[SOLVED] 2008 R2 SP1 issues installing updates
Step#1 - FRST Fix
1. Download and run Process Monitor. Leave this running as close to the failure as possible.
2. Try running SFC just like you have in the past.
I decided to vmotion the device to another host and it seems to have cleared the issue, ran SFC and was able to start applying updates. Thank you so much for all the help
