HapaxOromenon
Well-known member
- Nov 3, 2018
- 81
Hello,
Today I tried to install the new Cumulative Update (KB4505903) and it got to "Installing 100%" but then gave error code 0x800f0982. Retrying it gave the same thing. I then tried deleting the contents of the SoftwareDistribution folder (after stopping the Windows Update service) but that again didn't help. Next I ran dism /cleanup-image /restorehealth, which got to 100% but then gave error code 0x800f081f: "the source files could not be found". I Googled this error code and the advice was to run dism with the /startcomponentcleanup switch, which completed successfully, then I reran the original /restorehealth command and it completed successfully this time. But the update still wouldn't install, giving the same error 0x800f0982. Finally I ran SFCFix, which initially said "Stage 1 of 6 failed on server", but the rest of the stages appeared to complete fine and it said "failed to create zip file with errno 2" followed by "scan completed with warnings". After that it said "Due to the nature of your corruptions, scan times have been extended by approximately 15-20 minutes. Please be patient and allow the operation to complete", but after it was done, it actually said it had detected 0 corruptions, as is also shown in its logfile. I nevertheless retried the update one more time and still the same error 0x800f0982 was obtained.
I attach the logfile (SFCFix.txt) along with a copy of my CBS folder and my COMPONENTS hive. Any assistance would be much appreciated.
