[SOLVED] [Win10v1511Build10586 x64] dism error 193 and sfc /scannow both fail
Re: dism error 193 and sfc /scannow both fail
Start time: 2017-04-24 09:21:48.527
Microsoft Windows 10 Build 10586 - amd64
Using .zip script file at C:\Users\Jesus\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-i..er-engine.resources_31bf3856ad364e35_10.0.10586.0_ja-jp_0277d09dc65d9b8d\msimsg.dll.mui
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-i..er-engine.resources_31bf3856ad364e35_10.0.10586.0_ja-jp_0277d09dc65d9b8d\msimsg.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-i..er-engine.resources_31bf3856ad364e35_10.0.10586.0_ja-jp_0277d09dc65d9b8d\msimsg.dll.mui.
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-i..er-engine.resources_31bf3856ad364e35_10.0.10586.0_ja-jp_0277d09dc65d9b8d\msimsg.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-i..er-engine.resources_31bf3856ad364e35_10.0.10586.0_ja-jp_0277d09dc65d9b8d\msimsg.dll.mui
Currently storing 109 datablocks.
Finish time: 2017-04-24 09:21:49.574
Script hash: WAZKwpZ7C9kHlH57DzoeWop9oj5/uc5OU0oO2pFIWBA=
Another to fix.
2017-04-24 08:45:55, Info                  CBS    Failed to load package: Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
Please do the following.
Step#1 - SFCFix Script
Start time: 2017-04-24 09:32:04.614
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Currently storing 111 datablocks.
Finish time: 2017-04-24 09:32:05.833
Script hash: 849GuYVlhMdihgq7Nz78CJJH2Qvwe6hHanQ7KsrFXWk=
Please try the following again.
OK, let's fix the following.
amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui do not match actual file [l:13]"mlang.dll.mui" :
amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui do not match actual file [l:13]"mlang.dll.mui" :
amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll do not match actual file [l:12]"prflbmsg.dll" :
amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll do not match actual file [l:11]"raschap.dll" :
amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui do not match actual file [l:15]"vdsutil.dll.mui" :
amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat do not match actual file [l:25]"VoiceActivation_en-US.dat" :
wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM do not match actual file [l:12]"M1033DAV.APM" :
Start time: 2017-04-24 11:39:25.098
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM to C:\WINDOWS\Winsxs\wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat to C:\WINDOWS\Winsxs\amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll to C:\WINDOWS\Winsxs\amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll to C:\WINDOWS\Winsxs\amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui.
Successfully restored ownership for C:\WINDOWS\Winsxs\wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM
Successfully restored permissions on C:\WINDOWS\Winsxs\wow64_microsoft-windows-t..tospeech-en-us-male_31bf3856ad364e35_10.0.10586.0_none_709d2af42b033207\M1033DAV.APM
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-voiceactivation-en-us_31bf3856ad364e35_10.0.10586.0_none_827bf0209d7337fc\VoiceActivation_en-US.dat
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-v..skservice.resources_31bf3856ad364e35_10.0.10586.0_en-us_2e9674cb96d5ea3b\vdsutil.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-raschap_31bf3856ad364e35_10.0.10586.0_none_9f449b5e21a3aa17\raschap.dll
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-p..structure-minkernel_31bf3856ad364e35_10.0.10586.0_none_657a99e26120d968\prflbmsg.dll
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sv-se_f7e43d560553e911\mlang.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-mlang.resources_31bf3856ad364e35_10.0.10586.0_sr-..-rs_a046e18a78f08af4\mlang.dll.mui
Currently storing 118 datablocks.
Finish time: 2017-04-24 11:39:29.293
Script hash: xgFDnfzyfBzfXO2qk1EJkQzBfBWJ/Qk7pJA7i/1c26c=
Alright progress. It failed and log attached but my internet connection was down as message said could not download source files. I do have the ISO for version 1511 if that could be used. My ultimate goal is to upgrade to latest OS but preserve the apps and files on this laptop.
Start time: 2017-04-24 15:29:30.292
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_wnetvsc.inf_31bf3856ad364e35_10.0.10586.0_none_e3a3c42279d2ffd0\netvsc.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvraid.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvstor.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_netnvma.inf_31bf3856ad364e35_10.0.10586.0_none_be914abbd238f2fd\nvm60x64.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_netnvm64.inf_31bf3856ad364e35_10.0.10586.0_none_5b1d69ca6dcba042\nvm62x64.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_netjme.inf_31bf3856ad364e35_10.0.10586.0_none_785dd5ba9f8c77a5\NETJME.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_mwlu97w8x64.inf_31bf3856ad364e35_10.0.10586.0_none_d78c20e3fff6e278\mwlu97w8x64.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_msports.inf_31bf3856ad364e35_10.0.10586.212_none_65c0da6f174d48b5\parport.sys
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-w..ck-legacy.resources_31bf3856ad364e35_10.0.10586.0_en-us_d841540444632a40\wsock32.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-t..ork-msctf.resources_31bf3856ad364e35_10.0.10586.0_en-us_33eac725639c90bd\msctf.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-scripting.resources_31bf3856ad364e35_10.0.10586.0_en-us_17b2396801cad9cd\wshom.ocx.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-s..container.resources_31bf3856ad364e35_10.0.10586.0_en-us_e55226a1a2c7367c\microsoft-windows-sleepstudy-events.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-mapi.resources_31bf3856ad364e35_10.0.10586.0_en-us_b700b88a948f5d6f\mapi32.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-m..nager-rll.resources_31bf3856ad364e35_10.0.10586.0_en-us_bc62e40afdc67ade\odbcint.dll.mui
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_wnetvsc.inf_31bf3856ad364e35_10.0.10586.0_none_e3a3c42279d2ffd0\netvsc.sys to C:\WINDOWS\Winsxs\amd64_wnetvsc.inf_31bf3856ad364e35_10.0.10586.0_none_e3a3c42279d2ffd0\netvsc.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvraid.sys to C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvraid.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvstor.sys to C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvstor.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_netnvma.inf_31bf3856ad364e35_10.0.10586.0_none_be914abbd238f2fd\nvm60x64.sys to C:\WINDOWS\Winsxs\amd64_netnvma.inf_31bf3856ad364e35_10.0.10586.0_none_be914abbd238f2fd\nvm60x64.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_netnvm64.inf_31bf3856ad364e35_10.0.10586.0_none_5b1d69ca6dcba042\nvm62x64.sys to C:\WINDOWS\Winsxs\amd64_netnvm64.inf_31bf3856ad364e35_10.0.10586.0_none_5b1d69ca6dcba042\nvm62x64.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_netjme.inf_31bf3856ad364e35_10.0.10586.0_none_785dd5ba9f8c77a5\NETJME.sys to C:\WINDOWS\Winsxs\amd64_netjme.inf_31bf3856ad364e35_10.0.10586.0_none_785dd5ba9f8c77a5\NETJME.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_mwlu97w8x64.inf_31bf3856ad364e35_10.0.10586.0_none_d78c20e3fff6e278\mwlu97w8x64.sys to C:\WINDOWS\Winsxs\amd64_mwlu97w8x64.inf_31bf3856ad364e35_10.0.10586.0_none_d78c20e3fff6e278\mwlu97w8x64.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_msports.inf_31bf3856ad364e35_10.0.10586.212_none_65c0da6f174d48b5\parport.sys to C:\WINDOWS\Winsxs\amd64_msports.inf_31bf3856ad364e35_10.0.10586.212_none_65c0da6f174d48b5\parport.sys.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-w..ck-legacy.resources_31bf3856ad364e35_10.0.10586.0_en-us_d841540444632a40\wsock32.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-w..ck-legacy.resources_31bf3856ad364e35_10.0.10586.0_en-us_d841540444632a40\wsock32.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-t..ork-msctf.resources_31bf3856ad364e35_10.0.10586.0_en-us_33eac725639c90bd\msctf.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-t..ork-msctf.resources_31bf3856ad364e35_10.0.10586.0_en-us_33eac725639c90bd\msctf.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-scripting.resources_31bf3856ad364e35_10.0.10586.0_en-us_17b2396801cad9cd\wshom.ocx.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-scripting.resources_31bf3856ad364e35_10.0.10586.0_en-us_17b2396801cad9cd\wshom.ocx.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-s..container.resources_31bf3856ad364e35_10.0.10586.0_en-us_e55226a1a2c7367c\microsoft-windows-sleepstudy-events.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-s..container.resources_31bf3856ad364e35_10.0.10586.0_en-us_e55226a1a2c7367c\microsoft-windows-sleepstudy-events.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-mapi.resources_31bf3856ad364e35_10.0.10586.0_en-us_b700b88a948f5d6f\mapi32.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-mapi.resources_31bf3856ad364e35_10.0.10586.0_en-us_b700b88a948f5d6f\mapi32.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-m..nager-rll.resources_31bf3856ad364e35_10.0.10586.0_en-us_bc62e40afdc67ade\odbcint.dll.mui to C:\WINDOWS\Winsxs\amd64_microsoft-windows-m..nager-rll.resources_31bf3856ad364e35_10.0.10586.0_en-us_bc62e40afdc67ade\odbcint.dll.mui.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat to C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat.
Successfully copied file C:\Users\Jesus\AppData\Local\niemiro\Archive\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum to C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum.
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_wnetvsc.inf_31bf3856ad364e35_10.0.10586.0_none_e3a3c42279d2ffd0\netvsc.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_wnetvsc.inf_31bf3856ad364e35_10.0.10586.0_none_e3a3c42279d2ffd0\netvsc.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvraid.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvraid.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvstor.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_nvraid.inf_31bf3856ad364e35_10.0.10586.0_none_c6605b806955d798\nvstor.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_netnvma.inf_31bf3856ad364e35_10.0.10586.0_none_be914abbd238f2fd\nvm60x64.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_netnvma.inf_31bf3856ad364e35_10.0.10586.0_none_be914abbd238f2fd\nvm60x64.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_netnvm64.inf_31bf3856ad364e35_10.0.10586.0_none_5b1d69ca6dcba042\nvm62x64.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_netnvm64.inf_31bf3856ad364e35_10.0.10586.0_none_5b1d69ca6dcba042\nvm62x64.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_netjme.inf_31bf3856ad364e35_10.0.10586.0_none_785dd5ba9f8c77a5\NETJME.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_netjme.inf_31bf3856ad364e35_10.0.10586.0_none_785dd5ba9f8c77a5\NETJME.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_mwlu97w8x64.inf_31bf3856ad364e35_10.0.10586.0_none_d78c20e3fff6e278\mwlu97w8x64.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_mwlu97w8x64.inf_31bf3856ad364e35_10.0.10586.0_none_d78c20e3fff6e278\mwlu97w8x64.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_msports.inf_31bf3856ad364e35_10.0.10586.212_none_65c0da6f174d48b5\parport.sys
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_msports.inf_31bf3856ad364e35_10.0.10586.212_none_65c0da6f174d48b5\parport.sys
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-w..ck-legacy.resources_31bf3856ad364e35_10.0.10586.0_en-us_d841540444632a40\wsock32.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-w..ck-legacy.resources_31bf3856ad364e35_10.0.10586.0_en-us_d841540444632a40\wsock32.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-t..ork-msctf.resources_31bf3856ad364e35_10.0.10586.0_en-us_33eac725639c90bd\msctf.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-t..ork-msctf.resources_31bf3856ad364e35_10.0.10586.0_en-us_33eac725639c90bd\msctf.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-scripting.resources_31bf3856ad364e35_10.0.10586.0_en-us_17b2396801cad9cd\wshom.ocx.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-scripting.resources_31bf3856ad364e35_10.0.10586.0_en-us_17b2396801cad9cd\wshom.ocx.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-s..container.resources_31bf3856ad364e35_10.0.10586.0_en-us_e55226a1a2c7367c\microsoft-windows-sleepstudy-events.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-s..container.resources_31bf3856ad364e35_10.0.10586.0_en-us_e55226a1a2c7367c\microsoft-windows-sleepstudy-events.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-mapi.resources_31bf3856ad364e35_10.0.10586.0_en-us_b700b88a948f5d6f\mapi32.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-mapi.resources_31bf3856ad364e35_10.0.10586.0_en-us_b700b88a948f5d6f\mapi32.dll.mui
Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-m..nager-rll.resources_31bf3856ad364e35_10.0.10586.0_en-us_bc62e40afdc67ade\odbcint.dll.mui
Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-m..nager-rll.resources_31bf3856ad364e35_10.0.10586.0_en-us_bc62e40afdc67ade\odbcint.dll.mui
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Fonts-MinConsoleFonts-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-com-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-CoreSystem-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-DiskIo-ResourceControls-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-TroubleShooting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Core-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package-minkernel~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BootEnvironment-Dvd-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-BuildFlighting-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-vm-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package-windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ConsoleHost-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-Power-Cmdline-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Client-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-CoreSystem-RemoteFS-Server-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mergedcomponents-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-mincore-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-minkernel-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Foundation-Group-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetBIOS-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-minio-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Network-Foundation-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Admin-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Core-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Ds-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Full-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Inetsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Net-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Shell-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Termsrv-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-CrossArch-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Extra-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Windows-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SMB1-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~en-US~10.0.10586.0.mum
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.cat
Successfully restored ownership for C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Successfully restored permissions on C:\WINDOWS\Servicing\Packages\Multimedia-MMECoreBase-Package~31bf3856ad364e35~amd64~~10.0.10586.0.mum
Currently storing 376 datablocks.
Finish time: 2017-04-24 15:31:07.234
Script hash: yPUBXRXZyKBywn2EiYebIJyQ3Ge3xO9EslQZDzeWgfQ=
Please try the following again.
Hi Brian,
It restored successfully! Yeah! and many thanks. Are we done and then can or should I move to Creator's Upgrade now? I do have a boot usb but worried about some threads indicating dism failures. I'm also curious how this system got into this bad state. If you have clues, please share so it can be prevented in the future.
Excellent. You are good to go. Go ahead and upgrade. You can use your USB (just don't boot to it otherwise it will wipe your system) or use the following instructions. Unfortunately I don't know how your system got the way it was.
1. Download the Media Creation Tool and save this to your desktop. Go ahead and run this as well. Note: Click the Download tool now button when you get to this link.
2. Accept the License Agreement
3. Keep the default Upgrade this PC option and click Next.
4. Let this process complete the upgrade to the newest build and let me know when complete.
Hi Brian,
I am upgraded to 1703 without incident and have made a backup image as well. Thanks, Thanks, and Thank you so much!!!
