Wed Jun 27 07:04:31 2012 (4FEB04DF)
fffff880`011cc000 fffff880`011f0000   NNSHttp  NNSHttp.sys  Wed Jun 27 07:17:48 2012 (4FEB07FC)
fffff880`02db5000 fffff880`02ddd000   NNSIds   NNSIds.sys   Wed Jun 27 07:30:19 2012 (4FEB0AEB)
fffff880`02d13000 fffff880`02d1f000   NNSNAHSL NNSNAHSL.sys Wed Jun 27 07:47:45 2012 (4FEB0F01)
fffff880`040c3000 fffff880`040e1000   NNSPicc  NNSPicc.sys  Wed Jun 27 07:20:03 2012 (4FEB0883)
fffff880`040ac000 fffff880`040c3000   NNSPihsw NNSPihsw.sys Wed Jun 27 07:49:36 2012 (4FEB0F70)
fffff880`0408b000 fffff880`040ac000   NNSPop3  NNSPop3.sys  Wed Jun 27 07:37:08 2012 (4FEB0C84)
fffff880`04039000 fffff880`0408b000   NNSProt  NNSProt.sys  Wed Jun 27 07:23:25 2012 (4FEB094D)
fffff880`04000000 fffff880`04039000   NNSPrv   NNSPrv.sys   Wed Jun 27 07:01:24 2012 (4FEB0424)
fffff880`041d8000 fffff880`041f8000   NNSSmtp  NNSSmtp.sys  Wed Jun 27 07:45:31 2012 (4FEB0E7B)
fffff880`0419b000 fffff880`041d8000   NNSStrm  NNSStrm.sys  Thu Jul 12 03:11:16 2012 (4FFE94B4)
fffff880`0417d000 fffff880`0419b000   NNSTlsc  NNSTlsc.sys  Wed Jun 27 07:07:02 2012 (4FEB0576)
fffff880`0120b000 fffff880`0121c000   Npfs     Npfs.SYS     Mon Jul 13 17:19:48 2009 (4A5BC114)
fffff880`04171000 fffff880`0417d000   nsiproxy nsiproxy.sys Mon Jul 13 17:21:02 2009 (4A5BC15E)
fffff800`0384e000 fffff800`03e36000   nt       ntkrnlmp.exe Fri May 04 02:18:59 2012 (4FA390F3)
fffff880`0121d000 fffff880`013c0000   Ntfs     Ntfs.sys     Thu Mar 10 20:39:39 2011 (4D79997B)
fffff880`01668000 fffff880`01671000   Null     Null.SYS     Mon Jul 13 17:19:37 2009 (4A5BC109)
fffff880`02ced000 fffff880`02d13000   pacer    pacer.sys    Sat Nov 20 03:52:18 2010 (4CE7A862)
fffff880`00e26000 fffff880`00e3b000   partmgr  partmgr.sys  Fri Mar 16 23:06:09 2012 (4F641BC1)
fffff880`00fb3000 fffff880`00fe6000   pci      pci.sys      Sat Nov 20 02:19:11 2010 (4CE7928F)
fffff880`00e50000 fffff880`00e57000   pciide   pciide.sys   Mon Jul 13 17:19:49 2009 (4A5BC115)
fffff880`00e57000 fffff880`00e67000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 17:19:48 2009 (4A5BC114)
fffff880`013db000 fffff880`013ec000   pcw      pcw.sys      Mon Jul 13 17:19:27 2009 (4A5BC0FF)
fffff880`0889b000 fffff880`08941000   peauth   peauth.sys   Mon Jul 13 19:01:19 2009 (4A5BD8DF)
fffff880`07217000 fffff880`07254000   portcls  portcls.sys  Mon Jul 13 18:06:27 2009 (4A5BCC03)
fffff880`00c67000 fffff880`00c7b000   PSHED    PSHED.dll    Mon Jul 13 19:32:23 2009 (4A5BE027)
fffff880`0730e000 fffff880`0733a000   PSINAflt PSINAflt.sys Thu Jul 12 12:43:39 2012 (4FFF1ADB)
fffff880`0735d000 fffff880`0737d000   PSINFile PSINFile.sys Thu Jul 12 12:44:06 2012 (4FFF1AF6)
fffff880`04139000 fffff880`04171000   psinknc  psinknc.sys  Thu Jul 12 12:43:03 2012 (4FFF1AB7)
fffff880`0737d000 fffff880`0739f000   PSINProc PSINProc.sys Thu Jul 12 12:44:30 2012 (4FFF1B0E)
fffff880`0733a000 fffff880`0735d000   PSINProt PSINProt.sys Thu Jul 12 12:44:52 2012 (4FFF1B24)
fffff880`058d7000 fffff880`058fb000   rasl2tp  rasl2tp.sys  Sat Nov 20 03:52:34 2010 (4CE7A872)
fffff880`0457a000 fffff880`04595000   raspppoe raspppoe.sys Mon Jul 13 18:10:17 2009 (4A5BCCE9)
fffff880`04595000 fffff880`045b6000   raspptp  raspptp.sys  Sat Nov 20 03:52:31 2010 (4CE7A86F)
fffff880`045b6000 fffff880`045d0000   rassstp  rassstp.sys  Mon Jul 13 18:10:25 2009 (4A5BCCF1)
fffff880`040e8000 fffff880`04139000   rdbss    rdbss.sys    Sat Nov 20 02:27:51 2010 (4CE79497)
fffff880`05392000 fffff880`0539d000   rdpbus   rdpbus.sys   Mon Jul 13 18:17:46 2009 (4A5BCEAA)
fffff880`019f6000 fffff880`019ff000   RDPCDD   RDPCDD.sys   Mon Jul 13 18:16:34 2009 (4A5BCE62)
fffff880`01400000 fffff880`01409000   rdpencdd rdpencdd.sys Mon Jul 13 18:16:34 2009 (4A5BCE62)
fffff880`013f6000 fffff880`013ff000   rdprefmp rdprefmp.sys Mon Jul 13 18:16:35 2009 (4A5BCE63)
fffff880`01926000 fffff880`01960000   rdyboost rdyboost.sys Sat Nov 20 02:43:10 2010 (4CE7982E)
fffff880`073d5000 fffff880`073ed000   rspndr   rspndr.sys   Mon Jul 13 18:08:50 2009 (4A5BCC92)
fffff880`058fd000 fffff880`059ac000   Rt64win7 Rt64win7.sys Wed Apr 11 10:29:16 2012 (4F85B15C)
fffff880`043a4000 fffff880`043fc300   RtHDMIVX RtHDMIVX.sys Wed Jul 06 04:09:50 2011 (4E14346E)
fffff880`07408000 fffff880`077e6980   RTKVHD64 RTKVHD64.sys Thu May 31 03:21:30 2012 (4FC7381A)
fffff880`02dab000 fffff880`02db5000   SASDIFSV64 SASDIFSV64.SYS Thu Jul 21 17:03:00 2011 (4E28B024)
fffff880`02da1000 fffff880`02dab000   SASKUTIL64 SASKUTIL64.SYS Tue Jul 12 15:00:01 2011 (4E1CB5D1)
fffff880`02d7a000 fffff880`02da1000   SCDEmu   SCDEmu.SYS   Mon Nov 14 20:18:27 2011 (4EC1DA03)
fffff880`08941000 fffff880`0894c000   secdrv   secdrv.SYS   Wed Sep 13 07:18:38 2006 (4508052E)
fffff880`058a5000 fffff880`058b1000   serenum  serenum.sys  Mon Jul 13 18:00:33 2009 (4A5BCAA1)
fffff880`02d2e000 fffff880`02d4b000   serial   serial.sys   Mon Jul 13 18:00:40 2009 (4A5BCAA8)
fffff880`0191e000 fffff880`01926000   spldr    spldr.sys    Mon May 11 10:56:27 2009 (4A0858BB)
fffff880`0894c000 fffff880`0897d000   srvnet   srvnet.sys   Thu Apr 28 21:05:35 2011 (4DBA2AFF)
fffff880`058fb000 fffff880`058fc480   swenum   swenum.sys   Mon Jul 13 18:00:18 2009 (4A5BCA92)
fffff880`01675000 fffff880`01878000   tcpip    tcpip.sys    Fri Mar 30 02:34:26 2012 (4F757012)
fffff880`0897d000 fffff880`0898f000   tcpipreg tcpipreg.sys Sat Nov 20 03:51:48 2010 (4CE7A844)
fffff880`011bf000 fffff880`011cc000   TDI      TDI.SYS      Sat Nov 20 02:22:06 2010 (4CE7933E)
fffff880`0119d000 fffff880`011bf000   tdx      tdx.sys      Sat Nov 20 02:21:54 2010 (4CE79332)
fffff880`02d66000 fffff880`02d7a000   termdd   termdd.sys   Sat Nov 20 04:03:40 2010 (4CE7AB0C)
fffff960`004e0000 fffff960`004ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`042eb000 fffff880`04311000   tunnel   tunnel.sys   Sat Nov 20 03:51:50 2010 (4CE7A846)
fffff880`04800000 fffff880`04812000   umbus    umbus.sys    Sat Nov 20 03:44:37 2010 (4CE7A695)
fffff880`0727c000 fffff880`07299000   usbccgp  usbccgp.sys  Thu Mar 24 21:29:14 2011 (4D8C0C0A)
fffff880`045fc000 fffff880`045fdf00   USBD     USBD.SYS     Thu Mar 24 21:28:59 2011 (4D8C0BFB)
fffff880`05856000 fffff880`05867000   usbehci  usbehci.sys  Thu Mar 24 21:29:04 2011 (4D8C0C00)
fffff880`04820000 fffff880`0487a000   usbhub   usbhub.sys   Thu Mar 24 21:29:25 2011 (4D8C0C15)
fffff880`059b9000 fffff880`059c4000   usbohci  usbohci.sys  Thu Mar 24 21:29:03 2011 (4D8C0BFF)
fffff880`05800000 fffff880`05856000   USBPORT  USBPORT.SYS  Thu Mar 24 21:29:12 2011 (4D8C0C08)
fffff880`00fe6000 fffff880`00ff3000   vdrvroot vdrvroot.sys Mon Jul 13 18:01:31 2009 (4A5BCADB)
fffff880`015b8000 fffff880`015c6000   vga      vga.sys      Mon Jul 13 17:38:47 2009 (4A5BC587)
fffff880`015c6000 fffff880`015eb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 17:38:51 2009 (4A5BC58B)
fffff880`045d0000 fffff880`045db000   VKbms    VKbms.sys    Thu Sep 30 10:16:33 2010 (4CA4B7E1)
fffff880`00c00000 fffff880`00c3c000   vmbus    vmbus.sys    Sat Nov 20 02:57:29 2010 (4CE79B89)
fffff880`018c2000 fffff880`018d2000   vmstorfl vmstorfl.sys Sat Nov 20 02:57:30 2010 (4CE79B8A)
fffff880`00e3b000 fffff880`00e50000   volmgr   volmgr.sys   Sat Nov 20 02:19:28 2010 (4CE792A0)
fffff880`00d99000 fffff880`00df5000   volmgrx  volmgrx.sys  Sat Nov 20 02:20:43 2010 (4CE792EB)
fffff880`018d2000 fffff880`0191e000   volsnap  volsnap.sys  Sat Nov 20 02:20:08 2010 (4CE792C8)
fffff880`00e00000 fffff880`00e26000   vsflt67  vsflt67.sys  Wed Dec 14 04:43:33 2011 (4EE88BE5)
fffff880`02d4b000 fffff880`02d66000   wanarp   wanarp.sys   Sat Nov 20 03:52:36 2010 (4CE7A874)
fffff880`015eb000 fffff880`015fb000   watchdog watchdog.sys Mon Jul 13 17:37:35 2009 (4A5BC53F)
fffff880`00e96000 fffff880`00f3a000   Wdf01000 Wdf01000.sys Mon Jul 13 17:22:07 2009 (4A5BC19F)
fffff880`00f3a000 fffff880`00f49000   WDFLDR   WDFLDR.SYS   Mon Jul 13 17:19:54 2009 (4A5BC11A)
fffff880`02ce4000 fffff880`02ced000   wfplwf   wfplwf.sys   Mon Jul 13 18:09:26 2009 (4A5BCCB6)
[color=red][b]fffff960`00020000 fffff960`00335000   win32k   win32k.sys   unavailable (00000000)[/b][/color]
fffff880`00e81000 fffff880`00e95000   winhv    winhv.sys    Sat Nov 20 02:20:02 2010 (4CE792C2)
fffff880`04326000 fffff880`0432f000   wmiacpi  wmiacpi.sys  Mon Jul 13 17:31:02 2009 (4A5BC3B6)
fffff880`00fa0000 fffff880`00fa9000   WMILIB   WMILIB.SYS   Mon Jul 13 17:19:51 2009 (4A5BC117)
fffff880`0739f000 fffff880`073c0000   WudfPf   WudfPf.sys   Sat Nov 20 03:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`01630000 fffff880`0163e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0163e000 fffff880`0164a000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0164a000 fffff880`01655000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01655000 fffff880`01668000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
IDK about that, John...
All versions of Windbg GUI shows the same win32k symbol errors which IMO:
- rules out the scripts 100%
- rules out different versions of KD 100%
- rules out different versions of Windbg 100%
Why are we only seeing SYM errors related to win32k.sys & no others?
I think the problem lay with MSDL SYM server.
Running this dump - https://www.sysnative.com/forums/sh...d-for-win32k-sys?p=24849&viewfull=1#post24849
I deleted win32k PDB & SYS folders from local sym cache before running.
Windbg 6.12
Running dump from non-extracted zip - MSDL successful per !lmi command -
0: kd> [COLOR=#ff0000]!lmi win32k.sys[/COLOR]
         Module: win32k
   Base Address: fffff96000020000
     Image Name: win32k.sys
     Time Stamp: 5006fd0d Wed Jul 18 14:14:37 2012
       CheckSum: 306830
Characteristics: 22  perf
             CODEVIEW    23, 2a5c98,  2a5098 RSDS - GUID: {4CD57B19-7B9A-472D-9ABE-1FBDD098173F}
               Age: 2, Pdb: win32k.pdb
                CLSID     4, 2a5c94,  2a5094 [Data not mapped]
     Image Type: FILE     - Image read successfully from debugger.
                 win32k.sys
    Symbol Type: PDB      - [COLOR=#ff0000]Symbols loaded successfully from symbol server.[/COLOR]
                 a:\symbols\win32k.pdb\4CD57B197B9A472D9ABE1FBDD098173F2\win32k.pdb
    Load Report: public symbols , not source indexed
Full output -
My local sym cache shows current timestamp on win32k folder -
 Directory of A:\symbols\win32k.pdb\4CD57B197B9A472D9ABE1FBDD098173F2
08/23/2012  22:45    <DIR>          .
08/23/2012  22:45    <DIR>          ..
07/18/2012  19:07         4,885,504 win32k.pdb
               1 File(s)      4,885,504 bytes
               2 Dir(s)  23,382,413,312 bytes free
A:\symbols\win32k.pdb\4CD57B197B9A472D9ABE1FBDD098173F2>
I deleted win32k from local sym cache, then re-ran, but with extracted dump.
If I extract the dump from the zip, then run it - MSDL fails to download win32k SYMs -
    Load Report: [COLOR=#FF0000]no symbols loaded[/COLOR]
No symbols downloaded for win32k -
A:\symbols>dir win32k*
 Volume in drive A is BSOD Scripts - Dumps
 Volume Serial Number is 1055-E977
File Not Found
A:\symbols>
You got 2 posts in there Mike!
You type faster than I do!
We both do agree -- win32k sym errors have nothing to do with the apps whatsoever.
And as I asked.... why only win32k??
Windbg 6.12
Brilliant! I never would have thought to run it from the .zip itself. Nice find!!
I'll have to test that out, too.
