USB Ports Problem, can't in-place upgrade my OS, use DISM and SFC
Hi, I can't go into Recovery Environment in any method listed there and I searched around and found this, how do I fix this?
Managed to get WinRE.wim from the Windows10 ISO, but now this happenedRecovery Environment2.PNG
Am I doing this right? I am not in recovery environment since it does not let me enter command prompt there but this is what happened when I try itshrink desired fail.PNG
You must select partition 2, partition 1 is your current EFI partition.
I am not sure what it means since I only migrated my OS from my HDD to SSD back then, maybe that happened?
Because this section is limited to response on threads, I would suggest to start a new thread in the Windows 10 section so you will get advise from other helpers too. Please refer to this thread in your new post.
