[10ProV1803b17134 x64] Audio Latency ACPI/Dxgkrnl/ndsis/wdf01000. HP BP004LA/BP005LA
This fidelizer sounds, from some of the features shown on the website, like a pretty nice program. Only thing I'm concerned about is "Stop/Disable most non-audio system services greatly reducing system footprints for pure audio performance.", if the wrong non-audio system service is stopped it will only give trouble. I'm sure the vendor has taken care of not disabling the onces that are absolutely necessary, but it's something that I wouldn't like.
For now is a good bandaid, still have some troubles but really improves things (at least latency)
I will totally do what you mention of formatting in the next weeks, right now i dont have enough time to backup + reinstall, but be sure i'll keep you posted.
(last time i reinstalled W10, some drivers were updated via windows update automatically is there a solid way to prevent this?)
Thanks
Drivers from Windows Update are usually quite solid, but if you want to prevent any driver being installed by Windows Update, in Control Panel go to System and click Advanced System Settings on the left. Go to the tab Hardware and click Device Installation Settings, select No (your device might not work as expected) and click Save Changes. However, I believe this will also prevent any automatic driver installations when you connect a new device, say a new storage device.
