Download SFCFix.exe (by niemiro) and save this to your Desktop.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
When I tried to update KB4074594--Monthly Quality Roundup for Windows 8.1 x64 based systems-- again, it shows the same problem as before, "We couldn't complete the update--Undoing changes"
Here's files.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put tags around the log to break up the text.
Here's SFCFix.txt. Ran KB4074594 but it failed to complete, so here is CBS.log file.
We don't seem to be going anywhere. Do you think my update problem is fixable or should I just start fresh? Thanks.
Let's try to get you to Win10 Pro and fix it that way.
1. Download the Media Creation Tool and save this to your desktop. Go ahead and run this as well. Note: Click the Download tool now button when you get to this link.
2. Accept the License Agreement
3. Download the ISO file to your desktop.
4. Double-click on the ISO and then run the setup to try and upgrade your machine.
We want to get the ISO so that you don't have to keep downloading which can take hours.
