[SOLVED] [7SP1HomePre x64] WU kb2952664 will not install
Re: windows update kb2952664 will not install
great minds think alike I had already download that update from that site . Brilliant Brian taught me that and it failed also. what about sxstrace.exe ? and is this update important ? or is this update is needed for future upgrade to windows 8 because I am not thinking about upgrading soon.
Sxstrace is useful when dealing with SideBySide errors. This is not the case here. Please wait further instructions.
Hello!
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put
  9. Try updating again and attach CBS.log it fails.
Good morning Softwaremaniac and forum here is all the logs requested.SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-25 03:19:44.565
Using .txt script file at C:\Users\carl\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Currently storing 16 datablocks.
Finish time: 2018-02-25 03:19:46.000
Script hash: W81loGHITmes+oPAMuwz+PlBq71lFENZAbQKmjDKquo=
Afterwards run SURT and attach CheckSUR.log.
I feel your energy and determination to solve this challenging glitch that microsoft created, and I truly appreciate your time and effort we must be related because that is the way I am wired also, here is the log and txt. SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-25 13:05:50.467
Using .zip script file at C:\Users\carl\Desktop\SFCFix.zip [0]
Not using an additional text script file.
ERROR: File Placement Mode failed to identify destinations for all files and folders.
SFCFixScript.txt
Manifests\
AutoAnalysis:: directive failed to complete successfully.
Finish time: 2018-02-25 13:05:53.696
Script hash: RoRZns+ZgWwPaQrS9VYLeBibjE1mK8FyVVxjDxw0oqE=
Here is the report. SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-27 23:25:06.142
Successfully took permissions for file or folder C:\Windows\Temp
Successfully created directory tree \\?\C:\Windows\Temp\CheckSur\Winsxs\Manifests.
Successfully copied file C:\Users\carl\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4.manifest to C:\Windows\Temp\CheckSur\Winsxs\Manifests\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4.manifest.
Successfully restored ownership for C:\Windows\Temp
Successfully restored permissions on C:\Windows\Temp
Currently storing 17 datablocks.
Finish time: 2018-02-27 23:25:12.725
Script hash: 5yBI1RCXE6OmpUYMixoWzV7yNu0PafW0Ci1GI6B64FE=
okay the checksur log is coming soon.SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-27 23:40:03.030
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4.
Finish time: 2018-02-27 23:40:03.547
Script hash: cOHarSdAoiuff7if213sftcVU1msZ5XYWQuY9OsGfdo=
we are both workaholics to be up this early in the morning doing computer work .SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-28 02:39:53.140
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4
Successfully copied file C:\Users\carl\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aeinv.dll to C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aeinv.dll.
Successfully copied file C:\Users\carl\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aeinv.mof to C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aeinv.mof.
Successfully copied file C:\Users\carl\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aepic.dll to C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4\aepic.dll.
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-a..rience-program-data_31bf3856ad364e35_6.1.7601.23799_none_cfc64ad6b30242c4
Currently storing 18 datablocks.
Finish time: 2018-02-28 02:39:54.357
Script hash: Tywr2IDllsEAGshxSADSLjCunjOZ+1F7Ymj01GIh8/s=
True!
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put tags around the log to break up the text.
here is the log and checksur log will follow shortly.SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-28 03:34:06.544
RegistryScript::
Finish time: 2018-02-28 03:34:07.262
softwaremaniac I think I am becoming a maniac myself
