[SOLVED] 2008 R2 SP1 issues installing updates
I ran a chkdsk earlier in my troubleshooting and it found no issues. I ran another over the weekend, I dont see any issues reported.
Let's do it:
GSmartControl
Thanks.
FRST Registry Search
6. Copy and paste 6.1.7601.22948;6.1.7601.21890;6.1.7601.22750;6.1.7601.18523 into the Search box and click the Search Registry button.
Step#1 - FRST Fix
Step#1 - FRST Fix
