Re: [7SP1 x64] BSOD on Ryzen Desktop. FIX: CHANGED MEMORY SPEED
Unmarked as solved.
Try to lower again the ram speed to DDR4-2400 (PC4-19200).
It seems iomega zip drives could cause BSODs.
Samsung SSDs aren't present in MB QVL (SATA SSD Support List).
I can't find details about HDDs (firmware).
MB specs says only W10 is supported (although they included drivers for previous OSs).
One of their engineers in their forum wrote "new CPUs support only Win10".
Details about your graphics card? I found only Radeon R9 380 3GB pciex 3.0, I didn't find manufacturer and model.
Are you using a DVI-D to DSUB adapter (for the acer monitor)?
Did you disable defender antivirus?
Are you using any other antivirus?
Other checks:
Unmarked as solved.
Other checks:
Drives:
CPU, RAM frequency supported: 2667MHz
MB, RAM frequency supported: 2667/2400/2133
MB support: from 7 to 10
BIOS: latest
RAM model is present in MB QVL
Graphics driver: latest
ASUS VG27A 1920 x 1080 (32 bit) (59Hz) HDMI
ACER AL2216W 1680 x 1050 (32 bit) (60Hz) DVI
AMD Radeon (TM) R9 380 Series 3gb pciex 3.0
- IOMEGA ZIP 250 ATA Device
- SAMSUNG HD204UI ATA Device (2TB 5400rpm)
- Samsung SSD 850 EVO 500GB ATA Device
- NVMe Samsung SSD 960 SCSI Disk Device
BIOS: latest
