[SOLVED] WIN 7 Update problem / SP1
When I try to start the process, it says the following:
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another process. Would you nike to schedule this volume to be checked the next time the system restarts? Y/N
Should I proceed and restart?
------< Log generate on 08/01/2019 10:56:38 AM >------
Category: 0
Computer Name: AFRO-PC
Event Code: 1001
Record Number: 293027
Time Written: 01-08-2019 @ 09:53:35
Event Type: Information
User:
Message:
Checking file system on C:
CHKDSK is verifying files (stage 1 of 3)...
1209344 file records processed.
File verification completed.
950 large file records processed.
0 bad file records processed.
2 EA records processed.
60 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
1396016 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
1209344 file SDs/SIDs processed.
Cleaning up 229 unused index entries from index $SII of file 0x9.
Cleaning up 229 unused index entries from index $SDH of file 0x9.
Cleaning up 229 unused security descriptors.
93337 data files processed.
169345272 USN bytes processed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
157286399 KB total disk space.
130743664 KB in 1014040 files.
578440 KB in 93338 indexes.
0 KB in bad sectors.
1448003 KB in use by the system.
24516292 KB available on disk.
39321599 total allocation units on disk.
6129073 allocation units available on disk.
Internal Info:
00 74 12 00 bd e5 10 00 02 a8 1e 00 00 00 00 00 .t..............
8f 02 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Category: 0
Event Code: 1001
Record Number: 285382
Time Written: 12-01-2018 @ 14:54:38
User:
Message:
that you continue.
Attribute record of type 0x80 and instance tag 0x5 is cross linked
starting at 0x978024 for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x5
in file 0x12106 is already in use.
Deleting corrupt attribute record (128, "")
from file record segment 73990.
Attribute record of type 0x80 and instance tag 0x3 is cross linked
starting at 0xc1803b for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x3
in file 0x7c28d is already in use.
from file record segment 508557.
Attribute record of type 0x80 and instance tag 0x4 is cross linked
starting at 0xc1804c for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x4
in file 0x7ddf8 is already in use.
from file record segment 515576.
starting at 0xc1804d for possibly 0x1 clusters.
in file 0x7ddf9 is already in use.
from file record segment 515577.
starting at 0x97804d for possibly 0x3 clusters.
in file 0xc3529 is already in use.
from file record segment 800041.
starting at 0x97803d for possibly 0x8 clusters.
in file 0xdffba is already in use.
from file record segment 917434.
starting at 0x978035 for possibly 0x8 clusters.
in file 0xdffbc is already in use.
from file record segment 917436.
starting at 0x97802d for possibly 0x8 clusters.
in file 0xdffc1 is already in use.
from file record segment 917441.
starting at 0x978025 for possibly 0x8 clusters.
in file 0xdffc2 is already in use.
from file record segment 917442.
starting at 0x978003 for possibly 0x21 clusters.
in file 0xe425f is already in use.
from file record segment 934495.
starting at 0xc1804e for possibly 0x1 clusters.
in file 0xf505d is already in use.
from file record segment 1003613.
starting at 0x978045 for possibly 0x8 clusters.
in file 0xfe37a is already in use.
from file record segment 1041274.
Attribute record of type 0xa0 and instance tag 0x3 is cross linked
starting at 0x978050 for possibly 0x2 clusters.
Some clusters occupied by attribute of type 0xa0 and instance tag 0x3
in file 0x10882d is already in use.
Deleting corrupt attribute record (160, $I30)
from file record segment 1083437.
starting at 0x978000 for possibly 0x3 clusters.
in file 0x108d9c is already in use.
from file record segment 1084828.
starting at 0x978052 for possibly 0x3 clusters.
in file 0x108de9 is already in use.
from file record segment 1084905.
starting at 0x978055 for possibly 0x3 clusters.
in file 0x108dea is already in use.
from file record segment 1084906.
starting at 0x978058 for possibly 0x3 clusters.
in file 0x108dee is already in use.
from file record segment 1084910.
starting at 0x97805b for possibly 0x3 clusters.
in file 0x108dfa is already in use.
from file record segment 1084922.
starting at 0x97805e for possibly 0x2 clusters.
in file 0x108e0c is already in use.
from file record segment 1084940.
starting at 0x4d005b for possibly 0x5 clusters.
in file 0x109b11 is already in use.
from file record segment 1088273.
starting at 0x4d0000 for possibly 0x3 clusters.
in file 0x10fc7d is already in use.
from file record segment 1113213.
starting at 0xc18001 for possibly 0x1 clusters.
in file 0x117731 is already in use.
from file record segment 1144625.
starting at 0xc18002 for possibly 0x1 clusters.
in file 0x117732 is already in use.
from file record segment 1144626.
starting at 0xc18044 for possibly 0x1 clusters.
in file 0x117734 is already in use.
from file record segment 1144628.
starting at 0xc18046 for possibly 0x1 clusters.
in file 0x117735 is already in use.
from file record segment 1144629.
starting at 0xc18045 for possibly 0x1 clusters.
in file 0x117737 is already in use.
from file record segment 1144631.
starting at 0xc18047 for possibly 0x1 clusters.
in file 0x117738 is already in use.
from file record segment 1144632.
starting at 0xc18048 for possibly 0x1 clusters.
in file 0x11773c is already in use.
from file record segment 1144636.
starting at 0xc18049 for possibly 0x1 clusters.
in file 0x117741 is already in use.
from file record segment 1144641.
starting at 0xc1804a for possibly 0x1 clusters.
in file 0x117744 is already in use.
from file record segment 1144644.
starting at 0xc1804b for possibly 0x1 clusters.
in file 0x117745 is already in use.
from file record segment 1144645.
starting at 0xc18059 for possibly 0x1 clusters.
in file 0x117747 is already in use.
from file record segment 1144647.
starting at 0xc1805a for possibly 0x1 clusters.
in file 0x117748 is already in use.
from file record segment 1144648.
starting at 0xc1805c for possibly 0x1 clusters.
in file 0x11774c is already in use.
from file record segment 1144652.
starting at 0xc1805d for possibly 0x1 clusters.
in file 0x11774e is already in use.
from file record segment 1144654.
starting at 0xc1805e for possibly 0x1 clusters.
in file 0x117751 is already in use.
from file record segment 1144657.
starting at 0xc1805b for possibly 0x1 clusters.
in file 0x11843e is already in use.
from file record segment 1147966.
1173248 file records processed.
680 large file records processed.
The index bitmap for index $I30 in file 0x10882d is invalid or missing.
Correcting error in index $I30 for file 1083437.
The index bitmap $I30 is present but there is no corresponding
index allocation attribute in file 0x10882d.
The down pointer of current index entry with length 0x78 is invalid.
37 88 10 00 00 00 01 00 78 00 5a 00 01 00 00 00 7.......x.Z.....
2d 88 10 00 00 00 01 00 91 75 c1 82 36 15 cf 01 -........u..6...
00 5a 55 3a 8c f1 cd 01 a2 9c c1 82 36 15 cf 01 .ZU:........6...
91 75 c1 82 36 15 cf 01 00 40 00 00 00 00 00 00 .u..6....@......
fa 3a 00 00 00 00 00 00 20 00 00 00 00 00 00 00 .:...... .......
0c 02 53 00 4d 00 5f 00 46 00 4f 00 55 00 7e 00 ..S.M._.F.O.U.~.
31 00 2e 00 50 00 4e 00 47 00 65 00 2e 00 68 00 1...P.N.G.e...h.
ff ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 ................
18 00 00 00 03 00 00 00 ff ff ff ff ff ff ff ff ................
Sorting index $I30 in file 1083437.
The index bitmap for index $I30 in file 0x117735 is invalid or missing.
Correcting error in index $I30 for file 1144629.
index allocation attribute in file 0x117735.
The down pointer of current index entry with length 0x18 is invalid.
00 00 00 00 00 00 00 00 18 00 00 00 03 00 00 00 ................
ff ff ff ff ff ff ff ff 1b 0a ef d4 36 15 cf 01 ............6...
00 f0 da 8a cc fe cd 01 2c 31 ef d4 36 15 cf 01 ........,1..6...
Sorting index $I30 in file 1144629.
1305470 index entries processed.
CHKDSK is scanning unindexed files for reconnect to their original directory.
Recovering orphaned file SM_DOU~1.HTM (1083438) into directory file 1083437.
Recovering orphaned file sm_double_pendulum.html (1083438) into directory file 1083437.
Recovering orphaned file SM_FOU~1.HTM (1083439) into directory file 1083437.
Recovering orphaned file sm_four_bar.html (1083439) into directory file 1083437.
Recovering orphaned file SM_FRA~1.HTM (1083440) into directory file 1083437.
Recovering orphaned file sm_frame_tree.html (1083440) into directory file 1083437.
Recovering orphaned file SM_SIM~1.HTM (1083441) into directory file 1083437.
Recovering orphaned file sm_simple_body.html (1083441) into directory file 1083437.
Recovering orphaned file SM_PEN~1.HTM (1083442) into directory file 1083437.
Recovering orphaned file sm_pendulum_waves.html (1083442) into directory file 1083437.
Recovering orphaned file SM_COM~1.HTM (1083443) into directory file 1083437.
Recovering orphaned file sm_compound_body.html (1083443) into directory file 1083437.
Recovering orphaned file SM_PEN~1.PNG (1083444) into directory file 1083437.
Recovering orphaned file sm_pendulum_waves_01.png (1083444) into directory file 1083437.
Recovering orphaned file SM_DOU~1.PNG (1083445) into directory file 1083437.
Recovering orphaned file sm_double_pendulum.png (1083445) into directory file 1083437.
Recovering orphaned file SM_SIM~1.PNG (1083446) into directory file 1083437.
Recovering orphaned file sm_simple_body_01.png (1083446) into directory file 1083437.
Recovering orphaned file sm_four_bar.png (1083447) into directory file 1083437.
Recovering orphaned file SM_DOU~2.PNG (1083448) into directory file 1083437.
Recovering orphaned file sm_double_pendulum_01.png (1083448) into directory file 1083437.
Recovering orphaned file SM_COM~1.PNG (1083449) into directory file 1083437.
Recovering orphaned file sm_compound_body.png (1083449) into directory file 1083437.
Recovering orphaned file SM_COM~2.PNG (1083450) into directory file 1083437.
Recovering orphaned file sm_compound_body_01.png (1083450) into directory file 1083437.
Recovering orphaned file SM_FRA~1.PNG (1083451) into directory file 1083437.
Recovering orphaned file sm_frame_tree.png (1083451) into directory file 1083437.
Recovering orphaned file SM_FOU~2.PNG (1083452) into directory file 1083437.
Recovering orphaned file sm_four_bar_01.png (1083452) into directory file 1083437.
Recovering orphaned file SM_FRA~2.PNG (1083453) into directory file 1083437.
Recovering orphaned file sm_frame_tree_01.png (1
Category: 0
Event Code: 1001
Record Number: 248672
Time Written: 03-13-2014 @ 00:55:30
User:
Message:
that you continue.
starting at 0x40002 for possibly 0x5c clusters.
in file 0x670a1 is already in use.
from file record segment 422049.
starting at 0xb7fe30 for possibly 0x2e3 clusters.
in file 0x7a884 is already in use.
from file record segment 501892.
starting at 0x40000 for possibly 0x2 clusters.
in file 0x94e8d is already in use.
from file record segment 609933.
starting at 0x4005e for possibly 0x2 clusters.
in file 0x94ec8 is already in use.
from file record segment 609992.
starting at 0x1398000 for possibly 0x54 clusters.
in file 0x98fa7 is already in use.
from file record segment 626599.
starting at 0xef8005 for possibly 0x1 clusters.
in file 0xa016c is already in use.
from file record segment 655724.
starting at 0xef8006 for possibly 0x8 clusters.
in file 0xa016d is already in use.
from file record segment 655725.
starting at 0xef8012 for possibly 0x1 clusters.
in file 0xa016e is already in use.
from file record segment 655726.
starting at 0xef8013 for possibly 0x1 clusters.
in file 0xa016f is already in use.
from file record segment 655727.
starting at 0xef8014 for possibly 0x8 clusters.
in file 0xa0170 is already in use.
from file record segment 655728.
starting at 0xef801c for possibly 0x7 clusters.
in file 0xa0171 is already in use.
from file record segment 655729.
starting at 0xef8024 for possibly 0x8 clusters.
in file 0xa0172 is already in use.
from file record segment 655730.
starting at 0xef802c for possibly 0x1 clusters.
in file 0xa0173 is already in use.
from file record segment 655731.
starting at 0xef802d for possibly 0x1 clusters.
in file 0xa0174 is already in use.
from file record segment 655732.
starting at 0xef802e for possibly 0x1 clusters.
in file 0xa0175 is already in use.
from file record segment 655733.
starting at 0xef802f for possibly 0x1 clusters.
in file 0xa0176 is already in use.
from file record segment 655734.
starting at 0xef8030 for possibly 0x1 clusters.
in file 0xa0177 is already in use.
from file record segment 655735.
starting at 0xef8031 for possibly 0x6 clusters.
in file 0xa0178 is already in use.
from file record segment 655736.
starting at 0xef8039 for possibly 0x8 clusters.
in file 0xa0179 is already in use.
from file record segment 655737.
starting at 0xef8041 for possibly 0x7 clusters.
in file 0xa017a is already in use.
from file record segment 655738.
starting at 0xef8049 for possibly 0x7 clusters.
in file 0xa017b is already in use.
from file record segment 655739.
starting at 0xef8051 for possibly 0x1 clusters.
in file 0xa017c is already in use.
from file record segment 655740.
starting at 0xef8052 for possibly 0x1 clusters.
in file 0xa017d is already in use.
from file record segment 655741.
starting at 0xef8053 for possibly 0x1 clusters.
in file 0xa017e is already in use.
from file record segment 655742.
starting at 0xef805c for possibly 0x1 clusters.
in file 0xa017f is already in use.
from file record segment 655743.
starting at 0xef805d for possibly 0x1 clusters.
in file 0xa0180 is already in use.
from file record segment 655744.
starting at 0xef805e for possibly 0x1 clusters.
in file 0xa0181 is already in use.
from file record segment 655745.
starting at 0xef8054 for possibly 0x8 clusters.
in file 0xc2ff7 is already in use.
from file record segment 798711.
starting at 0xef8000 for possibly 0x5 clusters.
in file 0xc6a9d is already in use.
from file record segment 813725.
starting at 0xef800e for possibly 0x4 clusters.
in file 0xdb982 is already in use.
from file record segment 899458.
starting at 0xef8037 for possibly 0x2 clusters.
in file 0xedab6 is already in use.
from file record segment 973494.
starting at 0x1398054 for possibly 0x5 clusters.
in file 0xfa891 is already in use.
from file record segment 1026193.
starting at 0x1398059 for possibly 0x4 clusters.
in file 0xfa937 is already in use.
from file record segment 1026359.
starting at 0x139805d for possibly 0x3 clusters.
in file 0x10ba3e is already in use.
from file record segment 1096254.
starting at 0x159fffb for possibly 0xd clusters.
in file 0x119052 is already in use.
from file record segment 1151058.
starting at 0x15a0008 for possibly 0xb clusters.
in file 0x119063 is already in use.
from file record segment 1151075.
starting at 0x15a0013 for possibly 0x8 clusters.
in file 0x11906f is already in use.
from file record segment 1151087.
starting at 0x15a001b for possibly 0xb clusters.
in file 0x11908c is already in use.
from file record segment 1151116.
starting at 0x15a0026 for possibly 0x4 clusters.
in file 0x11ad96 is already in use.
from file record segment 1158550.
1171968 file records processed.
615 large file records processed.
The index bitmap for index $I30 in file 0x94e8d is invalid or missing.
Correcting error in index $I30 for file 609933.
index allocation attribute in file 0x94e8d.
The down pointer of current index entry with length 0x70 is invalid.
9e 4e 09 00 00 00 01 00 70 00 56 00 01 00 00 00 .N......p.V.....
8d 4e 09 00 00 00 01 00 c0 77 99 f9 a2 8b ce 01 .N.......w......
c0 77 99 f9 a2 8b ce 01 c0 77 99 f9 a2 8b ce 01 .w.......w......
c0 77 99 f9 a2 8b ce 01 60 00 00 00 00 00 00 00 .w......`.......
59 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 Y....... .......
0a 01 4b 00 69 00 72 00 69 00 74 00 69 00 6d 00 ..K.i.r.i.t.i.m.
61 00 74 00 69 00 00 00 ff ff ff ff ff ff ff ff a.t.i...........
Sorting index $I30 in file 609933.
The multi-sector header signature for VCN 0x29 of index $I30
in file 0x9fff0 is incorrect.
69 6f 6e 40 4a 53 43 40 40 32 55 43 6c 61 73 73 ion@JSC@@2UClass
49 6e 66 6f 40 32 40 42 00 3f 69 6e 66 6f 40 53 Info@2@B.?info@S
The multi-sector header signature for VCN 0x2b of index $I30
57 65 62 50 61 67 65 40 40 41 42 56 51 53 74 72 WebPage@@ABVQStr
69 6e 67 40 40 40 5a 00 3f 71 74 77 65 62 6b 69 ing@@@Z.?qtwebki
Correcting error in index $I30 for file 655344.
The multi-sector header signature for VCN 0x2e of index $I30
70 5a 51 10 f0 5a 51 10 f0 59 51 10 70 5a 51 10 pZQ..ZQ..YQ.pZQ.
b8 c4 6a 10 00 00 00 00 2e 3f 41 56 4a 53 43 65 ..j......?AVJSCe
The multi-sector header signature for VCN 0x2f of index $I30
40 40 00 00 b8 c4 6a 10 00 00 00 00 2e 3f 41 56 @@....j......?AV
42 6f 6f 6c 65 61 6e 4e 6f 64 65 40 4a 53 43 40 BooleanNode@JSC@
The multi-sector header signature for VCN 0x28 of index $I30
4d 41 45 58 50 41 56 51 44 72 6f 70 45 76 65 6e MAEXPAVQDropEven
74 40 40 40 5a 00 3f 65 6c 65 6d 65 6e 74 40 51 t@@@Z.?element@Q
The multi-sector header signature for VCN 0x2d of index $I30
3f 41 56 51 53 74 72 69 6e 67 40 40 50 42 44 30 ?AVQString@@PBD0
48 40 5a 00 3f 74 72 40 51 57 65 62 56 69 65 77 H@Z.?tr@QWebView
The multi-sector header signature for VCN 0x2c of index $I30
5a 00 3f 73 65 74 50 6c 61 69 6e 54 65 78 74 40 Z.?setPlainText@
51 57 65 62 45 6c 65 6d 65 6e 74 40 40 51 41 45 QWebElement@@QAE
The multi-sector header signature for VCN 0x2a of index $I30
51 47 72 61 70 68 69 63 73 53 63 65 6e 65 4d 6f QGraphicsSceneMo
75 73 65 45 76 65 6e 74 40 40 40 5a 00 3f 6d 6f useEvent@@@Z.?mo
The index bitmap $I30 in file 0x9fff0 is incorrect.
e5 00 0a 00 00 00 01 00 78 00 5a 00 01 00 00 00 ........x.Z.....
f0 ff 09 00 00 00 01 00 e3 2c d1 b5 fe da ce 01 .........,......
00 3d f8 e7 3d 84 ce 01 f4 53 d1 b5 fe da ce 01 .=..=....S......
e3 2c d1 b5 fe da ce 01 00 80 00 00 00 00 00 00 .,..............
a4 73 00 00 00 00 00 00 20 00 00 00 00 00 00 00 .s...... .......
0c 02 4d 00 58 00 53 00 45 00 54 00 43 00 7e 00 ..M.X.S.E.T.C.~.
31 00 2e 00 48 00 54 00 4d 00 6d 00 6c 00 6b 00 1...H.T.M.m.l.k.
ff ff ff ff ff ff ff ff 1f 00 0a 00 00 00 01 00 ................
78 00 5a 00 01 00 00 00 f0 ff 09 00 00 00 01 00 x.Z.............
Something is fishy here:
GSmartControl
  • Execute gsmartcontrol.exe; Let the install complete and launch the programme.
I'm not sure that will be possible in the near future :( I guess it's not possible to do the updates then?
Anyways, thank you so much for all the assistance.
