BrianDrab
Emeritus
Please do the following.
FRST Registry Search
1. Click your Start button and type cmd.
2. Right-click on Command-Prompt that comes up and choose Run as administrator.
3. In the command-prompt window please copy and paste the following and then hit enter.
reg load HKLM\COMPONENTS c:\windows\system32\config\COMPONENTS
4. If you see "The operation completed successfully." then you did it correctly and can move on.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste KB3172614 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please copy and paste the contents in your next reply. If for some reason notepad doesn't open the file should be
saved on your desktop named Search.txt.
