Wndows 7 x64 Pro -- Security / Rollups always fail (0x80070057) -- Other types fine
I did the following:
1) Uninstalled MSE
2) Rebooted
Now Windows Update cannot search for updates.
Gives the error "Windows could not search for new updates" with the error code 8024402C.
I tried running the Windows Update Troubleshooter, letting it complete and rebooted again. I got the same error as above.
Restart Windows in Safe Mode w/networking.
Download Windows Repair (All-in-One) Portable
  • Extract the tweaking.com_windows_repair_aio.zip to c:\Windows\TEMP the zip will extract to a folder called Tweaking.com - Windows Repair
  • Execute the file Repair_Windows.exe from the Tweaking.com - Windows Repair folder, accept the Security warning and the EULA
  • Click the button Jump To Repairs
  • Click the Open Repairs button to access the following screen:
  • Click the box All Repairs to uncheck all the boxes
  • Check only the following boxes:
    • 16 - Repair Windows Updates
  • Check the box Restart/Shutdown System When Finished > Restart System
  • Click the Start Repairs button
  • When the system reboots, attempt the updates again.
Partial success, the Security/Quality Rollups for the .NET Framework installed now when they did not in the past.
Am still getting failures with the Security Monthly Quality Rollup for Windows 7 (KB4480970) as well as the Cumulative Security Update for Internet Explorer 11 (KB4483187).
2. Try installing the update just like you have in the past.
For some reason, the latest ProcMon log wasn't particularly useful, please re-do it, but closer to failure + get my COMPONENTS hive:
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload to a file sharing service and just provide the link here.
Components.zip
Logfile.zip
Step#1 - FRST Fix
