I am having latencies and DPC issues.
Windows is updated, drivers too.
I disabled all audio drivers and devices (realtek is off in the bios) because I have an USB audio card (Focusrite scarlette 2i4 2 Gen).
I've made the maximum optimsation, settings USB/hard drive/PC to power off, maximum performances, disable background apps, etc ...
(Optimising your PC for Audio on Windows 10 – Focusrite Audio Engineering)
After test with latencyMoon, this drivers seems to be the problem.
nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 416.34,
dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation,
Wdf01000.sys - Runtime de l’infrastructure de pilotes en mode noyau, Microsoft Corporation
I can't fix my CPU frequency to 3.7Ghz.. Try a lot of thing in BIOS.
CONCLUSION
LatencyMon has been analyzing your system for 1:04:56 (h:mm:ss) on processors 0,1,2,3,4,5,6 and 7.
SYSTEM INFORMATION
Computer name: DESKTOP-PT1OHLM
OS version: Windows 10 , 10.0, build: 17134 (x64)
Hardware: MS-7B79, Micro-Star International Co., Ltd., X470 GAMING PLUS (MS-7B79)
CPU: AuthenticAMD AMD Ryzen 7 2700X Eight-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 16332 MB total
CPU SPEED
Reported CPU speed: 370 MHz
Highest measured interrupt to process latency (µs): 100860,825467
Average measured interrupt to process latency (µs): 4,508899
Highest measured interrupt to DPC latency (µs): 100858,611410
Average measured interrupt to DPC latency (µs): 2,047086
REPORTED ISRs
Highest ISR routine execution time (µs): 249,20
Highest reported total ISR routine time (%): 0,028966
Total time spent in ISRs (%) 0,034765
ISR count (execution time <250 µs): 3298968
REPORTED DPCs
Highest DPC routine execution time (µs): 1079,60
Driver with highest DPC routine execution time: Wdf01000.sys - Runtime de l’infrastructure de pilotes en mode noyau, Microsoft Corporation
Highest reported total DPC routine time (%): 0,132684
Driver with highest DPC total execution time: Wdf01000.sys - Runtime de l’infrastructure de pilotes en mode noyau, Microsoft Corporation
Total time spent in DPCs (%) 0,172803
DPC count (execution time <250 µs): 11481383
DPC count (execution time 500-999 µs): 264
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: ableton live 10 suite.exe
Total number of hard pagefaults 4717
Hard pagefault count of hardest hit process: 588
Number of processes hit: 46
PER CPU DATA
CPU 0 Interrupt cycle time (s): 245,736470
CPU 0 ISR highest execution time (µs): 249,20
CPU 0 ISR total execution time (s): 19,289807
CPU 0 ISR count: 2985389
CPU 0 DPC highest execution time (µs): 1079,60
CPU 0 DPC total execution time (s): 97,215582
CPU 0 DPC count: 11014466
CPU 1 Interrupt cycle time (s): 105,081786
CPU 1 ISR highest execution time (µs): 208,540
CPU 1 ISR total execution time (s): 2,378546
CPU 1 ISR count: 312997
CPU 1 DPC highest execution time (µs): 661,940
CPU 1 DPC total execution time (s): 10,136335
CPU 1 DPC count: 375316
CPU 2 Interrupt cycle time (s): 66,946475
CPU 2 ISR highest execution time (µs): 133,380
CPU 2 ISR total execution time (s): 0,002901
CPU 2 ISR count: 582
CPU 2 DPC highest execution time (µs): 195,340
CPU 2 DPC total execution time (s): 0,035584
CPU 2 DPC count: 5972
CPU 3 Interrupt cycle time (s): 56,462269
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 105,040
CPU 3 DPC total execution time (s): 0,003689
CPU 3 DPC count: 1460
CPU 4 Interrupt cycle time (s): 65,123021
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 318,980
CPU 4 DPC total execution time (s): 0,252366
CPU 4 DPC count: 66959
CPU 5 Interrupt cycle time (s): 55,650673
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 162,380
CPU 5 DPC total execution time (s): 0,009587
CPU 5 DPC count: 3073
CPU 6 Interrupt cycle time (s): 85,347620
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 313,160
CPU 6 DPC total execution time (s): 0,052750
CPU 6 DPC count: 11769
CPU 7 Interrupt cycle time (s): 59,970463
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 121,530
CPU 7 DPC total execution time (s): 0,012738
CPU 7 DPC count: 2633
A
B,C in attachment
D http://speccy.piriform.com/results/JrvPxyS0ApWnwlghYNlZ5dC
F I can't, I have an error, and I have no "trace.etl" on desktop
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16332 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
A
- System Manufacturer? Custom PC
- Laptop or Desktop? Desktop
- Exact model number (if laptop, check label on bottom) Custom
- OS ? (Windows 10, 8.1, 8, 7, Vista) W10 17134
- x86 (32bit) or x64 (64bit)? x64
- Service pack? 17134
- What was original installed OS on system? W10
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? scdkey.com
- Age of system? (hardware) 5 months
- Age of OS installation? 1 month (re install -> format)
- Have you re-installed the OS? yes
- CPU Ryzen 2700X
- RAM (brand, EXACT model, what slots are you using?) G.Skill Ripjaws V Gris DDR4 2 x 8 Go 3200 MHz CAS 16
- Video Card Zotac GTX770
- MotherBoard - (if NOT a laptop) MSI X470 Gaming Plus
- Power Supply - brand & wattage (if laptop, skip this one) Antec High Current Pro Platinium 1000W
- Is driver verifier enabled or disabled? disabled
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Avira Antivirus
- Are you using proxy, vpn, ipfilters or similar software? no
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
- Are you currently under/overclocking? Are there overclocking software installed on your system? Trying to fix CPU ratio to 37 (3.7Ghz), disabled Spread spectrum/Amd cool & quiet in BIOS
B,C in attachment
