[SOLVED] (Win7 x64) Update problem, error 80073701
We're getting there...only KB3150553 left now :-)
CheckSUR.log :
Binary Version 6.1.7601.22471
Package Version 26.0
2018-05-01 16:02
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
(f) CBS MUM Missing 0x00000002 servicing\Packages\Package_1_for_KB3150513~31bf3856ad364e35~amd64~~6.1.1.4.mum
Checking Component Store
Summary:
Seconds executed: 439
Found 1 errors
CBS MUM Missing Total count: 1
Unavailable repair files:
servicing\packages\Package_1_for_KB3150513~31bf3856ad364e35~amd64~~6.1.1.4.mum
servicing\packages\Package_1_for_KB3150513~31bf3856ad364e35~amd64~~6.1.1.4.cat
Remove Update Manually
wusa /uninstall /KB:3150513
Step#1 - FRST Fix
5. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply
Brilliant....that did the job, methinks. Windows Update seems clean now, as confirmed by SURT :
2018-05-01 16:56
Checking Packages
Summary:
Seconds executed: 428
No errors detected
Should I try avoid the two deleted updates (KB2952664 and KB3150513 ? They are offered again, as "important"...
The two updates we jusr deleted (KB2852664 and KB3150513) installed just fine
April Security Monthly Rollup (KB4093118) failed again with the error 80073701.
CBS log :
OneDrive CBS.log
wusa /uninstall /KB:4048957
Step#1 - FRST Fix
Phew ! The April update first reported success, rebooted, and failed at 98% configuration.
On a hunch, I disabled my Webroot firewall and tried it again....this time it was successful !
Not sure which service or process Webroot was blocking, as the program has no usable logging functionality.
