[SOLVED] Unable to fix component corruption
Please do the following again:
SFC Scan
Did you set the update.catalog entries in hosts and DPF - No
Could you temporarily disable IIS service? Yes
Tried to install it manually, says, This update is not applicable to this computer.
cbs.log to big to upload also to big zipped
