[SOLVED] [W7SP1 x64] I need help with at least one corruption (SURT) count.
Re: I need help with at least one corruption (SURT) count.
It worked once. But as like before other times it came back with 'couldn't open folder option' error, in cmd. But I would like to tell you; today being Monday: over the weekend I must have performed an operation at least 5 time's. The fourth time of this operation, your DISM command worked. But I think I must have missed installing kb3181988 once again, and the problem came back,with usHUB.sys.mui . I don't have the dtc runtime error anymore. I have Loaris trojan remov.. and off the bat I found it wanted to remove mctadmin.exe; but I have since,[during recurring operations] _ kept myself from letting that mistake happen again. But that kb3181988 corruption is a icky one!! I'll be sure never, (on this machine), to never download it. Is [FONT=&quot] KB3125574 a foul one too ?? [/FONT]https://youtu.be/RC_5eb9wTfk. <-- This is where I ultimately found a time consuming fix for fixing my repeating sfc scan problems where is can't fix all, then it says it has fixed all: back and forth and never getting a 'Windows has found no integrity violations'.The problem is fixed now. Thanks very much for your encouraging help ,and objectivity zcomputerwhiz ! :thumbsup2: P.S. -> If I get the option of updating with kb3125574 should I stay away from that one too?:startorb:
Glad to hear it's working now.
Please install any updates that are offered by Windows Update :)
Uninstall Update with DISM
  1. Download the update MSU here: Download Update for Windows 7 for x64-based Systems (KB3181988) from Official Microsoft Download Center
  3. Click on the Start
    cd C:\temp
    expand {update name}.msu -f:* C:\temp
    replace {update name} with the name of the MSU file downloaded in step 1
    DISM.exe /Online /Remove-Package /PackagePath:C:\temp\{update name}.cab
    Restart Windows to complete this operation.
    Do you want to restart the computer now (Y/N)?
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
Pls zcomputerwhiz, my problem with usbhub.sys.mui just keeps coming back. And every time I do a install repair the sfc is clean for a short time; but shortly comes back. I tried once again to produce the results from your post above. It worked _ it processed four items from the kb3181988. I'm just confused because I thought this optional update was exactly the fix for usbhub.sys.mui.. I found out kb3181988 helps with usb.ini.resource & usbport.ini.resouce. Regardless, I am just informing you that the commandline steps above worked again this time. Would like to hear from you again, finding where do we go from here. There must be a fix. !
Do not install the optional update, that should avoid the problem. :)
