[SOLVED] [Win7SP1Pro x64] WU Issue
Re: [Win7Pro x64] WU Issue
You should be able to attach more than 5 files in total, although I think the max you can attach to asingle post is 5. Can you send me a screenshot of what you're seeing?
Alternatively, please go to this page: https://www.sysnative.com/forums/profile.php?do=editoptions, scroll down and switch Enhanced Attachment Uploading off. Then try again.
Stephen
I was being proactive. I did not have a problem, but the last Attachment was the 5th for the issue I am chasing.
Thanks for the pointer.
I re-ran CheckSur and the log is attached at #21. As a result of the running I ended up with Links to the majority of applications on my desktop.
I will have several fixes for you. They are fairly large so I am going to send one at a time and confirm it was successful. Please start with the following.
Step#1 - SFCFix Script
Questions: I have already attached 4 files. How do I clean them up as Attached only allows 5?View attachment 26395
I believe the actual number of attachments allowed per post is 8. I set the forum up back in 2012 to only show 5 attachment boxes. So after you upload 5 in one shot, you should be allowed to upload another 3 for any single post.
The number of attachments allowed per thread =(your number of posts * 8). There is no maximum.
John
Sorry for the delay. Please do the following.
Retrieve Components Hive
After #28 I registered with sendspace. I think I now have my copy of components.zip at
/file/q2hult
Were you able to see the Components?
Please do the following again. Ensure you let it run to completion.
System Update Readiness Tool (SUR)
I was looking at the CHECKSUR text and noticed it referenced AVAST. I removed AVAST. I certainly do not want it put back.
Exactly what is CHECKSUR doing?
Thanks
Unfortunately I feel there are too many errors to surgicaly fix. CheckSUR looks to your registry to see what it is expecting and then looks for those files and ensures they are there and correct. For whatever reason your machine is just missing too many to fix manually. Not sure what caused this. A repair install will correct this though. If you have your Windows 7 x64 With SP1 media you can do a reapair install following the instructions at the following link. No programs or data will be lost in the process but as always ensure you have a backup of anything critical in case things do go awry.
Repair Install - Windows 7 Help Forums
 Found 5489 errors
 Fixed 1100 errors
  CSI Manifest Missing Total count: 2390
  Fixed: CSI Manifest Missing.  Total count: 720
  CSI C Mark Deployment Missing Total count: 8
  CSI Payload File Missing Total count: 3091
  Fixed: CSI Payload File Missing.  Total count: 380
Thank you for all the time and effort and education you gave me on this issue. I will try the next rollup to see if we have fixed this issue. If not then it is the security portion.
Thanks Again.
