[SOLVED] Windbg Installation Location
This is my $_dvrref_table_98
[PLAIN]https://www.sysnative.com/drivers/driver.php?id=,http[i]:[/i]//sysnative.com/drivers/driver.php?id=
 [/PLAIN]
What does the
HTML:
      [i] [/i]
do in the URL ?
Since as soon as I removed them the program no longer hangs and does output references to the DRT...........
Once removed the script runs and works:wave:
That is really odd. Your memory dump actually showed it either failed to read the file, or that it read a blank file. It shouldn't have mattered at all about the [i]:[/i]. I wonder whether saving the file was what fixed it... I can't quite understand how the italics could have affected it anyway - they are simply used as a string, and not interpreted in any way.
Anyway, thanks for fixing it and letting me know. If you run into problems, you could always add the italic tags back, and I reacon that it will probably continue to work.
I'll try putting the code back in and see what happens.
Now that was on my laptop, the location issue is on the Desktop, now that I have 1 system working again I'll get back to the desktop tomorrow.
Is there an older version of windbg available for D/L somewhere?
$_dbugdir parm file
C:\Program Files\Debugging Tools for Windows (x64)\kd.exe
Place exact path for your installation + \kd.exe in that parm file.
No luck yet finding Windbg 6.11 or 6.12
I put the italics code back in and it works fine:confused2:
