[SOLVED] [7SP1HomePre x64] WU kb2952664 will not install
Re: windows update kb2952664 will not install
you are still going strong softwaremaniac, and I am following your steps to success, here is the report SFCFix version 3.0.0.0 by niemiro.Start time: 2018-02-28 12:38:33.961
Using .txt script file at C:\Users\carl\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4c8d047f86c..d955f9f1707_31bf3856ad364e35_6.1.7601.23799_7c0c07142608ad5f.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4c8d047f86c..d955f9f1707_31bf3856ad364e35_6.1.7601.23799_7c0c07142608ad5f.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Currently storing 20 datablocks.
Finish time: 2018-02-28 12:38:35.428
Script hash: e/CTREyGojhdHInT6s6LdqS2cY1wX7ogsIvLs4RzPMY=
Softwaremaniac it looks like you over came the problem . My sfc /scannow log and the checksur log shows that everything is green and clean and when checking for updates the kb2952664 now appears as a optional update and not as an important update. The status of the update has change because of your hard work and indefatigable desire to fix this problem microsoft has created. Now that we know that this update is optional and not a requirement I can just hide this update with no serious consequences. You did a fantastic job Softwaremaniac and much kudos goes out to you. Your work ethic is a good sign that you will surely succeed in your endeavors in life. Thanks a million from me. Download CBS.zip from Sendspace.com - send big files the easy way
